Epson 3020 Question - AVS Forum
post #1 of 6 Old 11-20-2012, 09:55 AM - Thread Starter
icemanphil's Avatar
Hello!
I am about to purchase a Epson 3020. This will be my first projector. I have a question about this projector and was hoping someone could answer.
I know that the 3020 has no lens shift, but how bad would it be if I had to set up the projecter not directly in front of my screen but off to the left like 2 feet? My throw distance is about 11' to a 106" screen.
Would I have to use keystone correction for this and if so how bad would that impair the quality?
Thanks for any help!
icemanphil is offline
post #2 of 6 Old 11-20-2012, 09:16 PM
y2k02c5's Avatar
Originally Posted by icemanphil View Post
Hello!
Keystone is different from lens shift. You will not be able to compensate the 2feet
y2k02c5 is offline
post #3 of 6 Old 11-21-2012, 10:25 AM
Deuteronomy31:6's Avatar
He will be able to compensate with keystone but will have to turn the projector towards the wall and than keystone it straight. but likely to sacrifice HD contant for the adjustment.
Deuteronomy31:6 is offline
post #4 of 6 Old 11-21-2012, 10:39 AM - Thread Starter
icemanphil's Avatar
Thanks for the replies!
How much quality will I lose using the keystone on the 3020?
I guess I could get the 5020 but I would basically be paying an extra $1000 for lens shift.
post #5 of 6 Old 11-21-2012, 02:41 PM
jpmst3's Avatar
Quoted: 72 Post(s)
Liked: 224
You will get much more than lens shift for $1000!
Joe = LFE Addict
Joe's LOWARHORN build
jpmst3 is offline
post #6 of 6 Old 11-21-2012, 04:36 PM
What he said. sounds like you might have to do ur research before you pull the trigger. Good luck
