BenQ W1400 DLP full hd 3D Ready around 1300$ september 2013 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 40 Old 12-18-2012, 09:47 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
After the W1070 success story, here come the BenQ W1400. It's a 3D version of the W1200
http://www.audiovideohd.fr/tests/286-BenQ-W1200-0.html
I know that the W1400 will be available on the European Market on september 2013 for a price around 1199 euros
1080p
ISF
Frame Interpolation
3D ready with DLP LINK
Visit the new pjhc.fr forum here : http://www.projection-homecinema.fr/forum/
kraine is offline
post #2 of 40 Old 12-18-2012, 09:56 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Wow, BenQ is on fire. I wonder if it will have a DC3 chip (should have logically thinking) and would FI be the only difference between it and W1070.
Elix is offline
post #3 of 40 Old 12-19-2012, 04:46 AM
Bierryf's Avatar
Do you know if the focal length will be the same as the w1200 ?
It's the problem with the w1070 and my room ...
Bierryf is offline
post #4 of 40 Old 12-19-2012, 08:16 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
You have on the first topic all that I know for the moment, I'll update it as soon as I'll get new informations from BenQ.
kraine is offline
post #5 of 40 Old 12-19-2012, 12:55 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
We appreciate this early info. Thanks.
Elix is offline
post #6 of 40 Old 01-16-2013, 09:41 AM
SiggUA's Avatar
Liked: 25
SiggUA is offline
post #7 of 40 Old 01-16-2013, 09:51 AM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Are these different beasts? W1400 and W1500?
Elix is offline
post #8 of 40 Old 01-16-2013, 10:11 AM
SiggUA's Avatar
Liked: 25
My guess is that the W1400 will not offer Wireless HDMI.
SiggUA is offline
post #9 of 40 Old 01-29-2013, 12:56 PM
jcanaca's Avatar
hi all,
Found this video of the Benq W1500 ...same as the W1400 but with wireless hdmi...looks good
http://www.youtube.com/watch?v=yFIoGPij29Y
here is another...fast forward to 2:34 to see it in action
http://www.youtube.com/watch?v=4wQYnjEJ5RY
Highlights:
Full HD 1920x1080 DLP
WHDI (Wireless HDMI)
2200 Lumens
Zoom 1,6:1
Throw Ratio: 1.07 - .1.71
Supports 3D for HDMI
2 HDMI 1.4
Lens Shift (Manual/Vertical 20%)
Frame interpolation (FI)
Fan noise: 33/28 db (Normal/Eco)
lamp life 3000/6000h (Smart Eco)
speakers 2x10 Watt
jcanaca is offline
post #10 of 40 Old 01-29-2013, 01:04 PM
jcanaca's Avatar
Here is another view of the W1500 in white
http://recplay.pl/index.php?n=492&benq-w1500
the site states the w1500 can convert 2D images to 3D.
jcanaca is offline
post #11 of 40 Old 01-29-2013, 02:59 PM
blee0120's Avatar
Quoted: 429 Post(s)
Liked: 227
Looks like a better fit for me than the W1070. Now I need to see if the W7000 gets an upgrade
blee0120 is online now
post #12 of 40 Old 02-08-2013, 08:22 PM
yyy484's Avatar
Availability of the frame interpolation (smooth motion in fast scenes)
2 times more powerful built-in speakers
Big zoom and vertical lens shift
Presence in the model W1500 Wireless HDMI
Most importantly - the ability to display 3D with frequency 144Gts
The latter function is known, so far, only in professional theatrical projectors. It completely eliminates the single-frame flicker, and for films made with the same high frequency, ideally reproduces smooth movement even in fast scenes.
Projectors positioned as a budget, but from a technical point of view for the full "top-end" they lack only the functions simulated contrast, ie dynamic aperture of the lamp for dark scenes.
yyy484 is offline
post #13 of 40 Old 02-09-2013, 11:01 AM
dbox1080p's Avatar
What is 3D with frequency 144Gts? Is this similar to 144htz?
dbox1080p is offline
post #14 of 40 Old 02-09-2013, 11:35 AM
yyy484's Avatar
it just the same ( I believe ) but translated :
here
yyy484 is offline
post #15 of 40 Old 03-22-2013, 05:27 PM
tza88's Avatar
Has the release date changed on this? I saw somewhere that the W1500 was suppose to come out in March which obviously isnt happening. If its coming out soon then i may wait, otherwise i am going to go with the W1070
tza88 is offline
post #16 of 40 Old 03-23-2013, 02:10 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
W1500 is still arriving in April 2013 and W1400 is planned for Spetember 2013.
kraine is offline
post #17 of 40 Old 03-25-2013, 06:35 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
post #18 of 40 Old 03-26-2013, 03:03 PM
hockeyrama's Avatar
my main question concerning these projectors is contrast.
http://www.cinetson.org/phpBB3/download/file.php?id=24147&sid=854aff00be5a243fa09d7b6365da4586&mode=view
has the specs and the contrast of the w7000 is 5 times the w1070 or w1500. Just wondering if the picture is that much better. On a price comparison the W7000 will cost about the same amount as a w1500 when it comes out. If you don't need the wifi then which is the better one to grab?
The w1400 would be the best direct comparison to the w7000 as both do not have wif (1400 is the 1500 with no wifi)i. Just wondering if there is anyone who has a good idea about the difference in the picture quality between the w7000 and the w1070 as if the w1500 is a similar picture then we could start to decide if it worth waiting for the w1500 or buy the w7000. I do like the extra throw distance for me so I would be more for the w1400 or w1500 then w1070 so just curious as to which might be better for picture w7000 and w1400/w1500.
hockeyrama is offline
post #19 of 40 Old 03-27-2013, 12:35 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
I have seen both and I prefer the W1500 picture, native contrast is better on the new one (almost 4000:1 at D65).
kraine is offline
post #20 of 40 Old 03-27-2013, 06:19 AM
tigerfan33's Avatar
Quoted: 350 Post(s)
Liked: 168
I thought the 1500 and 1400 have the same lens off set as the 1070 and not the 7000??
Hope I was wrong as I would really like to have either 1500 or 1400 shelf mounted for a HP screen.
tigerfan33 is offline
post #21 of 40 Old 03-27-2013, 08:06 AM
Ron Jones's Avatar
Quoted: 899 Post(s)
Liked: 895
Any info on the lens shift and offset for the W1400/W15000? Are they the same as the W1070?
Ron Jones
Blog + Reviews + Articles: projectorreviews.com
Ron Jones is online now
post #22 of 40 Old 04-05-2013, 10:17 AM
Jimass's Avatar
Did i see that this model will support PIP (picture in picture)?
Jimass is offline
post #23 of 40 Old 04-05-2013, 11:04 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Yes it's exactly the same as this one without the WHDMI
http://www.avsforum.com/t/1465055/benq-w1500-full-hd-3d-ready-dlp-projector-whdmi
kraine is offline
post #24 of 40 Old 04-05-2013, 11:07 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
Both lens-shift on W1500 and W1070 as a very small vertical range, maybe a little bit more for the W1500 but tinny.
kraine is offline
post #25 of 40 Old 04-05-2013, 12:34 PM
Jimass's Avatar
So are we still expecting this in September as presumed or is this model going to be made available sooner. BTW which will come out earlier w1500 or w1400?
Thanks again.
Jimass is offline
post #26 of 40 Old 04-05-2013, 04:21 PM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
As I already say BenQ W1500 end April/beginning of May in Europe and the W1400 only at september 2013.
kraine is offline
post #27 of 40 Old 06-18-2013, 06:19 AM - Thread Starter
kraine's Avatar
Quoted: 200 Post(s)
Liked: 281
kraine is offline
post #28 of 40 Old 10-28-2013, 03:32 PM
thegarr's Avatar
has anyone heard anything further on the W1400? I'm hoping to purchase a projector around Christmas time and have a $1500 budget i was hoping we would have heard something about the w1400 by then.
thegarr is offline
post #29 of 40 Old 10-29-2013, 10:03 AM
RTK
RTK's Avatar
Quoted: 115 Post(s)
I'm also interested in the W1400 but I haven't seen anything about it being released other than it being listed on the BenQ global website. At time I write this post, the W1400 is not shown on BenQ US website so not sure if this means it won't be available here.
Rick
RTK is offline
post #30 of 40 Old 10-29-2013, 10:27 AM
RTK
RTK's Avatar
Quoted: 115 Post(s)
FWIW, I just called BenQ and was informed the W1400 was not scheduled to be released here in the US and there was no roadmap for the W1300 release here either.
Rick
RTK is offline
Benq
