Epson 5020UB Owners Thread... - Page 46 - AVS Forum | Home Theater Discussions And Reviews
 35Likes
post #1351 of 1584 Old 12-08-2014, 12:40 PM
groBschizer's Avatar
Quoted: 67 Post(s)
Quick question.
I recently changed my original lamp in my 5020 after 1600hrs. Replacing the lamp was no sweat. I've since put about 150hrs on the new lamp.
When I ran my calibration for Black levels and contrast (in THX mode), I found I had to crank the contrast down to -16!
After all was said and done, Brightness is set to +2 and Contrast to -16 and the picture looks great. The numbers shocked me, though.
I have a COMPLETELY dark room and an SI 115" ZeroEdge screen -2.4 gain. Oppo 103D-BD player into a Marantz AV7702 to the Epson. No processor modifications.
Anyone else have a similar experience?
Should I put a few more hours on the lamp?
Should I not worry and just enjoy the nice picture?
-Dave
groBschizer is offline
post #1352 of 1584 Old 12-28-2014, 10:22 PM
ezelkow1's Avatar
Anyone have any recommendations on where to get replacement lamps? I see alot of places making cheaper replacements, on amazon its hard to tell which is oem and which is not
So far I went through 3 5020's. My original started flickering and after contacting their support they sent me a replacement, this was only after a few months. Then the replacement had a completely distorted signal and output after a few days. Ive been using the final replacement for a little over a year now and it was just fine up until today when I started to see the flickering again. The bulb has ~1500 hrs on it so before I contact their support again (that is even if they let me since I think Im past the original warranty on my first one) I wanted to try a new bulb
Has anyone seen flickering caused by a bulb going out? Should I try anything else?
ezelkow1 is offline
post #1353 of 1584 Old 12-28-2014, 11:38 PM
harmil2's Avatar
You might try turning off the auto Iris. I have sometimes seen what I call flickering depending on what I am watching. When I turn off the iris it stops. Only certain scenes seem to trigger this. After awhile I will turn the iris back on and it is fine until the next time. Good luck.
harmil2 is offline
post #1354 of 1584 Old 12-28-2014, 11:44 PM
ezelkow1's Avatar
After reading up it appears its a common issue with all home theater projectors basically. Its because when you run in ECO modes the arcs in the bulbs can wear unevenly. I noticed that I do not see the flicker when running in normal mode. From all the threads on the issue I could find is that generally running in the non-eco mode on your projector for ~20hrs will re-wear the arc paths back to normal and the flicker should hopefully go away. So Ill try that for now
Not sure why epson never suggested that the first time i had the problem though
ezelkow1 is offline
post #1355 of 1584 Old 01-05-2015, 09:52 PM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
Do people still feel like this unit performs great in 3d? I watched some 3d when I first bought it and don't recall any issues.
However, I recently watched Godzilla, How to Train Your Dragon 2 and Guardians of the Galaxy all in 3d. In all 3 films I noticed a lot of crosstalk. Anyone else experiencing this with newer 3d movies?
Denon 4520CI
Emotiva LPA-1
Epson 5020ub::::110" Silver Ticket
PS4::::Toshiba HD-A35:::::::::Denon DBT 3313UDCI:::Darbee DVP 5000
Martin Logan Stage(c)::::ML Aerius I(l/r)::::ML Motion FX(s)::::ML Scripts(sb)
PSA XV15:::::PSA XV15se
wadec22 is offline
post #1356 of 1584 Old 01-05-2015, 10:46 PM
ezelkow1's Avatar
I think it just really depends on the movie. Last ones I watched were Lego and despicable me 2 and they looked perfect. However a while ago I noticed a bit of crosstalk in Jurassic park and avengers. It was never constant but noticeable at times. I'll have to try guardians and see if I see it here
ezelkow1 is offline
post #1357 of 1584 Old 01-06-2015, 12:54 AM
ashyt16's Avatar
Quoted: 37 Post(s)
Absolutely zero crosstalk in guardians of the galaxy on my 5010.
ashyt16 is offline
post #1358 of 1584 Old 01-06-2015, 06:22 AM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
forgot about the "3D Brightness" setting. Set that from Hi to Medium and it fixed crosstalk in HTTD2. I'll have to try it on GOTG and Godzilla. I think it should take care of it.
Denon 4520CI
Emotiva LPA-1
wadec22 is offline
post #1359 of 1584 Old 01-21-2015, 12:37 PM
mhariush's Avatar
Quoted: 18 Post(s)
Guys, I want to buy a burned out/broken BULB. IF anyone one has one, please PM me. Thanks.
mhariush is offline
post #1360 of 1584 Old 01-22-2015, 06:57 PM
DTI
DTI's Avatar
Quoted: 25 Post(s)
Going for the old send in the burnt bulb under warranty get one free
DTI is offline
post #1361 of 1584 Old 01-28-2015, 02:08 AM
xplorar's Avatar
Quoted: 37 Post(s)
Bingo! I thought I was the only one seeing this on my 5010. Glad to see that I am not alone.
xplorar is offline
post #1362 of 1584 Old 01-28-2015, 05:46 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
2 out of 3 of those films were filmed in 2D,
How to Train Your Dragon 2 says it uses Digital 3D
which is also not REAL 3D.
I suggest you refer to this website - HERE
drhankz is offline
post #1363 of 1584 Old 01-29-2015, 05:43 AM
xplorar's Avatar
Quoted: 37 Post(s)
I don't understand. What has crosstalk go to do with what type of 3D it is?
xplorar is offline
post #1364 of 1584 Old 01-29-2015, 08:43 AM
fatherom's Avatar
Quoted: 327 Post(s)
Liked: 177
It doesn't. Don't listen to him, he's wrong about most of what he says.
Theater 1: LG OLED55E6P 4K TV, Samsung UBD-K8500 UHD Blu-ray player, Oppo UDP-203, Dune HD Solo 4K
Theater 2: Epson 5020UB (won on AVSForum!) on Elite Sable 16:9 100", Oppo BDP-83 / 93 (ISO firmware) / 103D (CFW), Dune Base 3.0 / Smart units, Darblet, Sony MDR-DS7500 Wireless Surround Headphones & Onkyo TX-SR707
fatherom is offline
post #1365 of 1584 Old 02-17-2015, 07:54 AM
kutizoltan83's Avatar
Hi Guys,
Which is the best non-Epson 3d glasses which i can use this projector with?
I have Samsung SSG-P51002 IR glasses. Is there a better one?
thanks!
kutizoltan83 is offline
post #1366 of 1584 Old 02-17-2015, 08:01 AM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
Valuview RF. 34.99 on amazon and they work great.
Denon 4520CI
Emotiva LPA-1
wadec22 is offline
post #1367 of 1584 Old 02-18-2015, 06:55 AM
jdaddieo's Avatar
Quoted: 13 Post(s)
Liked: 25
agreed the Value View glasses are very comfortable and lighter than the Epson glasses. Didn't notice any drop off in visual quality either.
jdaddieo is offline
post #1368 of 1584 Old 02-25-2015, 07:26 PM
y2k02c5's Avatar
Quoted: 25 Post(s)
So the 5020 has been out for a little over 2 yrs now. How are you guys doing on bulb life? I'm at 1350hrs. Primarily use it in eco mode. Who has changed their bulb and how many hours did you have on it?
y2k02c5 is offline
post #1369 of 1584 Old 02-26-2015, 04:16 PM
DTI
DTI's Avatar
Quoted: 25 Post(s)
Haven't changed mine I guess that's because I am on my fifth projector on this one
have 470 hrs in normal mode
DIY dust box / hush box / ceiling light... http://imagizer.imageshack.us/v2/640...633/7qBblE.jpg
DTI is offline
post #1370 of 1584 Old 02-26-2015, 04:19 PM
wadec22's Avatar
Quoted: 148 Post(s)
Liked: 63
I'm at about 1400 hrs normal mode. Bulb going strong.
old corps likes this.
Denon 4520CI
Emotiva LPA-1
wadec22 is offline
post #1371 of 1584 Old 02-28-2015, 04:57 AM
DeSolate's Avatar
Had this flickering issue to my original bulb too after ~800hrs. Like people have mentioned, I had to run it in normal mode to eliminate the flicker then switch back to eco many times. I ended up just running it in normal It was real annoying. After ~2000hrs under normal mode it started flickering again usually under bright white high contrast scenes.
I figured the bulb was nearing the end so I bought a cheap replacement $45 bulb off ebay (under the seller electrifieddiscountersinc203) and it has been working great. No flickering on this bulb vs original with the same light output too using the X-Rite EODIS3 i1Display Pro to calibrate and test. I however have to say upon opening it, it was put together cheaply. The bulb was sitting angled about 20 degrees up in the housing when I got it so I had to take the housing apart to set the bulb straight before installing. But with that said it works great. I use my 5020ub around 10-18 hours everyday. It's almost on all the time. To add I think all these cheap replacement bulbs are probably the same too just from different sellers all over the net. Its got 2500hrs on it right now in full time normal mode and looks like it'll go to 3000hrs easy. I also bought another one from the same seller as a back up so if this one goes out I'll just throw that replacement in. Overall totally worth the $45 shipped I got the bulb for. I recommend them, and it calibrates just like factory.
DeSolate is offline
post #1372 of 1584 Old 03-16-2015, 06:10 PM
Brett Jason's Avatar
My 5020ub just died. Starts to turn on for about 3 seconds and then all of a sudden the fan stops and the lamp and power light flash red. It's out of warranty by a few months, but Epson immediately said they'll send a replacement unit. I was quite surprised, the agent didn't have me do any trouble shooting. Maybe it's happening a lot? It has very few hours on it as it's in a dedicated theater in basement that i unfortunately (for me) don't get down to use as much as I would like.
Brett Jason is offline
post #1373 of 1584 Old 03-16-2015, 06:55 PM
DTI
DTI's Avatar
Quoted: 25 Post(s)
sucks just a few months past warranty and it fails, its good that there going to replace it
I've got warranty to the end of April if mine fails and they don't replace it and its going to cost a arm & leg to fix. its going through there biggest window screw their quality control I have said this before if you have a good unit focus panel picture you might want to get them to fix yours just a thought
DTI is offline
post #1374 of 1584 Old 03-18-2015, 06:49 AM
WillyJ's Avatar
Quoted: 24 Post(s)
Liked: 84
That is excellent customer service. Good to know Epson stands behind its products.
WillyJ is offline
post #1375 of 1584 Old 03-24-2015, 09:01 PM
mak99's Avatar
Quoted: 27 Post(s)
Greetings, fellow owners - sorry to be so late to the 5020 party!
I recently upgraded my trusty 7500UB that I bought used just over two years ago, to an almost-new 5020UBe (~370 hrs) that was bought from a fellow local Forum member earlier this month. After comparing the two PJs side-by-side (well, "top-to-bottom" since the 7500 was still ceiling-mounted) with the same source material in my dedicated media room, it was an easy decision to buy the 5020 for the great price that it was graciously offered to me. I was also fortunate that he brought his calibration gear with him to perform a complete calibration in my room, and it was dialed in quite accurately.
For the few issues that others have discussed on this thread, my convergence did not seem to have any issues whatsoever. Nor have I seen any flickering/dimming lights that has been mentioned. I do run my lamp on Eco mode and do not use the Dynamic Iris, and I'm getting right at 14 fL off my 135", 1.1 gain Elite fixed frame screen. The PJ is almost directly above the main LP, but I have a simple, removable sheet metal hush box lined with 1" studio foam that eliminates most fan noise save for the quietest moments. I don't use the wireless HDMI feature as I already have two HDMI runs to the PJ, plus my gear is remotely located in an adjacent room so no line-of-sight is available.
For the handful of movies I've had time to watch so far with the calibrated settings, I have to say that I am nothing but impressed (and very happy) with the overall picture quality of the 5020. I thought the 7500 threw a great picture (which I still think it does quite well), but the 5020 has just taken me to the next level with its overall better performance. Details are a bit sharper, colors have a bit more "pop" (which might be due to the extra brightness), and the blacks are just a bit blacker. One big improvement I've noticed is the depth the picture now has on good transfers such as Tron Legacy and Skyfall. It really draws me into the movie more than before, which is something that I don't recall experiencing before...
So hopefully I won't have any issues with the 5020 and will only be posting here with general questions, or maybe even help answer another member's question. So for now, chalk me up as a very happy 5020 owner...
old corps and Modicen like this.
still one of my favorite bumper stickers of all time...
FREE TIBET! *
* with purchase of equal or lesser Tibet
mak99 is offline
post #1376 of 1584 Old 03-29-2015, 02:36 PM
fornold's Avatar
I have a 5020UB that today starting showing a pattern of pixels on the screen. Anyone know what this indicates?
I know this picture isn't very good, but it does give an indication of what it is doing. I'll try to get a better picture.
I should add it doesn't matter what the source is. It is always displayed.
Any help in understanding what is going one would be appreciated.
Dave Brown
Update: After trying everything else I could think of. I unplugged the projector for about 30 minutes and everything seems to be back to normal. Hopefully it stays that way.
fornold is offline
post #1377 of 1584 Old 04-04-2015, 07:34 PM
Unhappy
my replacement projector has been fine for a week, but tonight when i turned it on, i have 1 green vertical line running straight down the middle of the screen. Any ideas or is it back to the shop again?
post #1378 of 1584 Old 04-05-2015, 06:29 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
I am sure no one has some ideas you might
try OTHER THAN - BACK TO THE SHOP AGAIN.
I am also sure 99% of us are HAPPY USERS.
I am sorry you had the problem twice.
I do have one question for you?????????
What Source are you driving the projector with?
drhankz is offline
post #1379 of 1584 Old 04-05-2015, 09:12 AM
it happens with all sources (directv, bluray etc) BUT now if i turn it completely off and on again the line disappears. The problem is that I have to do this every time. I'm going to call the authorized repair shop on Monday to see what they suggest. Since it's the refurbished unit that i got, maybe it needs to be swapped out for another one.
post #1380 of 1584 Old 04-05-2015, 09:31 AM
drhankz's Avatar
Quoted: 77 Post(s)
Liked: 64
I was trying to think if a HDMI cable could cause that
but I highly doubt it. A green line seems like a display,
or in this case, a projector problem.
That fact that TWO units do it for you sounds suspicious.
Are there any POWER problems in your location?
Is anyone running some NOISY electrical devices?
My projector is 100% Isolated from the power grid.
drhankz is offline
Samsung Ssg 4100gb 3d Active Glasses 2012 Model , Epson 5020ub Powerlite Home Cinema 3d Front Projector
