Image "warping" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-02-2013, 09:18 AM - Thread Starter
nicklepots's Avatar
Hey all. I just installed an Epson 8350 and noticed something strange with the image. Whenever the camera pans from left to right, or right to left, the image warps in a way that looks like the camera is using a fish eye lens or something. When the image is still, it looks fine, but when there is left to right or right to left movement, it looks funky. Is this a calibration thing, or a bad projector thing?
nicklepots is offline
post #2 of 6 Old 01-02-2013, 10:48 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Sounds like you have the aspect ratio set to wide where the center of a 4:3 the image is left alone and the outer portions are stretched. Set it to Normal so the image is displayed with the aspect ratio it was recorded in.. 4:3 will have black bars on the left and right 16:9 will fill the screen
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 6 Old 01-02-2013, 12:50 PM - Thread Starter
nicklepots's Avatar
Thanks airscapes. I will try that and will check out a couple of different movies making sure to check both 'widescreen' and other formats.
post #4 of 6 Old 01-02-2013, 06:29 PM
42Plasmaman's Avatar
Quoted: 20 Post(s)
Liked: 37
What transport are you using?
Hdmi, component, composite
2016
42Plasmaman is offline
post #5 of 6 Old 01-02-2013, 07:48 PM
DarkVenture's Avatar
If your screen is not perfectly flat you can encounter this effect. That is to say, if there are any waves or curls it will look fine in a stationary image but warped during motion.
DarkVenture is offline
post #6 of 6 Old 01-03-2013, 09:11 AM - Thread Starter
nicklepots's Avatar
Hey all. I changed the aspect ratio setting to match the DVD format and that fixed it. Looks good now. Thanks for all the help.
