Short throwing distance 1080p projector recommendation. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-12-2013, 06:30 PM - Thread Starter
Archaea's Avatar
Quoted: 3079 Post(s)
Liked: 2700
I am looking for a projector that can throw around a 100" image at about 8 foot. The top 10 model recommendations from projector central seem to top out at about 85". Any recommendations on a good model that has a shorter throw distance?
Archaea is offline
post #2 of 6 Old 01-12-2013, 07:29 PM
Jim McC's Avatar
Quoted: 188 Post(s)
Liked: 66
Is there any flexibility in the throw or screen size? If you can go to a 9' throw, the Benq W1070 will work.
Jim McC is offline
post #3 of 6 Old 01-12-2013, 08:15 PM
dougri's Avatar
Quoted: 48 Post(s)
Liked: 53
A short throw version of the w1070, the w1080st will be available in early February... Throw ratio .69-.83... Can do 100" from 5ft, or MUCH larger from 8 ft.
dougri is offline
post #4 of 6 Old 01-15-2013, 02:05 PM
ahheck01's Avatar
The w1080st is perfect, except it's a bit more than I'd like to spend, and I don't need 3D. Is there a similar-throw option that's cheaper with just 2D?
ahheck01 is offline
post #5 of 6 Old 01-15-2013, 02:12 PM
wyen78's Avatar
According to BenQ, the W1080st is the first full HD short throw projector so you pretty much have no options if you need short throw.
I don't think you're going to save much by not going 3D with newer projectors. many DLPs have been able to do 3D for years, even before 3D started to get popular. That is why you see a lot of projectors labelled as 3D ready (of course they don't tell you that you need to get a converter box or use a pc to actually get 3D).
wyen78 is offline
post #6 of 6 Old 02-01-2013, 08:33 AM
eastcoastbuff's Avatar
If you are willing to go down to 720p there is the Benq 710st and the Optoma GT750e. They both seem to get pretty good reviews.
eastcoastbuff is offline
Benq W1070 1080p 3d Projector , Benq W1080st 1080p 3d Short Throw Dlp Home Theater Projector
