Upgrading from an Optoma HD7100 need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-13-2012, 10:29 AM - Thread Starter
attichometheater's Avatar
I’m looking to upgrade from an Optoma HD7100 now that it finally died and I was contemplating the Optoma HD33. Anyone have any info on the quality of the projector or known defects in the unit? My HD7100 gave me nothing but trouble and I’m a little leery of purchasing another Optoma product. I really like the picture quality the DLP chip produces better than any other type of projector. I have a max throw of 13.5 ft. ceiling mounted projecting onto a 100" screen. My HD7100 is mounted 10ft 6in away from the screen and I would like to keep that mount if possible. I really do not feel like spackling and painting the ceiling if I can help it. Any info would be appreciated.
attichometheater is offline
post #2 of 3 Old 12-13-2012, 02:33 PM
rekbones's Avatar
Quoted: 466 Post(s)
Liked: 238
The HD33 seems to be a fairly sold projector, I have read the whole thread with very few problems reported with it and mine has been no problem at all. Some of the earlier firmware revs had some lockup issues. All the entry level DLP 3D projectors have come very close in price in the last 6 months so its a tough decision. ACER hb9500, benq 7000 Mits 7800 all with there own quirks. The benq 1070 soon to be on the US market looks promising. The Mits and Benq 1070 both have DC3 to there advantage (don't know how much). The only complant I have with the HD33 is the black level in 2D the others are marginaly better. 3D is no problem and I use a ND filter on 2D to darken the blacks.
attichometheater likes this.
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is online now
post #3 of 3 Old 12-17-2012, 03:42 AM - Thread Starter
Got the same thing unless Im doning something wrong.Here is a link http://www.projectorcentral.com/Optoma-HD8600-projection-calculator-pro.htm
