Epson LPE Filter. Over 1600 Color Correct Lumens Out Of the 5010/5020 6010/6020? A Detailed Review. - AVS Forum | Home Theater Discussions And Reviews
Old 11-30-2012, 01:43 AM - Thread Starter
Kirnak's Avatar
What is the LPE filter? It's a filter 12 cm in diameter that mounts on the 5010/5020. It comes with special edition "Light Power Edition" 5010/5020s projectors. It corrects the native light output of the bulb in the same fashion as the internal filter, except that it is more efficient due to it's size. You run the PJ in Dynamic with a few adjustments listed in the instructions. Supposedly, you get over 1200 color correct lumens--in ECO lamp mode. Over 1600 in Normal lamp. PLUS, you get a healthy bump in native contrast! (Up to 5000 from about 4300 on the 5010. Even more on the 5020.) Here's the link. It's in German, so you'll have to use Google Translate. http://www.cine4home.de/tests/projektoren/Epson_TW9000/TW9000_Test.htm http://www.cine4home.de/Epson/LightPowerEdition/TW9100/Werte/Kurzanleitung9100er.htm
Why is this only available in a couple of European countries? I have no idea.
I'll calibrate it and measure lumen output to see how it lives up to the claims. I'll be using an i1 Pro, and an i1 Display Pro to test and calibrate with Calman 5 software. I'll be taking measurements off my DIY 138" screen. It's Glidden Diamond 450 Titanium White and has a DeltaE of 1.43; RGB measure out at 245, 246, 243. (Measured with an i1 Pro and BabelColor.) I'm guessing gain at around 1.1 to 1.2; hopefully I'll be able to get the gain measured soon. Lumen output will be measured directly with a Lux meter. I have no means to objectively measure contrast.
There are a few minor adjustments you're instructed to make in addition to snapping the filter in place. Contrast -10, Color temp 7000 (I ended up at 7500.), Skin tone 5. (Many thanks to AVS member ANDYK48 for translating the instructions to English!)
I got my 5020 today. I was able to do some very rough testing of lumen output and watched a few scenes from Avatar. It'll be a day or two before I can do any real testing and calibration. But I thought I'd share my first impressions.
WOW!
First the measurements, and bear in mind these are rough. I'll get better readings soon. ECO lamp mode: 1200 lumens. Normal Lamp mode: 1600 lumens. To my eye, the color is pretty darn good! Using the starship scene at the beginning of Avatar, it seems to my naked eye that contrast is improved. The star field is very black and the starship is brilliant. Forest scenes where there is sun lit areas along with shaded areas look incredible. Skin tones during the live action scenes look very good. Subjectively, this picture looks outstanding! If I never calibrated it I'd be a happy man to have it look as good as it looks now. Calibration can only make it look even better.
I have an Epson 8700UB that I calibrated Dynamic on. The gray scale actually turned out pretty good, colors seemed close but curved through the saturations instead of straight. Output measured at 1100 lumens. Let me tell you one thing straight and clear: That 8700 in calibrated dynamic never looked even one tenth as good as this 5020 with the LPE filter. In THX mode, I never saw more than 12 Ftl with a brand new bulb. I thought that looked great, but it can't hold a candle to this LPE equipped 5020. I'm only getting 9 ftl out of my Epson now in THX, I'm getting over 20 With the 5020. I'm gushing, I know. But if you have a large screen, this filter is a complete game changer for the Epsons. A whole new level of performance.
Someone at Epson is absolutely insane for not making this filter available in the US.
Measurements, calibration, screen shots, and more movie watching to come.
Kirnak is offline
Kirnak's Avatar
Kirnak is offline
Kirnak's Avatar
Here's the measurements with the suggested settings for the 5020. Not calibrated, just the directions that come with the filter. Pretty darn good! This was in normal lamp mode, I'll post up if ECO has any significant variance.
Obviously, things can be tightened up a bit. But considering this is what you get without needing a calibration, it's excellent.
Lumen output was measure at 1655 lumens.
Now, bear in mind there's a bit of zoom here. The Lens is at about 15.5 feet, I think around 14 feet would be wide open. So, max lumens should be just over 1700 lumens. I'll edit to add ECO lumens later. I'm guessing over 1200.
Kirnak is offline
Kirnak's Avatar
Calibrated Lumen Output:
ECO: 1337
Normal: 1780
Here's the best I could do. Colors came out exceptionally well, except for red. Gamma is near perfect. The Grayscale calibrated is not much better than not calibrated. The problem is that the colors are curved in such a way that the typical Gain/offset just can't be adjusted so that DeltaE is below 5 at each point.
Overall, color is very good. Not outstanding, but very good. In all honesty though, while watching a movie color seems very natural. The fact that red and the gray scale is not perfect is just not noticeable to my eye. Skin tones are excellent in every scene that I used to evaluate them. Blacks look black, whites look white and grays look gray. Colors look excellent and natural.
For the vast majority of us I think this is as good as it gets. Purists will want better, no argument there. The color is available at every point, it's just that adjustment is not sufficient. A video processor that can adjust gamma for each of the colors would have no problem nailing a perfect grayscale, and all colors too I'm sure.
Screen shots to come.
Settings I used. Anything not listed is at default value.
Dynamic
Contrast -1
Color -4
Temp 6500K
Skin Tone 4
Gamma Custom
RGB
Red Offset -15
Green Gain -4, Offset -2
Blue Offset -16
RGBCMY Hue, Saturation, Brightness
Red: 0, -3, -12
Green: 29, 38, -24
Blue: 8, -35, 0
Cyan: -13, 30, -25
Magenta: 12, 0, 8
Yellow: 0,0,0
And here's the Grayscale after calibrating with an iscan Duo video proccessor. No hit in lumen output to get this. 100 IRE green was not dropped, rather Blue and Red were bumped up. So, if anything a slight bump in lumen output. The bump in Gamma at the higher IREs and the drop in Gamma at the lower IREs was intentional.
Kirnak is offline
Old 11-30-2012, 01:44 AM - Thread Starter
Kirnak's Avatar
Here's the results of my 3D calibration with my 5020 and LPE filter. 3D Dynamic mode:
I could have tightened things up a little bit, But I have a new PJ on the way and it's not worth the effort for now. Measured output is 1600 lumens. Mind you, I have full horizontal shift and the PJ is at 15 feet. If the PJ was centered and wide open on the zoom, I think output would be closer to 1700 Lumens.
Also, there should be a Mini 3D on the way soon! Woo Hoo!
Kirnak is offline
Old 11-30-2012, 06:49 AM
UdoG's Avatar
Quoted: 111 Post(s)
Which settings you use with the LPE filter? Did you tried the LPE filter also in 3d - is the brightness always the same?
I received the following settings for the German 9100 LPE (similar 6020):
Settings in German (!):
Menu / Bild:
Farbmodus: Dynamisch
Helligkeit: 0
Kontrast: -1
Farbsättigung: -4
Farbton: 0
Abs. Farbtemp.: 6500K
Hautton: 4 oder 5
Menu / Bild / Erweitert…:
Gamma: 2,2
RGB/Offset: R: -10 / G: 0 / B: 0
RGB/Gain: R: 0 / G: -7 / B: 0
RGBCMY
Schattierung R: „0“ Sättigung R „-12“ Helligkeit R „-12“
Schattierung G : „0“ Sättigung G „0“ Helligkeit G „-9“
UdoG is online now
Old 11-30-2012, 07:30 AM
buddhamus's Avatar
Quoted: 108 Post(s)
Liked: 80
Man, I wish there was someway we could get this filter...Im already happy with the black levels atm but If this indeed improves it further while giving me more contrast........Id be stupid not to do it. But Epson is ****ing us over on the other side of the world frown.gif
buddhamus is offline
Old 11-30-2012, 08:45 AM - Thread Starter
Kirnak's Avatar
@ UdoG: I haven't used anything other than the basic settings that were in the instructions--and shown in my post. Further analysis and calibration will come in the following days. How are you liking the results with your LPE filter?
@ Buddhamus: It's not that Epson is screwing you guys; this filter is only available in a couple of European countries. Again, I haven't the slightest idea behind the reasoning here. Perhaps someone at Epson will take note of this thread and release the filter world wide. biggrin.gif
Kirnak is offline
Old 11-30-2012, 08:56 AM
HDTV Maniac's Avatar
Will this filter work on an 8350?
HDTV Maniac is offline
Old 11-30-2012, 09:16 AM - Thread Starter
Kirnak's Avatar
Unfortunately, I doubt it. I'm not sure how you'd mount it and the native color output of the lamp is different. I guess the mounting is doable... I have an 8700UB--same lamp as the 8350--at the very least I'll hold the filter up in front of the PJ and eyeball the results. I'm leery of trying anything more as I'd be terrified of damaging the filter. Right now I have no way of getting another and without it I'm back to low brightness or inaccurate color...eek.gif
Kirnak is offline
Old 11-30-2012, 09:21 AM
UdoG's Avatar
Quoted: 111 Post(s)
I will perform some tests in the next days... strange is that I received other settings - f.e. contrast -1 instead of -10 (which you postet above) and the color temp is also different!
UdoG is online now
Old 11-30-2012, 09:25 AM - Thread Starter
Kirnak's Avatar
The instructions I have are for the 5010, but the PJ I have is the 5020. It would be great if you could post the instructions for your 6020!!!! If your instructions include them, could you also post the native contrast with and without the filter? Thanks!!
Kirnak is offline
Old 11-30-2012, 10:12 AM - Thread Starter
Kirnak's Avatar
@UdoG: Are the settings in your post above what you did with a calibration, or are those the settings that Epson provided with the filter?
Here's the Google translation of UdoG's settings:
Colour mode: Dynamic
Brightness: 0
Contrast: -1
Color: -4
Hue: 0
Abs:. 6500K
Skin tone: 4 or 5
Menu / Picture / Advanced ...:
Gamma: 2.2
RGB / Offset: R: -10 / G: 0 / B: 0
RGB / Gain: R: 0 / G: -7 / B: 0
RGBCMY
Hue R: "0" saturation R "-12" Brightness R "-12"
Hue G: "0" saturation G "0" G brightness "-9"
Kirnak is offline
Old 11-30-2012, 10:18 AM
UdoG's Avatar
Quoted: 111 Post(s)
These settings are directly from cine4home which develop the filter for Epson!
Please check also this link:
cine4home
UdoG is online now
Old 11-30-2012, 10:51 AM - Thread Starter
Kirnak's Avatar
Kirnak is offline
Old 11-30-2012, 10:52 AM
lesliew's Avatar
Location: From Nottingham in UK but living in Palm Bay, FL
Kirnak
Any ideas of a European part number or URL order page for the filter or is this only available with an LPE PJ
lesliew is offline
Old 11-30-2012, 11:41 AM - Thread Starter
Kirnak's Avatar
A couple of people, including myself, have managed to find this filter separately. Pretty hit or miss at this point. I don't have a source right now, but I'm working on one. Hopefully, if we can show demand, Epson will release this filter more widely.
Kirnak is offline
Old 11-30-2012, 12:11 PM
rufilo's Avatar
Hi Kirnak,
Nice thread!
I'll be getting a 9100W within one or two weeks and surely I'll be tracking your testing.
Any idea how can I get one shipped to Portugal?
Darbee already in house waiting for it.
Cheers,
///Rui
rufilo is offline
Old 11-30-2012, 12:25 PM
UdoG's Avatar
Quoted: 111 Post(s)
UdoG is online now
Old 11-30-2012, 12:29 PM
ANDYK48's Avatar
I have the LPE filter and the EH-TW9000W projector (5010 in the US)
I just saw the link that UdoG provided for the EH-TW9100 settings for the LPE filter and there are differences between this and the older version of the projector.
For comparison here are the settings that came printed on a leaflet from EPSON with the LPE filter.
I have spotted a German guy in Ebay that has around 10 LPE filters in stock, but unfortunately he ships only in selected European Countries. Mine is also excluded - I got mine from another german seller but he has no more in stock.
If you can convince him to sell them to a group of you that will be great.
Here is the link
http://www.ebay.de/itm/EPSON-Light-Power-Filter-passend-EH-TW-9000-9000W-/180899107868?_trksid=p2045573.m2042&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D27%26meid%3D3831447187535415039%26pid%3D100033%26prg%3D1011%26rk%3D4%26sd%3D360498669962%26
ANDYK48 is offline
Old 11-30-2012, 01:47 PM
Quoted: 112 Post(s)
Liked: 125
Someone please tell me if they find one. I want to use it on my Epson 6010!!!
HT - JVC RS520 - Anthem AVM 60 - XPA-7 - XPA-5 - GE Triton 2 - GE Supercenter XXL - GE Invisa 650 x 8 - Xbox One - PS4 Pro - Oppo BDP-203 - Dual Rythmik FV15HP's - Lumagen Radiance Pro
My Media Room
kaotikr1 is offline
Old 11-30-2012, 05:42 PM
hrc4u's Avatar
Damn doesn't ship to my country :-(
hrc4u is offline
Old 11-30-2012, 06:02 PM
buddhamus's Avatar
Quoted: 108 Post(s)
Liked: 80
If you can find one, please let us know...as I would be on board for sure smile.gif
Old 12-01-2012, 02:07 AM
rx-8's Avatar
I would definitely get one also.
Cheers!
-- Bill --
rx-8 is offline
Old 12-01-2012, 07:01 AM
Quoted: 112 Post(s)
Liked: 125
So the guy linked earier in the thread has a new listing on eBay. It says he now ships to the US. But he wants 435 EUR which is over $500 USD. I think I will pass.
I do have some good news. My pilot friend showed up yesterday and has a buddy that lives in Germany who is a huge movie/HT buff. He is going to send him the information and try to locate the filters.
I will try and get as many as I can.
Edit -
So I emailed that buyer and asked why the increase...So which one of you here got 15 of them?
Sorry this item is sold! this is a set for 15 filters for a customer from USA!
thx
eder natascha
- di-life
My Media Room
kaotikr1 is offline
Old 12-01-2012, 08:04 AM
lesliew's Avatar
Here is the link
OK Guys, To cut a long story short
Sorry if I gazumped someone else but I've been communicating with this seller since 5:30AM EST. It originally started out at 5 sets which I sent payment for via paypal at around 7:02am but for some reason I may have crossed wires with another interested party and ended up snagging all 15.
So here's the deal
Since I took the risk I'm only looking to cover the cost of my own filter through AVS forum, so I will sell 10 filters via this forum to the first 10 lucky people who send me a PM.
I'm not going to spend all day answering questions just send me a PM if your a committed buyer. Your cost will be $48 + shipping to wherever you are.
You don't pay me until I have them here in my hands. The ebay seller has promised to mail these out on Monday so hopefully they won't take much longer than a week to arrive.
Hopefully you will agree that's a fair deal
The remaining 4, I will probably flip on ebay for a profit since the cheapest I could find these going for elsewhere was 79 Euros
$48 + shipping (Sorry - All 10 Now SOLD)
Leslie
Forums Mods - Please be gentle with me if I have listed this item for sale inappropriately or incorrectly, I apologize in advance.
lesliew is offline
Old 12-01-2012, 08:41 AM
ANDYK48's Avatar
I confirm the findings of Kirnak. I checked mine yesterday (EPSON EH-TW9000W, 5010 in the US) and I am getting around 20 ftl in dynamic mode with the LPE filter on a 92" high contrast gray screen with 0.8 gain.
At a first glance primary colors were almost spot on with the settings EPSON provided but secondary colors were not so good, especialy Magenta if I remember correctly.
Brightness and Contrast were also spot on.
ANDYK48 is offline
Old 12-01-2012, 11:30 AM - Thread Starter
Kirnak's Avatar
@Lesliew: LOL, that was me! I finally had to go to bed after messaging with those guys all night, 5 minutes before they finally put the filters up. rolleyes.gif It all worked out in the end as I was going to make them available here too.
PM sent
Kirnak is offline
Old 12-01-2012, 11:46 AM
lesliew's Avatar
PM sent
PM sent
lesliew is offline
Old 12-01-2012, 12:13 PM
lesliew's Avatar
Update
Sorry to those late to the party but all 10 filters have now been sold.
Those lucky 10 have been notified via PM.
Already had a item marked for dispatch email from ebay but no doubt the item won't be picked up by a courier until Monday, as soon as I get tracking information I will provide another update via PM.
Thanks again
My 6020 is a very happy projector, I can see her grinning as I type biggrin.gif
lesliew is offline
Epson , Epson Usa Inc , Epson Projector , Epson America , Epson Projectors
