EPSON 5010e 3D ghosting? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-13-2012, 01:59 PM - Thread Starter
Kitetsu's Avatar
I'm sorry if this has been posted before but I'm new here and new in the projector technology, ok I'm connecting my projector to my pc through onkyo receiver but experiencing ghosting with 3D movies especially in action scenes.
Is there anyway to reduce the ghosting (flicker) by any means cause I read some where here that Epson owners enjoy free ghosting in 3D movies. But couldn't find ways how to fix or reduce or enhance the quality, is it the graphic card configuration or the player's or the epson itself?
using Nvidia GTX 590
Thank you for baring with me
Kitetsu is offline
post #2 of 5 Old 11-14-2012, 10:10 AM - Thread Starter
Kitetsu's Avatar
Come on where are the experts?
Kitetsu is offline
post #3 of 5 Old 11-15-2012, 10:41 AM - Thread Starter
Kitetsu's Avatar
Up
Kitetsu is offline
post #4 of 5 Old 11-17-2012, 01:00 AM
96sev's Avatar
You could try to play with depth settings in powerdvd or nvidia settings, or play with Stereoscopic Player.
The epson isn't 100% ghost free, even if you would use stand alone player.
That is only thing I could suggest since I do use ati and 5010 and I don't have that problem, actually I have less ghosting that samsung player. I have realized that if you will play with depth setting would help for ghosting. Maybe do as I did before in searching of 3D pop out ( with to me is none) I have borrowed 3d blu ray player and ps 3, bought ultimate wave and tried on all three. This way I did compared colors, ghosting, quality etc. I wouldn't really relay on sbs or under / over since that will depend on some body's rip.
Ohhh also I do remember reading a post about placement and some guy did claim that when he switched from ceiling to shelf (head height) he did minimize his ghosting.
Well good luck, how is your pop out? Do you feel like stuff is jumping from screen?
96sev is offline
post #5 of 5 Old 11-18-2012, 02:13 PM - Thread Starter
Kitetsu's Avatar
Thanks, will try and update
Kitetsu is offline
