Bulb Replacement Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 12-13-2012, 01:51 PM - Thread Starter
golffnutt's Avatar
Quoted: 140 Post(s)
Liked: 31
Hi Guys & Happy Holidays,
I'm going to be buying a new lamp for my Mitssubishi HC 3800 (same bulb as hc 4000) soon. Just wondering, since it is considerably cheaper to buy just the bulb versul bulb with housing, is it very difficult to remove and install the bulb fron and into my existing housing. Of course I only want to buy the original Osram lamp. Anyone done just a lamp replacement versus lamp & housing in one replacement? Please let me know what you think? Thank you so much.
Thank you. Golffnutt "GO DAWGS" !!!!!!!!!!!!!! Panasonic PT-AE 8000U Projector with 10' Screen // Samsung 65" 4K TV UN65KS9500F // Denon X6200W Receiver // Oppo 203 4K Player // Pioneer Elite BDP-51FD Blu-Ray Player (Great CD Player and Excellent Blu-Ray Player) // All PSB Speakers in my 9.2 speaker setup with 2ea. M&K 12" Subs // Panamax Surge Protection // 35' Bluerigger Cable (18gbps band width, 60 frame rate, and 4:4:4 capable) and 3 ea Monoprice 6' Premium Certified Cables
golffnutt is offline
post #2 of 4 Old 12-13-2012, 02:11 PM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Do a search.. but what you will find is "BUY THE OEM LAMP ASSEMBLY" and don't waste your money on anything else.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 4 Old 12-13-2012, 02:21 PM
nikonf5's Avatar
What you want is the original official genuine NIB replacement part made by Mitsubishi.
You want this because the lamp is made in Japan and Mitsi's are famous for their lamp longevity and you want the original.
This comes in only one form, with the housing.
So you actually dont have any other choice if you want an original replacement part.
nikonf5 is offline
post #4 of 4 Old 12-20-2012, 11:16 AM - Thread Starter
golffnutt's Avatar
Quoted: 140 Post(s)
Liked: 31
My thanks to both airscapes and nikonf5 for your suggestions.
