Epson 3010 and Epson 3020 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 11-20-2012, 10:10 PM - Thread Starter
Black Cat's Avatar
Can anyone help with a brightness question....?
The Epson 3010 is rated at 2200 lumins and the the 3020 is rated at 2300 lumins. Not that much difference it would appear?
When I use the projector central calculator to calculate foot lamberts there is a huge difference in the 2 projectors. What's going on? Is there some big difference with the lens or other feature? None of the reviews indicated any difference in the projectors like that.
I'm trying to figure out a projector that will work with a 20 foot throw to a 10 foot wide screen. The 3020 appears to work well for those conditions but it's confusing why the big difference in screen brightness.
Thanks for any explaination.
Black Cat is offline
post #2 of 2 Old 11-21-2012, 03:39 PM
Deuteronomy31:6's Avatar
I think there are more advantages to buy 3020 than for extra 100-200 L. I had both, after calibration, it's negligible. Both will work. For extra $200 having Iris adj on 3D, shorter lag time and less cross talk was a sealer for me.
Deuteronomy31:6 is offline
