Anybody have any experience with the Toslink 3 way switch - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-16-2013, 08:19 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 170 Post(s)
Liked: 81
Have the soundbar connected with the projector and a bit of a hassle to switch the digital optical cable from the cable box to the blu ray player. Anybody have any experience with this?
http://www.ebay.com/itm/3-x-1-Optical-Audio-Toslink-Bi-Directional-Manual-Switch-/320855995642?pt=US_Audio_Cables_Adapters&hash=item4ab481f4fa
If I would lose any sound quality, it's out of the question!!
It may not be your job, but perhaps it's your opportunity.
MPJ's theater build: http://www.avsforum.com/forum/19-ded...ter-build.html
mpjmeyer is offline
post #2 of 5 Old 01-16-2013, 08:46 AM - Thread Starter
mpjmeyer's Avatar
Quoted: 170 Post(s)
Liked: 81
or what about this? This seems like it would be more legit
http://www.newegg.com/Product/Product.aspx?Item=N82E16812270488
mpjmeyer is offline
post #3 of 5 Old 01-16-2013, 01:43 PM
rekbones's Avatar
Quoted: 478 Post(s)
Liked: 246
I would go with the second one as its active compared to the passive first one. There might be too much light loss through the passive switch. I have something simular to that second one but it has 2 opt out, 4 opt in and also component ,and coax with a remote. That one looks like it has a remote but its not in the specs. I don't need mine any more if your intrested
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #4 of 5 Old 01-16-2013, 03:28 PM - Thread Starter
mpjmeyer's Avatar
Quoted: 170 Post(s)
Liked: 81
is it the Bytecc?
mpjmeyer is offline
post #5 of 5 Old 01-16-2013, 07:07 PM
old corps's Avatar
Quoted: 159 Post(s)
Liked: 89
I can only comment on the 1st one from ebay. I had one and it was junk.mad.gif Fell apart shortly after I got it. Good luck with your search. Let us know if you find a good one.
Ed
old corps is offline
