Selecting a projector - 106inch screen 12 ft viewing distance just under 8ft ceiling height - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 11-17-2012, 01:30 PM - Thread Starter
ankuse's Avatar
AVS was very helpful when I originally built my home theater 6 years ago, I have since moved and starting the process again.
There is one section in my basement that has a wall 154" wide, where I would put a 106" 16x9 screen, viewing distance (sitting area) is 144" from the screen and the ceiling height for that section is 95.5" however, I can mount the projector behind the sitting area and the ceiling behind the sitting area is 4 inches lower 91.5" and that area goes on for another 11ft from the sitting area to the back wall (completely opposite the screen). Thus, I think my greatest limitation in picking a projector is the ceiling height.
Based on the 1/3 rule, I understand screen placement (viewing area) is about 24" from the ground (using approximately 42" eye level). However given offsets from certain projectors I understand that I may have to mount my screen lower to the ground
Looking for a FULL HD (1080P) projector 3d is not a must, my past was DLP and I loved it but open to other types. I just want something around 2500 or less that works with this setup.
Any suggestions or help would be greatly appreciated.
ankuse is offline
post #2 of 6 Old 11-17-2012, 08:12 PM
eljaycanuck's Avatar
Quoted: 1228 Post(s)
Liked: 1800
A PJ with lens shift would resolve any placement issues. IMO, both the JVC DLA-HD250 (D-ILA) and BenQ W7000 (DLP) projectors are worth considering.
(AVS has B-stock DLA-HD250s available at a very nice price.)
eljaycanuck is offline
post #3 of 6 Old 11-17-2012, 08:15 PM - Thread Starter
ankuse's Avatar
Doesn't lens shift effect quality? Hopefully there is something out there with not so much offset.
ankuse is offline
post #4 of 6 Old 11-17-2012, 08:18 PM
Liked: 1800
Not that I'm aware of, unless perhaps you max out the H & V lens shift.
FWIW, my DLA-HD250 is mounted with the lens aimed at a point a few inches above the top of the screen, and an inch or two off to the side of center. The shifted image is dead-centered on screen and looks absolutely perfect.
post #5 of 6 Old 11-17-2012, 09:14 PM
RedBull1985's Avatar
I think u are confusing Lens Shift with Keystone Correction mate....which actually degrades PQ and should be avoided if possible..Lens Shift, on the other hand, is just repositioning of the image and is a very handy feature to have and makes PJ placement a lot easier.
Regards
RB
RedBull1985 is offline
post #6 of 6 Old 11-18-2012, 02:20 PM - Thread Starter
ankuse's Avatar
thanks for the info. Will do some research on those projectors.
ankuse is offline
