best gaming projector under 600 dollars - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 11-29-2012, 07:34 PM - Thread Starter
crazybizzle's Avatar
im a noob to projectors, ive never owned one and there is so much info to search thru and im having a hard time trying to figure one out. does anyone have any input and help in figuing one out for me. my wall it is going on is 15 feet long and i have 13 foot ceiling looking to get the best one under 600 or even cheaper so far ive picked the viewsonic pjd 5133...im also looking to have the screen at a minium of 150 inches...any help or advice would be great thanks
crazybizzle is offline
post #2 of 5 Old 11-29-2012, 07:38 PM - Thread Starter
forgot to add would like it to be 1080, 3d is a must and the room is usually dark
post #3 of 5 Old 11-30-2012, 12:27 PM
rdb4133's Avatar
For $600 you won't be able to find a 1080p 3d projector for sure, maybe a 720p.
rdb4133 is offline
post #4 of 5 Old 12-01-2012, 07:04 AM
aznbladez's Avatar
LG pa70g which is a LED projector if you don't want to worry about bulb life. You can also turn it on and off repeatedly unlike DLPS.
aznbladez is offline
post #5 of 5 Old 12-01-2012, 07:23 AM - Thread Starter
Okay ..so 600 is out then whats the best one for my needs under a grand then
