lg pa70g settings can someone post there custom settings for best picture - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 12-22-2012, 09:41 AM - Thread Starter
colts19's Avatar
Looking for a starting point for custom setting. Just looking for a better setting for color (skin tones) and a little better picture in dark scenes. So if some of you could post the settings you use for watching movies It would really help. Thanks in advance..
colts19 is offline
post #2 of 20 Old 12-22-2012, 11:14 AM
Honzik1's Avatar
Quoted: 17 Post(s)
I use Expert1 mode:
Constrast 86,
Color: 48,
H-contrast: 40,
V-contrast 40,
Brightness: 62
Honzik1 is offline
post #3 of 20 Old 12-22-2012, 12:29 PM
Amber Ale's Avatar
Amber Ale is offline
post #4 of 20 Old 12-22-2012, 12:33 PM - Thread Starter
colts19's Avatar
Originally Posted by Honzik1 View Post
I use Expert1 mode:
Constrast 86,
Color: 48,
H-contrast: 40,
V-contrast 40,
Brightness: 62
Thanks I will try those.
colts19 is offline
post #5 of 20 Old 12-22-2012, 05:45 PM
rgtaa's Avatar
There are a lot of things to take into consideration. The room you are in, how big a screen, they type of screen, and there might be slight differences in each unit.
But , this is a great thread, because we can get ball park settings.
I've mentioned it before, in our regular PA70G thread, do the "picture wizard II' setup stuff, then place a hdtv next to 70G and watch the same recorded tv/movie at exact same time, and adjust settings on PJ until it's as good as the hdtv. I did that, and it looked amazing. If you don't have that reference hdtv screen, hard to tell how it's suppose to look, and the camera work in the movie might not look good, so having both set side by side, you can see , "oh, the hdtv picture on that scene looks like crap, so of course it will look like crap on the PJ". smile.gif
rgtaa is offline
post #6 of 20 Old 12-23-2012, 04:45 PM
daltrey's Avatar
I just posted my settings in the other LG thread but I think it would be easier to find in this one since there aren't 1000 posts to go thru. We should keep this thread for only settings. Here are mine:
Saved under Picture Mode: Expert 1
Contrast 85
Brightness 50
H Sharpness 80
V Sharpness 90
Color 40
Tint G25
Expert Control
Everything Off
Black Level High
Color Filter Off
Color Temperature Medium
Gamma 2.2
Method 2 Points
All contrast 0
All Color Management 0
daltrey is offline
post #7 of 20 Old 12-23-2012, 07:27 PM - Thread Starter
colts19's Avatar
Contrast 85
Brightness 50
H Sharpness 80
V Sharpness 90
Color 40
Tint G25
Expert Control
Everything Off
Black Level High
Color Filter Off
Gamma 2.2
Method 2 Points
All contrast 0
Posted this in the other thread also. Used your settings only thing I changed was the tint to G15. It looks great, thanks for posting these.smile.gifsmile.gif
colts19 is offline
post #8 of 20 Old 12-23-2012, 08:29 PM
yyy484's Avatar
for my 92" light silver gray DIY screen ( games - movies - browsing )
I used this setting :
Contrast 80
Brightness 50
H Sharpness 70
V Sharpness 100
Color 45
Tint 0
Expert Control
Everything Off
Black Level High
Color Filter Off
Color Temperature cool
Gamma 2.2
Method 2 Points
Red contrast -40
Green contrast -40
Blue contrast -20
more or less its your desire and room setting with screen shade and size wink.gif
yyy484 is offline
post #9 of 20 Old 12-24-2012, 02:49 AM
yyy484's Avatar
you can set a game 1080p
My setting was : ( Expert Control ) + above setting tongue.gif
Dynamic Contrast - Off
Color Gamut - EBU
Edge Enhancer - High
Dont forget ( Apply to all Inputs ) after your desire setting is done biggrin.gif
yyy484 is offline
post #10 of 20 Old 12-24-2012, 03:01 AM
yyy484's Avatar
One last thing my application done with AMD HD6950 +2GB ( GPU )
and in that part i have played little with Display color ( Digital Flat-Panel )
Saturation - 140
Brightness - 5
Contrast - 105
what i mean to say whats suit me does not suits other with different environments and applications smile.gif
yyy484 is offline
post #11 of 20 Old 12-24-2012, 04:26 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
I'll be doing a full pro-level calibration on my unit in the near future and if it calibrates out well (depends on just how functional the CMS is) I'll be happy to share the full calibration that includes the grey scale and CMS.
Please do keep in mind however that sharing settings like this is a crapshoot due to so many variables (tolerances, room, screen) and thus using perfect settings from one unit is not likely to be perfect on another. wink.gif
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #12 of 20 Old 12-25-2012, 01:56 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Merry Christmas!
Spent some calibration time on the PA70G and on my unit Green is not correctable and is a good bit away from being accurate at full power (regardless of presets & settings while using Expert mode).
It appears this is how they are getting the extra lumen's out of this model, by boosting green.
Cyan is a bit off as well but the rest of the primaries and secondaries fall mostly into place.
The 2.2 Gamma preset is fairly accurate across the scale and greyscale can come out great with the 10 point. Warm color temp is close to 6500K (my unit = 6496K post cal).
That's all I have time for at the moment but wanted to share some findings, happy holidays.
Jason
__________
post #13 of 20 Old 12-25-2012, 08:46 PM
yyy484's Avatar
IMO nothing left to dig about this projector in this forum ( focusing issue, color setting, ...etc )
All we can do wait next year and hope for 1080p good color no focusing issues with affordable price ( again your wallet should spit the gut ) and so on tongue.gif
at the end with the money we throw we got a good PJ with all faults on it biggrin.gif
CHEERS
yyy484 is offline
post #14 of 20 Old 12-28-2012, 01:03 PM - Thread Starter
colts19's Avatar
bump
colts19 is offline
post #15 of 20 Old 12-29-2012, 04:01 AM
bony's Avatar
Projected on the wall.The wall is modified gypsum plaster.Painted standard white.The projector is away from the wall about 4 meters .The ceiling and the other lateral walls are green .
My color settings
Energy Saving :Medium
Picture Mode :Expert2
-Contrast 93
-Brightness 63
-H Sharpness 79
-V Sharpness 79
-Color 58
-Tint G2
Expert Control:
-Dybamic Contrast Off
-Noise Reduction Off
-Digital Noise Reduction Off
-Black Level Low
-Real Cinema On
-Color Gamut Standart
-Edge Enhancer Off
-Color Filter Off
-White Peaking 10
-Color temperature Cool
-Gamma 2.2
-Method 2 Points
-Red Contrast -2
-Green Contrast -2
-Blue Contrast -2
-Red Brightness -2
-Green Brightness -2
-Blue Brightness -2
Color Management System
-Red Color -2
-Red Tint -2
-Green Color -2
-Green Tint -2
-Blue Color 2
-Blue Tint 2
-Yellow Color -2
-Yellow Tint -2
-Cyan Color 2
-Cyan Tint 2
-Magenta Color -2
-magenta Tint -2
Shot phone .. Desperado 1080p .
bony is offline
post #16 of 20 Old 12-29-2012, 12:46 PM
HTCrazy's Avatar
Is anyone using meters or is this all by eye?
HTCrazy is offline
post #17 of 20 Old 12-30-2012, 04:46 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
I am using an i1 Pro spectro & i1 Display Pro colorimeter combo with CalMan but just moved on to my third PA70G and have not calibrated it as of yet.
Jason
post #18 of 20 Old 12-30-2012, 05:19 AM
rgtaa's Avatar
Jason
You bought 3 PA70G's and all are in focus. Or you returned 2 of them and this is your 3rd one. Figured I would ask. smile.gif
If you have 3 of them, are you doing a special setup?
rgtaa is offline
post #19 of 20 Old 12-30-2012, 05:31 AM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Jason
post #20 of 20 Old 11-24-2015, 04:59 PM
raymate's Avatar
I know this is a very old thread, would the setting translate well into a new LG?
Just ordered a PH300 and want to get some starting points
AVC-A1SE with mission speakers and REL sub
AVR-2113CI with Polk TL350s and Polk sub
raymate is offline
