optoma ML300 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-15-2013, 08:37 PM - Thread Starter
Japnik Singh's Avatar
I am planning to buy optoma ml 300
I am buying it for watching movies in my room. Can I project the screen onto my ceiling or will it result in damage to lamp or sumthing.
Japnik Singh is offline
post #2 of 3 Old 01-16-2013, 11:22 PM
dangur's Avatar
well there are two fans on the back of this projector so i am not such how good of an idea it would be to just put it on its back facing up.wink.gif This will most likely cause it to overheat. however if you use the threads on the bottom to attach it to tripod that can face up. I think that will work fine. it is an led projector so there are no moving parts or bulbs to worry about. You might even be able to build something to attach the projector to with a wood block and bolt and some glue if your really want:)smile.gif
dangur is offline
post #3 of 3 Old 01-17-2013, 06:24 PM - Thread Starter
Thanks man.
