Epson 5020UB Owners Thread... - Page 44 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #1291 of 1509 Old 06-26-2014, 09:27 AM
ashyt16's Avatar
Quoted: 36 Post(s)
Liked: 27
Originally Posted by kriktsemaj99 View Post
When trying the panel alignment, make sure you only use whole pixel shifts of the entire panel (that should avoid introducing any extra artifacts). To get a whole pixel shift make sure you only move the corners, and move all 4 corners of a given panel by the same amount which is a multiple of 8 steps (8 steps equals 1 pixel IIRC).
This pixel shifting in 8 steps makes no difference in the real world. In fact in my tests it can make the image look worse. I have spent many many hours on this testing this out and comparing. Also how can you light up an 1/8th of a pixel? A pixel is either on or off.
If we are referring to a matrix block of pixels of 8x8 then fine, but that is not one pixel.
To me the problem looks more like an out of line lens system. I've seen it before with lenses that have been incorrectly columised.
ashyt16 is offline
post #1292 of 1509 Old 06-26-2014, 09:56 AM
kriktsemaj99's Avatar
Quoted: 591 Post(s)
Liked: 328
His case might be an optical problem, but the general advice about panel alignment still holds. Moving 1/8 pixel (1 step) will cause resampling and you'll get double-pixel wide lines. The cure can be worse than the disease, so I would stick to whole pixel shifts (8 steps). But you have to make the same shift on all four corners otherwise you're still resampling, so don't judge the result until all four corners have been moved.
I've played with the alignment on my 5030 (same system as the 5020) and it's clear that doing a global shift of one colour by a whole pixel doesn't cause any extra artifacts.
kriktsemaj99 is offline
post #1293 of 1509 Old 06-27-2014, 09:29 AM
pkriengsiri's Avatar
Thanks for the suggestions regarding my possible alignment issue. After talking with a tech at Visual Apex as well as one at Epson, I'm just getting a replacement projector sent to me. Crossing my fingers that this one is better.
pkriengsiri is offline
post #1294 of 1509 Old 06-29-2014, 10:54 PM
DTI
DTI's Avatar
Quoted: 20 Post(s)
try this in the LCD alignment on the remote press the RGBCMY and turn the green right down, all 3 Hue Saturation & Brightness now on the alignment select color red first and then on the pattern color R/G now that the green is not so bright you can really see how much to move the red and do the blue with B/G don't forget to default the green back see if this helps
DTI is offline
post #1295 of 1509 Old 07-01-2014, 06:43 PM
Got my replacement projector from Epson today and... WOW what a difference! New one is as sharp as a tack. Blue alignment was a little off out of the box, but that was easily fixed via tips others have provided in this thread.
One other thing I noticed with the defective unit was that there was a very faint dimming that would occur occasionally. The brightness seemed to dim ever so slightly (for a fraction of a second) and the color balance would go a little out of whack as well. No such problems that I can tell with the new one.
Thanks to everyone for their help and suggestions. Very happy 5020UBE owner here!
post #1296 of 1509 Old 07-18-2014, 04:54 AM
Liked: 1
New 5020UB r , Convergence & Focus
Hey guys,
I think this may be my first post but I think it is important to help other news owners with set up and or help others in jumping in on a refurb unit or even the 5030
I had spent time centering & focusing my projector and still felt it was out of focus in some areas more then others.
So I spent some time aligning the LCDs via the control panel and was getting a better picture, but still felt it was not tack sharp and was seriously considering sening it back or trading it out.
The problem I was noticing during convergence was, the 3 corners looked fuzzy and not as sharp as the 4th.
In thinking about it I though well maybe the lens is just not perfect or LCDs are not on plane and this is something I may have to live with, but then thinking a little more I decided to adjust, ****, and or turn the unit just a little to try to bring those corners into focus. Well that was it!! It turns out just a hair of adjustment to the whole unit and that put the whole picture in focus and aligning the LCDs if needed is then an easy process too!
Now the picture looks great in all aspects and the buyers remorse gone.
I guess what it comes down to is the face of the screen and the face of the projector need to be on the same "plane" because the focal focus range is so precise. from there lens shift should not make a difference.
On another note, there is some fan noise but I don't find it unacceptable or bothersome. When watching a movie you are unlikely to notice. I have been sitting right next to it for testing and it's just fine. It can run warm though so in a small room with no A/C or venting it may warm up the room.
vipergfx is offline
post #1297 of 1509 Old 07-21-2014, 12:52 PM
Kadath's Avatar
Quoted: 144 Post(s)
Liked: 130
I watched Snowpiercer via AppleTV this weekend on the 5020 projected onto 120". Was damn impressed at how well it held up, I'd say 90% of the way there to Blu quality and guests viewing it wouldn't have known it was a stream unless told. First time I had ever used the ATV for a new film, thumbs up and of course the 5020 was the workhorse here, love it!
Buncha savages in this town....
Sam Posten
Kadath is offline
post #1298 of 1509 Old 07-21-2014, 05:55 PM
Liked: 1
Just was checking out the 5020s 3D function via avatar 3D and I have to say wow. What a way to watch a movie.
I did not think I would care about the 3d function nor was looking forward to it. The 3d movies I have seen in the past in theaters were not that great, but after watching this level of 3D, I have to say it is really impressive and really adds so much to the experience and depth. So much so, it would be hard to watch the same movie in 2D. From the looks of this level of tech I would say 3D is not a fad but is here to stay and will become the norm years down the pipeline as the tech improves even more.
old corps likes this.
vipergfx is offline
post #1299 of 1509 Old 07-24-2014, 08:07 PM
JewDaddy's Avatar
Quoted: 58 Post(s)
Liked: 41
Hey guys. I posted this in the 5030 forums but though I could also get some help from this thread as well.
I've been wondering for some time now if my Epson 5030 projector would benefit from doing a panel alignment. I've attached a couple pics to get some opinions. Also, I've went back and read the steps posted on how to perform a panel alignment and it doesn't really make sense. Can someone explain exactly how that works? Thanks for the help
JewDaddy is offline
post #1300 of 1509 Old 07-24-2014, 11:25 PM
bigly's Avatar
Your pre-alignment images look better than my post-alignment.
I would be very happy with that natural alignment if i were you and wouldn't mess with it.
(None of your colours are off enough for alignment to benefit you IMO)
bigly is offline
post #1301 of 1509 Old 07-25-2014, 04:47 AM
Quoted: 66 Post(s)
Hi Guys I am thinking about getting a 5020 bstock from Projector People. My Yamaha receiver is non 3d but is a great receiver. I am keeping it since it cost $1500. I have a BR player that supports 3d. How do you all hook up 3d to your 5020 when you cant use your receiver to pass the HDMI though. Thanks
hotpepper007 is offline
post #1302 of 1509 Old 07-25-2014, 08:07 AM
Mr.G's Avatar
Quoted: 477 Post(s)
Liked: 247
Assuming your Yamaha receiver is HDMI capable you will need an amplified splitter or mirroring. The HDMI output from the Blu-ray player goes to the splitter which then sends one HDMI signal to the projector and the other HDMI cable into the receiver for sound. The splitter should be 3D capable and HDCP compliant. You will find these products at Monoprice or Sewell.
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #1303 of 1509 Old 07-25-2014, 09:16 AM
JewDaddy's Avatar
Quoted: 58 Post(s)
Liked: 41
Really?? I'm kind of shocked to hear you say that because you can clearly see the blue and green lines covering most of the white line. Ideally, what is it supposed to look like?
JewDaddy is offline
post #1304 of 1509 Old 07-25-2014, 09:57 AM
Quoted: 66 Post(s)
Thanks Mrg' I found the Panasonic BDT 460 player has dual HDMI outputs. I need a 3d BD player anyway since my other one is not 3d. So I kill two birds with one stone. Plus the 460 gets great reviews. Thanks
post #1305 of 1509 Old 07-26-2014, 12:42 AM
bigly's Avatar
Yes when I open your pics full size and zoom in, I can see a glow of blue slightly above the white and a glow of green slightly below.
But the lines are not separated by an entire pixel and I think alignment is only useful if an entire pixel shift is required.
Have a look at my before and after pics (post 1191, pg40). At a similar distance from screen as yours, my before pics show distinct separate colour lines.
After the 1 pixel shift of red and blue, I have similar glow around the edges as you.
But because that remaining miss alignment is down to a fraction of a pixel, its the best achievable with the alignment digital scaling feature.
Id challenge you cant see those separate glows after a few feet away from your screen.
bigly is offline
post #1306 of 1509 Old 08-23-2014, 01:25 PM
DTI
DTI's Avatar
Quoted: 20 Post(s)
Curios on your guys take would you be happy receiving this as a replacement and if it needed
panel alignment adjustments right away.. did you need to adjust panels soon as you got yours here some pics including letter
ID:	225937   Click image for larger version
Name:	epson 3 (2).jpg
ID:	225945   Click image for larger version
Name:	epson 3 (1).jpg
DTI is offline
post #1307 of 1509 Old 08-23-2014, 02:23 PM
DTI
DTI's Avatar
Quoted: 20 Post(s)
Is this quality with the panels plus the focus its not as good.
with this unit that I just got notice when you do the panel alignment and you turn on
Frame Interpolation it throws the alignment out especially the red ,on my old unit it stays the same
DTI is offline
post #1308 of 1509 Old 08-23-2014, 11:53 PM
bigly's Avatar
I had to adjust mine from new.
I can see from your pics that the green panel is 2 pixels to the left of the red and blue.
If I were you I would apply an EQUAL -16 adjustment to the left parameter for ALL four corners for BOTH the blue and red panels.
Then I would assess it again.
I have a 2 panel 2 pixel adjustment on mine and it holds fine with FI switched on.
BTW, 2 rows of pixels out of alignment is out of Epsons tolerance parameters so you shouldn't have any argument if you decide to reject it.
(But after alignment I'm happy with mine for now.)
bigly is offline
post #1309 of 1509 Old 09-01-2014, 08:42 AM
dbldown768's Avatar
Sorry, I dont mean to double post, but looks like I posted in the wrong thread. My 5020 projector has been working just fine since I have had it. That's said just recently when the projector starts up I will see some of the picture and a bunch of clicking sounds. The sounds are in rapid succession for like a second. I check and I have auto iris turned off at the moment. Any thoughts? Device isn't even a year old. If it is a warranty claim do they send you a new or used device? I only have 393 lamp hours.
Theater Build thread here
dbldown768 is offline
post #1310 of 1509 Old 09-01-2014, 11:01 AM
DTI
DTI's Avatar
Quoted: 20 Post(s)
Not to sure on what is making the clicking noise
but when you send yours in for repair you get someone else repaired project or so called repaired projector in which can be in a lot worse shape than the one you send in,
although comes with a new light bulb and hours of operation cleared because you sure wouldn't be happy sending yours in with 700hrs of operation and receiving one with 1800hrs on it with my experience in replacement its not good the first two that they sent boxes had some bad dents the boxes could have been dropped give Epson that.. but the last one what was checked by quality control box was perfect & projector had big problems. so if you got a good projector as in focus panel alignment picture is perfect
I would ask Epson if they could repair yours an send yours back instead of playing the hit and miss game.
DTI is offline
post #1311 of 1509 Old 09-02-2014, 11:04 AM
dbldown768's Avatar
Well i called epson after writing them an email. They suggested the clicking noise is a hardware failure - dont know if it is auto iris exactly. I have basically two choices, have them send me a refurbished unit or send my in for repair. I guess the third option is to drive the unit to a repair facility nearby. Im debating on why a product with under 400 lamp hours requires work in the first place. I dont know if i should be getting the refurbished or hope to get my unit fixed. I dont want to open a can of worms on what kind of of replacement product i might get. Does anyone have any feedback? Interesting the guy on the phone at epson can't give me an estimated time of life the product itself should work for. He sounded hopefully optimistic that it should work for 5 years. I should hope this thing works for that long, if not, i will never buy epson again.
post #1312 of 1509 Old 09-11-2014, 12:36 PM
Barrettmr's Avatar
Quoted: 103 Post(s)
Liked: 29
Personally I think I would just get a repair on my own PJ rather than a refurb but that's just me... each to his own :-) I would also say no one can guarantee how long a device like this will last without any breakdowns, that why we have warranties. From what I read there isn't a major issue with build of these PJ's, I haven't had any issues with mine and my friend has one for about the same time and hasn't had any issues. Nothing is perfect and yes I know there has been the alignment of the panels and Epson swapping out a number of units where customers are not 100% happy, but the fact they are willing to do that is good customer service as well....
Epson 5020UB - Falcon Screens AT 131"
Onkyo TX NR818 - Emotiva XPA-5 - Panamax M5300
Polk 265LS/255cLS L/C/R - 80F/X-LS & LSiM703 surrounds - Dual SVS PB2000 subs
OPPO BDP-103 - HTPC with MediaBrowser3
http://www.avsforum.com/forum/19-ded...-re-model.html
Barrettmr is offline
post #1313 of 1509 Old 09-11-2014, 03:34 PM
DTI
DTI's Avatar
Quoted: 20 Post(s)
I have to agree Epson customer care is top notch probably the best
but its the quality control that lacks that is why some of us are getting not
fully repaired units
DTI is offline
post #1314 of 1509 Old 09-23-2014, 09:17 AM
TH3_FRB's Avatar
Quoted: 135 Post(s)
Liked: 29
Consideting a refurbished 5020 to save some $ over a new 5030. Has there been any information about a potential firmware update similar to the what was recently announced for the 5030 and 6030?
dougc11 likes this.
TH3_FRB is offline
post #1315 of 1509 Old 09-24-2014, 11:59 AM
Quoted: 66 Post(s)
My 5020 refub from PP will be here today. Hopefully fedx will be carefull with it. I just took my 8350 down and ready to stick the 5020 in its place. Hopefully the 5020 works well and it will be a fun evening. Got the beer cold and made some popcorn. I just now have to figure out what BD to demo first. Getting a new projector does not happen very often and I still get excited. This will be my best one yet. I will using a 125in 2.35 screen 1.1 gain. Will post first impressions sometime in the moring. Also the new 5030 firmware does not work on the 5020. But I have a darbee so I will use that also. Thanks
post #1316 of 1509 Old 09-29-2014, 05:25 PM
drhankz's Avatar
Quoted: 71 Post(s)
Liked: 62
I posted this in the 5010 thread but owners here might find it interesting
Click on I Posted this in the 5010
drhankz is online now
post #1317 of 1509 Old 09-30-2014, 04:24 AM
ashyt16's Avatar
Quoted: 36 Post(s)
Liked: 27
Seems like you have the same problem I had. I have posted a fix in the 5010 thread.
ashyt16 is offline
post #1318 of 1509 Old 09-30-2014, 12:10 PM
garywade1978's Avatar
Quoted: 47 Post(s)
Liked: 24
Can you find the firmware on Epson's website? Mines coming Saturday and cant wait to fire this up...
garywade1978 is offline
post #1319 of 1509 Old 10-02-2014, 10:38 AM
TH3_FRB's Avatar
Quoted: 135 Post(s)
Liked: 29
I've decided to go with a refurbished 5020 and have a few questions.
1. What would you suggest as far as a screen goes for a room without ambient light control? I definitely want motorized and tab-tensioned. I'll be shooting 110" at 12ft. Are the Visual Apex screens any good? They have pretty reasonably priced packages.
2.Is there some sort of trigger lead I can run to my motorized screen to have it drop when the projector is powered up?
3. Is there a clean way to run HDMI and power to the connections for a ceiling mount? I'll be flush mounting at close as possible to the ceiling.
TH3_FRB is offline
post #1320 of 1509 Old 10-03-2014, 09:04 AM
WillyJ's Avatar
Quoted: 24 Post(s)
Liked: 84
I think you have to call them. I could not find any firmware updates on their website. I guess the old "if it ain't broke, don't fix it" rule applies here. I have sometimes updated firmware on components just for grins only to have issues later so unless you are having problems with your pj now, the latest Epson firmware probably isn't going to add any features or fix something that isn't broken. Just my 2 centavos.
WillyJ is offline
Samsung Ssg 4100gb 3d Active Glasses 2012 Model , Epson 5020ub Powerlite Home Cinema 3d Front Projector
taboola here
