Mitsubishi HC4000 - too loud! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-12-2013, 02:41 PM - Thread Starter
Singh007's Avatar
I was watching tv in standard lamp mode last night, and realized...man is the fan ever loud. Is there any quick fix to dampen the sound, or re-direct it so I can't hear it as much. I sit directly under the ceiling mounted PJ. Maybe some sort of barrier between the projector and me? I don't want to make a hushbox with fans etc...out of my scope of expertise. Thanks
Singh007 is offline
post #2 of 5 Old 01-12-2013, 03:06 PM
HTPC_Dude's Avatar
Quoted: 13 Post(s)
You can run in Eco mode, that should decrease the noise by about half. I had an HC1500 and when I decided to upgrade to 1080p I decided not to choose the HC4000 and instead went with the Epson 8350, one of the quietest projectors on the market. Mine is also ceiling mounted above my head so I did not want another noise maker.
The Epson has totally met my expectations and I can hardly hear it, even in quiet movie scenes.
HTPC_Dude is offline
post #3 of 5 Old 01-12-2013, 03:59 PM - Thread Starter
Singh007's Avatar
Running eco mode just for less noise is not an option for me. I have ambient light in room, so I need the lumens.. Any other options? Even if it just decreases it a little?
Singh007 is offline
post #4 of 5 Old 01-13-2013, 12:16 AM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
I would deal with the ambient light problem first. That should have been done in the first place.
Jim McC is offline
post #5 of 5 Old 01-13-2013, 11:17 AM
cbeyond's Avatar
Hello, I just set up a new HC400 in a room with 3 big windows. It needs to run in the econ mode, the default setting, It is very quiet in that mode, just a whisper, and you get a much longer bulb life, I think. Go to Home Depot or similar and do what I did, get some blackout paper window shades, just stick them up on the windows. You will need a flashlight afterwards. Its very inexpensive, about $9 a box. Projectors by design, need a darkened room for good contrast.
cbeyond is offline
