Is ir Possible to o shoot a Ceiling Mounted Projector projection Up ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 01-11-2013, 05:58 PM - Thread Starter
Durvelle27's Avatar
I have a Acer H5360 and when i ceiling mounted the projection was at the bottom of the wall and i want to know if its possible to flip it around and shoot it up so it can be in the center of the wall ? Thx
Durvelle27 is offline
post #2 of 9 Old 01-11-2013, 06:17 PM - Thread Starter
Durvelle27's Avatar
sorry about the typo's in the title was typing kinda fast
post #3 of 9 Old 01-11-2013, 08:35 PM
Jim McC's Avatar
Quoted: 193 Post(s)
Liked: 69
You have 2 options
1) Tilt the front of projector up, to raise image. The you have to use keystone correction to "correct" the shape of image. This is not ideal, due to slight resolution loss.
2) Put the projector on a low table, sitting upright.
Jim McC is offline
post #4 of 9 Old 01-11-2013, 09:58 PM - Thread Starter
Durvelle27's Avatar
Originally Posted by Jim McC View Post
You have 2 options
i actually ended up tilting it up thx
post #5 of 9 Old 01-15-2013, 10:07 PM - Thread Starter
Durvelle27's Avatar
Also is it possible to to stretch the image if its set to 4:3
post #6 of 9 Old 01-16-2013, 03:42 PM
wyen78's Avatar
Not sure what you're trying to do here? Stretch a 4:3 to fill 16:9? Stretch 16:9 to 4:3? Either way it'll look horrible the aspect ratio is too different.
wyen78 is offline
post #7 of 9 Old 01-16-2013, 04:04 PM - Thread Starter
Durvelle27's Avatar
Stretch 4:3 to fit 16:9
post #8 of 9 Old 01-17-2013, 03:54 PM
kmannth's Avatar
Sure see what horrible zoom modes you have on your projector, stretch to fit?. It will look like Junk. People will be really WIDE or really SHORT.
You can zoom in your 4:3 until it is the width you want but you will loose the top and bottom of the screen in a big way.
4:3 is 4:3.
kmannth is offline
post #9 of 9 Old 01-17-2013, 04:30 PM - Thread Starter
Durvelle27's Avatar
4:3 is 4:3.
ok thx gonna try that
