INFOCUS X10 blue tint - AVS Forum | Home Theater Discussions And Reviews
Old 11-22-2012, 07:04 PM - Thread Starter
mase's Avatar
I have an Infocus X10 with about 2500 hours on the original bulb. Today the picture showed a blue tint after the projector was on for about an hour. You could see the image, but the picture had a blue tint to it. The tint is uniform across the picture.
I shut it down for about 10 minutes, turned it back on, the picture was normal for a few minutes and then the blue tint appeared again.
Does anyone know if this means that the bulb is going or is it something else. I want to order a new bulb but don't want to spend the cash if it is another problem.
Thanks in advance.
Galatians 6:7-8:
mase is offline
Old 11-22-2012, 07:36 PM
talon95's Avatar
Quoted: 130 Post(s)
Liked: 63
Definitely not the bulb. Likely a problem with the projector. If you have brilliant color turned on, might try turning it off. I've seen some odd things happen with it on, although not what you describe.
talon95 is offline
