Mounting idea pics - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-09-2013, 09:59 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 206 Post(s)
Liked: 126
Going to be mounting my projector from my drop tile ceiling. Anybody have pics of how you mounted yours?
It may not be your job, but perhaps it's your opportunity.
MPJ's theater build: http://www.avsforum.com/forum/19-ded...ter-build.html
mpjmeyer is online now
post #2 of 3 Old 01-09-2013, 10:55 PM
Jim McC's Avatar
Quoted: 193 Post(s)
Liked: 69
I don't have pics, but I can explain it pretty well I think. I used a DIY mount. Do you already have a mount?
1) Measure to find where mount will go.
2) At that point, screw a 2X6 between joists for your mount to screw into(if there is not joist there).
3) You will have to cut a hole in tile, where the pipe from mount goes thru. ZERO weight is supported by tile.
Jim McC is offline
post #3 of 3 Old 01-10-2013, 07:15 AM
tburns6's Avatar
I just remounted mine (new bigger screen on its way, and got tired of it moving then kids play trampoline on the kitchen floor above).
I still have to cut my tile to fit around the post and clean up the cabling.
tburns6 is offline
