mitsubishi hc 7900dw - AVS Forum | Home Theater Discussions And Reviews
post #1 of 14 Old 01-04-2013, 06:49 PM - Thread Starter
orlando22's Avatar
just bought the projector from newegg.They had such a great price i had to pull the trigger.I am upgrading from hc4000 to a 84in and 103in 2:35:1 screens.the hc 4000 has been such a great projector that i hate to get rid of but i wanted 3d and hopefully better blacks for that great pop a dlp gives.
orlando22 is offline
post #2 of 14 Old 01-04-2013, 09:19 PM
Elix's Avatar
Quoted: 215 Post(s)
Liked: 100
Waiting for your input on HC7900!
Elix is offline
post #3 of 14 Old 01-05-2013, 05:43 PM
nezz621's Avatar
Also waiting for a review, most likely I will be getting the Hc 7900dw but there are a few other good options in this price range. Im coming from a HC3800 so i'm super excited to hear the differennces between the Hc 4000 and the HC 7900
nezz621 is offline
post #4 of 14 Old 01-07-2013, 10:39 AM
Chris Matney's Avatar
Quoted: 13 Post(s)
I'd be very interested in the observation... coming from a plasma I'd rank sharpness and black levels most important and in that order... I'm considering my two options to be this 7900DW or the Sonly 30es due to their 3D capabilities and price range...
Chris Matney is offline
post #5 of 14 Old 01-07-2013, 02:41 PM - Thread Starter
orlando22's Avatar
still waiting for delivery.I just ordered 3d emitter directly from mits because know one carries it yet.
post #6 of 14 Old 01-10-2013, 10:11 PM
Quoted: 13 Post(s)
Waiting with anticipation lol! I've got my eye in this guy or the optoma hd8300... Photos coming?
post #7 of 14 Old 01-11-2013, 04:36 PM - Thread Starter
orlando22's Avatar
Just a little update on the projector.After having the mits 4000u for 1 year i was hesitant on upgrading .I thought of try all new lcd or lycos projector but was worried on convergence and sharpness.Well worry no more because this projector is very sharp and easier to setup due to vertical lense shift.I thought white was wrong for color of the projector but it turns out i like it more because it blends well with ceiling.I need to fiddle with controls and hook up 3d emitter this weekend and give a better overview but so far playing with it for one day it definately way and beyond the hc4000u.if theres anything you want me to check out just ask
post #8 of 14 Old 01-11-2013, 07:40 PM
Quoted: 13 Post(s)
Thanks for the update, I'd be very interested in your opinion one you configure and play with it a bit in both 2D & 3D... I'm also looking at LCD and lycos but worried about sharpness. From what I'm told, it's really not the same advantage anymore due to filters and software enhancements.... But Art and others still say "DLP has that something else, a pop to the picture"...
post #9 of 14 Old 01-11-2013, 07:46 PM
Quoted: 13 Post(s)
Thanks for the update, I'd be very interested in your opinion one you configure and play with it a bit in both 2D & 3D... I'm also looking at LCD and lycos but worried about sharpness. From what I'm told, it's really not the same advantage anymore due to filters and software enhancements.... But Art still says "you get that DLP look, which I've always tried to define an image that offers particularly rich darker colors, that pop, but aren't over the top... (that at least should be a distinguishing feature of a good DLP projector)."
post #10 of 14 Old 01-11-2013, 09:27 PM - Thread Starter
orlando22's Avatar
I got to play around with 3d.I am using xpand 104 glasses.I viewed about a half hour so far and there is no ghosting or cross talk its just a smooth 3d picture.The 2d conversion works great.I tried letting oppo bluray player doing conversion and i the mits did alot better job of making you believe that its 3d.I am running 84in 1:78:1 and a 103 2:35:1 screens and its plenty bright.
post #11 of 14 Old 01-11-2013, 11:19 PM
Quoted: 13 Post(s)
Glad to hear you like it... How's the 2D &3D image compare in sharpness and black level?
post #12 of 14 Old 06-28-2013, 08:36 PM
Speedthrill04's Avatar
Orlando,
Tell me about your experience with Mit 7900dw. I bought one from Projector People recently. Are you seeing any issues with non-1080p signals. Im running HDMI from a Direct TV HD box (HR20) and am noticing issues with motion. I came from a HC3800 that did not experience those issues.
Also, do you have access to the advanced menu: cw speed, frame rate conversion, or FRC level on non-1080 p signals? Im noticing a lot of issue with this lately.
Any help would be appreciated.
Speedthrill04 is offline
post #13 of 14 Old 09-04-2014, 05:45 PM
Liked: 0
Originally Posted by Speedthrill04 View Post
Orlando,
Hi. Did you ever figure out a solution to this?
inimitable_g is offline
post #14 of 14 Old 09-04-2014, 07:05 PM
I returned it and bought the Panasonic AE8000U. ....and haven't regretted it since!!
Mitsubishi Hc7900dw Home Theater 3d Projector
