Ceiling Mount for Sony Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 01-02-2013, 11:34 AM - Thread Starter
cdiddy4224's Avatar
Im a little confused. I want to mount my projector to the ceiling. I am currently looking at the Chief RPA020. I was going to "flush" mount this projector as close to the ceiling as possible. If I don't use an adjustable extension column do I need another plate that mounts to the celing? Chief's website isnt 100% clear, at least not to me.
I do understand that if I want to drop the projector down a couple inches I need a Joist celing mount, extension arm and the mount for the projector.
cdiddy4224 is offline
post #2 of 2 Old 01-02-2013, 03:54 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
The RPA series is designed to connect to some sort of 1 1/2" threaded column. Your best hope for minimal additional height added to the mounting hardware would be one of Chief's ceiling mounting plates and a 1 1/2" threaded nipple from your local hardware store. Most of the nipple would screw into the ceiling plate and RPA mount, only adding another .5-.75" besides the ceiling mounting plate thickness.
Just keep in mind you need to be able to reach the set screws for the 3 axis adjustments, might require an extra long phillips screwdriver.
underachiever extraordinaire
weaselfest is offline
