Projector Offset question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 11-30-2012, 09:07 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Say I have a short throw and I want a 100" screen size or so.. on projector central it's showing me having a 9.5" offset for a 16:9 screen, OK as seeing I don't have the projector yet I was looking at this mount here http://www.amazon.com/Vantage-Point-CGUPM12-B-Universal-Projector/dp/B00067OR6K/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=1NH884YY0W7K2&coliid=I3GH91HMVEMEEI
I ask all this because when I did a mock up on the wall I did not count in the offset but with the mount could you slightly tilt it up without distorting the image?
SubaruB4 is offline
post #2 of 10 Old 11-30-2012, 09:50 PM
ebpgh's Avatar
I just got the BenQ 710st and that exact mount. My screen size is about 120 from 7-8 feet and I am projecting under a beam. Pretty happy with both so far.
ebpgh is offline
post #3 of 10 Old 12-01-2012, 03:13 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
That's good I just hope it works for me, since the offset is throwing me off a little, if i tilt the projector upwards to lessen the offset will it distort the image too much? The other projectors I use they have a lens shift so in a short throw I'm not sure how I should go.
SubaruB4 is offline
post #4 of 10 Old 12-02-2012, 05:30 AM
aviman33's Avatar
Your definitely going to notice that much alignment error. Add the 9.5" offset to the distance between the center of the lens and the ceiling and the result is the distance from the ceiling to the top edge of the screen. I'm guessing that mount will put the center of the lens approx 7" below the ceiling. So your screen will be approx. 16.5" below the ceiling.
You could build your own flush mount or partially recess you projector into the ceiling. This will get you close enough to avoid using keystone adjustments.
aviman33 is offline
post #5 of 10 Old 12-02-2012, 05:55 AM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
The ceiling is concrete so that makes things harder.
SubaruB4 is offline
post #6 of 10 Old 12-02-2012, 08:35 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Only other way I think it can be done is get a wall mount and mount the projector so it's not upside down.. however it would have to sit lower which would be another issue.
SubaruB4 is offline
post #7 of 10 Old 12-03-2012, 11:25 AM
ebpgh's Avatar
My projector is mounted 8" from the ceiling (to the top of the projector) and the image starts about 11 inches from the ceiling. I have it tilted slightly upward to get under a beam. I'm using the keystone correction, but I'm not noticing any difference in picture quality. You can use the mount as a flush mount as well if you remove one of the extensions. It is pretty versatile especially if you aren't sure what you are doing.
ebpgh is offline
post #8 of 10 Old 12-03-2012, 12:26 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
My ceiling is 7.9' so I was thinking wall mount (picture would be too big for room) or these two ceiling mounts.. If I did a wall mount my room from the other wall is 9 ft so that would make the image 84" tall and 172" diagonal, also if I wall mounted it a projector in it's upright position shoots upwards so that means I would need to lower the height on the wall which means sitting in bed would be an issue taking in account of the ceiling height.
but I was looking at these 3 mount types
it would be 1000 times better if I had the projector here now to see in person what my limits are but right now just going by what the data is on projector central, It wont be until after christmas I can get the projector now.
SubaruB4 is offline
post #9 of 10 Old 12-03-2012, 04:17 PM
ebpgh's Avatar
You can mount the vantage point on the wall as well, so it might be the most flexible option.
ebpgh is offline
post #10 of 10 Old 12-03-2012, 06:00 PM - Thread Starter
SubaruB4's Avatar
Quoted: 32 Post(s)
Liked: 30
Oh yeah I forgot about that one.
SubaruB4 is offline
