Need advise on how can i easily install or remove ND filter on projector. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-09-2013, 10:54 PM - Thread Starter
squall12's Avatar
Hi guy,
i want to know what can i do so i can easily install or remove ND filter from projector as currently i am using blu tak to stick it to my acer projector and i find it troublesome to remove when i want to view 3d movie on my high power screen as u all know i need all the brightness i have for 3d viewing.
squall12 is offline
post #2 of 4 Old 01-10-2013, 05:57 AM
man4mopar's Avatar
Can you get a adapter ring that it screws into and attach the ring to projector, then just screw the ND filter on or off as needed?
man4mopar is offline
post #3 of 4 Old 01-10-2013, 06:01 PM - Thread Starter
squall12's Avatar
where can i find such adapter ring for the acer projector and i am using nd2 hoya 77mm filter. Thanks
Remarks: I am using acer h9500bd projector.
squall12 is offline
post #4 of 4 Old 01-11-2013, 07:18 AM
man4mopar's Avatar
A specific one for the projector I do not know. Not even sure if it has threads but with some handy work one of these may be fitted to work. http://www.amazon.com/s/ref=nb_sb_noss_2?url=search-alias%3Delectronics&field-keywords=77mm+ring
