Help with 8350 placement please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 12-12-2012, 02:01 AM - Thread Starter
Lands's Avatar
Hi,
I've decided to go with the Epson 8350, but the problem is I can't mount it to the ceiling. To make things worse, in front of where the screen will go I have a bunch of windows with very little space between, so I can't have a permanent shelf there.
I will have to have something that is moved into place unless there is another solution. I understand you can have this projector quite a bit off center? Here's a rough sketch of my layout:
Would I be able to have my projector either off to right or left as shown above? What are the limitations with this placement (meaning how far to the side can you go)?
Since you're going farther away from the screen, I'm sure I'd be losing some brightness, but might be worth it.
Thanks very much for the advice.
Lands is offline
post #2 of 7 Old 12-12-2012, 02:11 AM - Thread Starter
Lands's Avatar
There's a chance I've answered my own question. :-)
I THINK the image below is telling me the projector can be 8'11" from the center of a 130" screen.
Am I correct?
Does anyone have experience with this? How much did it effect the picture quality and brightness?
Lands is offline
post #3 of 7 Old 12-13-2012, 01:02 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Yes, that looks right. You can get image problems as you go too far. Ideally, I would not go beyond the edge of the screen.
lespurgeon is offline
post #4 of 7 Old 12-13-2012, 02:13 AM - Thread Starter
Lands's Avatar
Thanks. I made the move and picked it up today. Haven't yet tried to go too far left or right, but the up/down lens shift has already been a huge help.
I'll update this thread once I try.
Lands is offline
post #5 of 7 Old 12-13-2012, 08:50 AM
yusoslo's Avatar
Just to add on. I am about to order the 8350. I was using this tool but it does not give me height adjustment. I want to hang mine from the ceiling with the projector centered but 1' from the ceiling. I dont have to have the projector in the middle of the screen correct? I believe in my reading you can throw the image down and then adjust the trapezoid effect.
yusoslo is offline
post #6 of 7 Old 12-14-2012, 07:53 PM
yusoslo's Avatar
bump for my question.
yusoslo is offline
post #7 of 7 Old 12-15-2012, 06:58 AM
RTROSE's Avatar
Quoted: 192 Post(s)
Liked: 167
^^^^^You are correct you don't have to have the projector in the center of the screen. With lens shift you won't have keystoning which is what you are calling trapezoid effect. You should be good to go.
RTROSE
RTROSE is offline
