epson's galore: 8350, 8500, 8700, 3010, 3020, 5010, 5020 --- which one for 2d? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-20-2012, 08:22 PM - Thread Starter
ivo welch's Avatar
the 8350, 3020, and 5020 are current models. the others are very recent, and widely available refurbished.
the 3020 and 5020 are best for 3d, with the 3020 being the plain model and the 5020 being the videophile model.
alas, what about 2d? I don't care much about 3d.
the 8350 is supposed to be the 2d home theater model, but it is 2 years old. does the new 3020 beat it even on its home turf of 2d movies? does the 5020 beat the 8350 easily on 2d?
the 8700 is expired, but does it perform as well as the 5020 on 2d home theater application? is it much better than the 3020 for 2d applications? where does it rank? almost as good as the 5020, or just a little better than a 3020?
(Assume that light output is good enough on all of them.)
any insights would be appreciated.
/iaw
ivo welch is offline
post #2 of 5 Old 11-20-2012, 09:29 PM
Deuteronomy31:6's Avatar
If 2d is all you care for, 8700ub will be the best choice. It's comparable to 6020 w.o the 3d but much cheaper.
Deuteronomy31:6 is offline
post #3 of 5 Old 11-21-2012, 08:09 AM
Duke Broadway's Avatar
Are you a gamer? 8350 is your best bet. Not sure of lag times on the 8700. I know the 30/50 series and significant more lag compared to 8350.
Duke Broadway is offline
post #4 of 5 Old 11-23-2012, 08:48 PM - Thread Starter
ivo welch's Avatar
no, just movie watcher. as long as my audio is sync'ed, I am fine.
best,
/aiw
post #5 of 5 Old 11-23-2012, 08:57 PM
jdsd6k's Avatar
The 8350 is one I've been considering (my post is in the $3k and up forum) as I do game on my Xbox/Wii. While reading the owner forum thread though, all the talk about failed iris' began to freak me out though. Sigh.
jdsd6k is offline
