mitsubishi hc3800 lamp life and brightness - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-24-2012, 12:46 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
i got to about 400h mark and it seems as though the lamp is dimmering, i now have to use BSPLAYER because it has higher brightness compared to other softwares could it be that at the 400h mark the projector dimmers so much?, i would say i'd lost around 30% of brightness, i cant see hair in the dark anymore if use VLC player or total media theater.
i tried different settings but it seems like it has to do with the hardware itself.
any thoughts? did this happen to any of you?
soler37 is offline
post #2 of 3 Old 11-24-2012, 01:32 AM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
It's common for a bulb to noticeably dim after 100 - 200 hours. That's why you have to re-calibrate contrast and brightness. You need to do this.
Jim McC is offline
post #3 of 3 Old 11-24-2012, 10:44 AM - Thread Starter
soler37's Avatar
Quoted: 18 Post(s)
ah i didnt know that, good to know. ill try and recalibrate then.
soler37 is offline
