noobQ - home theater projector for well light room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-17-2013, 01:21 PM - Thread Starter
byThorbyOdin's Avatar
Well noob kinda. I've gone through this rigmarole once before and given up - lets see if this time's a bit better. I'm looking for a HT projector that goes in my living room - no options for darkening windows or putting in extra heavy curtains w/o a riot act read from the missus. Last time I tried (a couple years or more ago) there were just no options to handle the ambient light in the room - I live in Oregon so there isn't "bright: light ever but even so. With the updated technology I'm hoping for better luck this time around. Are there any projectors that fit this scenario and are reasonably priced?
byThorbyOdin is offline
post #2 of 6 Old 01-17-2013, 01:30 PM
kmannth's Avatar
Got ask about this in the screens section first. I know there are some expensive screens that might give you a chance.
There are more lumen now than before (look at the w7000)
I travel with an 80inch white screen to uncontrolled light places from time to time. I have (bulb life and modes considers) 800-1000 lumens and it is not even close to enough to use during most days at the Oregon Coast.
Maybe with a dark screen and more lumens you could have something you can live with but I don't consider my travel setup usable during the day.
Have you looked into the 80 inch LCD and big Rear Projection TVs?
kmannth is offline
post #3 of 6 Old 01-17-2013, 02:30 PM
rekbones's Avatar
Quoted: 408 Post(s)
Liked: 198
No matter what the tech no image will be any darker then the screen is with the projector off. More lumens will make it brighter to up the contrast. For a large screen I would look at the Mits RPTV before they are gone for good
"Smart enough to know better, to old to care" ------ Dedicated Home Theater, Mitsubishi HC7900DW Projector, 110" 16:9 Jamestown screen with variable power masking for CIW 2.50:1 to 16:9, Marantz 7009 with 7.1.4 Atmos with Ohm mains,3 DIY Subs (2 15" (1 ported, 1 sealed and a 12" 4th order bandpass), 1 DIY butt kicker, Custom Built HTPC, 10TB DroboFS NAS
rekbones is offline
post #4 of 6 Old 01-17-2013, 02:59 PM
Sheridan1952's Avatar
Projectors just cannot compete with bright, ambient light. If you can't control the environment then you should really consider a flat panel.
Sheridan1952 is offline
post #5 of 6 Old 01-18-2013, 09:18 AM
wyen78's Avatar
I would think that with all the different kinds of window treatments out there you and your wife could come to some compromise that would work well and look good too. I mean, how obtrusive is a pull down shade? It can go behind the drapes, just pull it down when using the projector and have it rolled up behind your current window treatments when not using the projector.
wyen78 is offline
post #6 of 6 Old 01-19-2013, 11:00 AM - Thread Starter
Problem is there is an open connecting doorway to a room with skylights. This was not for lack of trying smile.gif
