what is ambient light? AR100U vs Epson 8350 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-23-2012, 08:10 AM - Thread Starter
bahboric's Avatar
I want to replace my old Optima h31 with either a Panasonic AR100U or an Epson 8350. From what I've read, the projectors seem very similar, but the AR100U is brighter and does better in ambient light, and the 8350 has better blacks in dark rooms. The problem is that I don't know what counts as ambient light. This is for home theater in my living room (2 walls are yellow paint, the other opens into the dining room). We never watch during the day, and at night in the winter it is pretty dark, say at least as dark as a typical movie theater showing the main feature. However, during the summer months the sun sets later, and there is more light until later in the evening. I have drapes and shades on all the windows, but some light seeps in around the edges. So on early summer evenings before the sun sets, I'd guess the light is similar to what I see in a movie theater when they are showing previews (much lighter than when the movie is on), but it will then get dark as the evening goes on.
So when people are talking about the Epson not doing as well in ambient light, are they talking about situations like I have in the summer before it is really dark, are they talking about the minimal light during a theater's main feature, or are they talking about viewing it in daytime or with lamps on? Put another way, when I read in reviews that the Epson is better than the Panasonic for dark rooms, I don't know what is meant by "dark room"; does my room on summer evenings with shades drawn count as a dark room? Does my room on winter evenings count as a dark room? What I'm wanting to know is whether I need to get the AR100U, or whether the 8350 will be bright enough for my needs. Some online discussions seem to indicate the Epson is not bright enough for living rooms, although some (http://www.projectorcentral.com/epson_home_cinema_8350_projector_review.htm?page=More-Advantages) seem to indicate there is no problem projecting a 120" diagonal with curtain light leakage. And will the Panasonic be too bright for 120" screen once the sun has set?
Other info: My screen is 120" diagonal (105"x 59"), and the distance from the screen to the lens on my current Optima is 14' 7". I haven't quite figured out how to calculate the throw distance and other technical details yet, but as far as I can tell, both should be able to project a 105" wide image at this distance (but I could be wrong). I will mount the projector on the ceiling, but I can easily modify how low I mount it (right now top of the screen is 17" from the ceiling, and the lens is 11" from the ceiling).
Any help would be appreciated. As you can tell, I'm not very knowledgeable about these matters. It looks to me as if the Epson is about $200 cheaper than the Panasonic and would be bright enough even on summer evenings, but I'd pay the extra $200 if it means a better picture for me in my situation.
Thanks, Ric
bahboric is offline
post #2 of 3 Old 11-23-2012, 08:57 AM
Mr.G's Avatar
Quoted: 708 Post(s)
Liked: 397
Coming from the Optoma H30 either of these projectors will be a significant upgrade. A dark room (bat cave) defines an area with total light control. A room with ambient light describes most living and family room environments. Your description of your living room is a close match to my family room where my AR100U is used and is the type of room that this projector is intended for. It is bright but you can tone down the light output by using eco mode and one of the low light picture modes. The Epson 8350 is a good projector and cheaper so your choice will be based on price or brightness - whichever is the most important. Your screen size and throw distance will not be a problem with either.
BTW there are dedicated threads for both of these projectors, just use the search function on this website.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is online now
post #3 of 3 Old 11-23-2012, 09:02 AM
Crabalocker's Avatar
Quoted: 182 Post(s)
Liked: 122
"Ambient light is the available light in a room, whether by natural or mechanical" Dark room is exactly that, a room where it can go dark either by night or the ability to be light controlled, eliminating/controlling the ambient light.
I don't know much about Panasonics but do own a couple of Epsons, the 8350 being one of them and it can handle 'ambient light' to a certain level. You must understand that in my situation I'm lighting up a 153" screen so I'm pushing my projector close to its max. I don't like the living-room and dynamic modes of the 8350 because they appear to me to give an unnatural look to the image and colours. Maybe this is why they say the Panasonic is better with ambient light? maybe their dynamic, or brighter projector modes, have a more natural look to them????
I can watch regular TV with my lights dimmed, around quarter strength, and still have an OK picture with the 8350 in one of its better modes. I like natural. The other factor is screen gain. Mine is closer to 1.0 so it can handle more room reflections than say a high powered screen.
I believe the Epson 3020 has around 1000 lumens when calibrated in best mode so it should be plenty bright while having nice colours and look. This will give the 3020 the ability to handle more 'ambient light' than the 8350, again I don't know much about the Panasonic. The 3020 would be closer to what I would see with my W7000, brightness wise, which handles ambient light extremely well. I can watch with my lights at 3/4 strength with my W7000 and still have a really good looking picture. I can have my lights on full and the image is still watchable, the 8350 you could not unless you went into one of the brighter unnatural looking modes, IMHO.
Crabalocker is offline
