dark bar on the bottom of the screen. pic attach (epson 8500ub) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-19-2013, 10:42 AM - Thread Starter
erezbt's Avatar
as you can see on the picture below, there is a dark bar on the bottom of the screen. can i fix this issue by myself?
what cause to this problem?
thanks.
erezbt is offline
post #2 of 5 Old 01-20-2013, 01:17 AM
jnabq's Avatar
Liked: 39
Is it there on different source inputs? It could be a light engine issue and repair would be almost, if not higher than buying a new pj. Probably not a diy repair. You might try a different cable, and or bulb, if you have one as well, but it doesn't look good.
jnabq is offline
post #3 of 5 Old 01-20-2013, 01:57 AM - Thread Starter
erezbt's Avatar
thanks for you answer.
there is no other source inputs. i recently replace the bulb with a new one, this problem show on the old bulb also.
i'll try to replace the cable and see what happen.
again thank you very much
erezbt is offline
post #4 of 5 Old 01-20-2013, 10:58 AM
Tinman's Avatar
Liked: 33
These types of faults are generally caused by one of the elements in the light engine MOVING a little out of place from heating and cooling cycles.
It is a very simple fix, but not a DIY unless you are comfortable taking LCD's apart and getting them back together.
Welcome to the darkside.....
Tinman is offline
post #5 of 5 Old 02-11-2013, 12:22 PM
Brian Owens's Avatar
Mine just starting doing this too. 3 months out of warranty. Epsons response "sorry, only covered for 2 years".
Brian Owens is offline
