3D QUALITY: POP OUT/Benq w 1070 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-20-2013, 12:53 AM - Thread Starter
dekkerEssex7's Avatar
I have read people commenting that on newer projectors in general, 3D adds depth withIN scenes. Have you seen the 3D 'reach for it' effect, particularly with the benq w1070? I assume it depends which movie, but if made for 3d blu-ray, it should, if effect is there.
Also, although the w1070 doesn't have a 2d to 3d converter, the oppo dbp 103 dvd player ($500) does. Anyone tried this?
dekkerEssex7 is offline
post #2 of 5 Old 01-20-2013, 07:48 AM
Ilya Volk's Avatar
I wouldn't be worried about that. The quality of 3d "pop-out" depends on three things:
a) content,
b) ghosting - perfect on any DLP,
c) contrast - typical for DLP DC3, good enough behind the glasses, I suppose better than W7000.
Ilya Volk is offline
post #3 of 5 Old 01-20-2013, 07:56 AM
TLJester's Avatar
a) content,
I thought the 3D effect was determined by the offset of each image for the left/right eye?
Where the greater the offset, the further the object comes/retreats to you?
TLJester is offline
post #4 of 5 Old 01-20-2013, 10:44 AM
Ilya Volk's Avatar
That's "a) content".
post #5 of 5 Old 01-21-2013, 06:26 AM - Thread Starter
Thank you for input
Benq W1070 1080p 3d Projector
