"Rainbow Screen of Death" Sony VPL-HW10 not working!!!! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-11-2012, 07:18 PM - Thread Starter
Robster1958's Avatar
After several years of "just" enjoying this hobby, I now have a problem.....
Immediate need for a new PJ; my 3.5 year old Sony HW10 with only about 1,400 hours on it appears to have bitten the dust. i never turned it on since the power issues with the hurricane, so maybe a board fried out. The attached picture says it all.
Anyhow, with the holidays and all, I don't have my usual time to research and compare. I am looking for an easy remove and replace job with respect to mounting. I have a 92" x 52" screen with 12 foot throw distance and Chieftan universal mount. Totally light controlled cave.
I was very happy with the Sony with respect to PQ, small size and lack of dust, noise and heat. In fact, i can detect noise more easily than n'th black level.
So under the assumption of technological progress, and the the HW10 was $2,499 in its day, i am hoping i can do better at that price point now. Given the unexpected nature however of the added expense, i would love to keep the cost as low as possible.
Any advice? thanks!
Robster1958 is offline
post #2 of 4 Old 12-11-2012, 09:57 PM
uuddlrlrbass's Avatar
How much would it cost to ship it off to Sony to possibly fix? Probably not worth it?
uuddlrlrbass is offline
post #3 of 4 Old 12-11-2012, 10:32 PM
tulum's Avatar
If your power was off for some time, you might need to double check the settings on the projector and the receiver or whatever you use to switch sources. I'd also double check that the HDMI cable is firmly plugged in. If it is it wouldn't hurt to try another cable.
Sorry this happened to you and glad you made it through the storm.
tulum is offline
post #4 of 4 Old 12-12-2012, 03:47 AM - Thread Starter
i should have mentioned that even the setting menu fails to project; just this rainbow....which i am starting to enjoy!!
seriously, my quick research yields the Sony HW30, although apparently discontinued still sells close to msrp everywhere.
next choice is Panny AE7000; then Epson 5020 (need black case).
also...appears that all mainstream pj's are 3D, which seems to an added expense and complexity with no usefulness for me. unless i don't know what i'm missing.
