Panasonic PT-AE3000 - Software Adjustment Tool - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 01-16-2013, 10:08 AM - Thread Starter
Aaron407's Avatar
In an effort to fix the uniformity issues with my panny projector (green tinge on the left half of the screen, red tinge on the right half), I have ripped it apart numerous times, thoroughly cleaned it out (including the incidence polarizers, lenses, mirrors and LCD panels), and adjusted the mirrors to the extent possible. However, that didn't really make any difference for the uniformity problem, so I'm thinking that I need to do some final software adjustment.
In the service manual, the software in question is referred to as "Adjustment Tool [AE3000]" and a description of the commands is provided. However, I cannot, for the life of me, find that serial-based software anywhere. I assume that it's probably limited to Panasonic repair depots, but does anyone know where someone like myself may be able to get their hands on this? The uniformity issue fits in the "what has been seen cannot be unseen" category and is driving me crazy, so any help would be much appreciated!
Aaron407 is offline
