Fixed a Broken Epson Powerlite 1080 (TW1000) myself - AVS Forum | Home Theater Discussions And Reviews
 2Likes
  • 1 Post By redman042
  • 1 Post By Tinman
post #1 of 20 Old 01-21-2013, 12:11 PM - Thread Starter
redman042's Avatar
There's very limited information out there on this subject so I thought I'd share in the hopes of helping out others.
I purchased this projector new in late 2007 as part of my home theater build. As of today it has 1400 hours on it (original bulb). It's been working perfectly for the five years I've owned it, until a few weeks ago a problem started cropping up. It began as an occasional error during startup, requiring me to unplug the unit to reset it then try again. Then it quickly grew in frequency over the next week until I could no longer start up the projector anymore. So I started seeking a solution.
The error happens like this:
  • I power on the projector
  • Green light blinks as normal for a few seconds and I hear the faint rumble sound of the auto iris cycling
  • Then I hear the normal louder motor sound, which I believe to be the optical filter being cycled. When a failure is about to occur, this sound is louder and longer than normal, as though the motor is struggling. Just by listening, I can tell when the error is about to happen.
  • Then the projector kicks the fan up to the highest speed I've ever heard, and the red light blinks on and off at one second intervals. This blinking interval indicates an "internal error" per the manual. It is not a lamp or temperature issue, which would be indicated differently.
After this, the projector must be physically unplugged. Plugging it back in would sometimes result in a successful startup, but the rate of success decreased rapidly.
So I started by calling Epson. Of course, the projector is long out of warranty and I knew I'd be facing repair costs. I figured anything below $500 was worth the cost, anything above made the unit a throwaway. Epson referred me to two authorized service providers a couple of hours from my house. They also offered me discounts on their Loyalty website in case I decided to replace the projector. This turned out to be a cruel joke, since they are not currently offering comparable projectors on that site. But I can get a great discount on printer ink mad.gif
Then I tried the more reputable of the two service providers. They were very helpful and spent a long time on the phone with me, called Epson themselves, then got back to me. But the bottom line was not encouraging. Basically, they would replace the most likely culprit, the auto iris, at a cost of $200. It would either fix the problem or not. If it didn't, then the next step was to replace the motherboard or light engine. In either case, the cost would be over $1000 and this would clearly not be worth it for a 5 year old projector.
I didn't like the odds. I'm reasonably handy with a screwdriver and have repaired electronics before, so I decided to try to fix it myself, and if I failed, I'd buy a new projector. I found two tips online that helped point me in the right direction:
1. A short discussion thread where two people discuss successfully fixing the optical filter:
http://www.fixya.com/support/t6236487-after_replaced_lamp_epson_emp_tw700
2. A German website that actually tore down a unit and pointed out where everything was:
http://cine4home.de/tests/projektoren/EpsonTW700/TW700Test.htm
Right away I was intrigued by this optical filter. This was the first I heard that there was another motorized part besides the auto-iris (and of course the fans). I remembered the sounds the projector made. The auto iris sounds like a rumble. So the louder sound that occurs before the error must be this optical filter. The service rep never mentioned trying to fix that (or even that it existed). If this was the real issue, would the service rep consider that part of the optical engine and hit me with a $1000 bill? Hmmm. So that was my target for the repair.
I took my sweet time with the disassembly but it wasn't overly difficult. I took photos at various stages to carefully document the correct locations of cable connections and screws, and this was invaluable for the reassembly.
After removing the motherboard, my first step was to remove and check the auto iris. I wasn't certain I could eliminate this as a possible failure point. Removal was easy. I did have to push the motor gear to get the iris doors in the vertical position before I could lift out the assembly. The gears moved smoothly without any resistance, and the motor gear seemed firmly attached to the motor shaft. There was plenty of silicone lubricant. I did not see any problems. I did go ahead and clean a little sensor underneath one of the "half circle" black gears that detects the position of that gear. Used canned air and a lens wipe. Then I carefully repositioned the gears so that the one dot on the upper gear centered between the two dots on the lower gear, and reinstalled the iris.
Next I moved on to the optical filter. I removed the metal bar that covers the sliding filter. See photo. The filter can then easily be pulled straight up and out. I noted before removing it that it the back edge was exactly centered on the glass lens. This probably doesn't matter since I think the projector cycles this filter back and forth on startup until each limit switch (on the metal bar that I just removed) is activated, thus calibrating its position.
After removal, I blew out a light amount of dust with an air can. Then I visually checked everything out. I could not see anything wrong. I then tested the limit switches with a homemade continuity tester (flashlight bulb and battery connected to wire leads) and verified that they were making proper contact when closed. I had suspected the switches were the issue, because the bad sound I was hearing kind of sounded like the motor was attempting to move the filter past its limit, as though the switch wasn't giving feedback. But I could not detect a problem with them.
I put the optical filter back in the slot and meshed it with the gear, then slid it back and forth with my fingers. I felt what seemed like the proper amount of resistance from the motor, indicating that I probably didn't have gear slip on the shaft (gear slip was described in one of the links I provided above). I really didn't want to pull the whole optical engine to get underneath and inspect those gears directly. So I relied on this test to assume that I probably did not have gear slip.
To make a long story short, I actually did not find any obvious problems at all. I carefully reassembled everything in the hopes that I would get lucky. And I did! The projector works fine now. I've started it up at least 6 times with no issue at all. In fact, the motor sound during startup is quieter and shorter than I remember even when the projector was previously working okay.
So what did I do? I have to assume something was not in perfect alignment in the motorized optical filter (maybe it never was), and the reassembly fixed this. I did not grease it by the way (it was dry when I removed it, unlike the auto iris, so I didn't want to grease something that is not supposed to be greased).
If the problem does crop up again, I will try to order replacement parts for the optical filter including the motor and gearbox, and do the repair myself. By the way, after reassembly I turned the unit on with the top cover lifted up a little, and listened carefully to try to localize the sounds I was hearing. I'm almost certain the larger motor sound does come from the optical filter, not the iris.
Anyway, I hope this helps someone, because I know others have had similar problems with their Epsons. If you don't want to attempt this repair yourself, at least you can point your repair person to this thread.
Protonus likes this.
redman042 is offline
post #2 of 20 Old 07-29-2013, 04:08 PM - Thread Starter
redman042's Avatar
Just thought I'd report back that my projector is still going strong 6 months later. Not a single issue since that repair. Eventually I will replace it with a new, much brighter, 3D one, but I can do it when I'm ready and can get a little cash for this one since it's still working. I hope this post has helped someone.
post #3 of 20 Old 07-29-2013, 05:33 PM
d james's Avatar
Thanks for the heads up, this gives me hope that I can fix my broken 6500ub that has two blinking lights, which is supposed to be the filter I believe. I took mine in to have it repaired and paid 50 bucks for them to tell me the whole optical lens needed to be replaced as its one unit. The parts cost was 1200 dollars without them even installing it. Strangely enough it was the same price as a refurb, which I don't quite get but maybe I can take it apart and see if I can solve it.
d james is offline
post #4 of 20 Old 07-31-2013, 03:03 PM
Tinman's Avatar
Liked: 33
I always love it when people dare to fix something themselves.
This is what we USED to do long ago. Nowadays you get a quote for an entire assembly because we have become a culture of board swappers. There are few technicians left that repair to single component or are not to lazy to do so.
It's just become easier to toss out a big quote and see.
Congratulations!!
toddman36 likes this.
Welcome to the darkside.....
Tinman is offline
post #5 of 20 Old 03-30-2014, 02:15 PM
size14a's Avatar
Redman042,
  Thank you so much with your help i fixed my epson projector home cinema 3580. The one thing i would add to yours it to place the optical filter in front of the lens for proper alignment. I had to take mine apart twice to figure that out. Thank you again great post!!!!
size14a is offline
post #6 of 20 Old 03-31-2015, 04:41 PM
Protonus's Avatar
Quoted: 17 Post(s)
Question
@redman042 - thank you so much for this awesome guide. I've got a very similar projector, the Epson 8350, and it's doing the same thing yours was. Only, I'm not positive the cause is the same. I've already done what you've done in this guide and it didn't help. Furthermore, I've run the projector with the cover off and lamp out so i can see the cinema filter and auto iris do their thing. They seem to function OK. I actually wonder if I have a thermal switch issue. I was wondering if you could please, take a look at my post here:
The Offical Epson 8350 Owners Thread
And let me know about the things I listed there? I appreciate any and all feedback you can provide!
Harman Kardon AVR 254 ● Energy Connoisseur C-7 ● Epson PowerLite 8350 ● 100" DIY WA DW w/ 80/20 frame
Protonus is offline
post #7 of 20 Old 03-31-2015, 07:08 PM
Verge2's Avatar
Quoted: 723 Post(s)
Liked: 171
Congratulations!!
Yea good write up. Hope it helps people who are a googling.
Verge2 is offline
post #8 of 20 Old 04-09-2015, 12:03 PM
dinodog's Avatar
ok, Have to agree with Redman042......you must put the filter back directly in front of the Lens for this work, and yes I had to do it twice also.
And now it works again. Again I did nothing but pull the filter, clean it then re-align it in front of the lens. and presto, fully functional.
Cheers to you all, good work.
Dean
dinodog is offline
post #9 of 20 Old 04-25-2015, 10:51 PM
Liked: 0
Redman042.
Thank you, thank you, thank you......
You save my Epson TW700 (almost 7 years old, about 3000 hours of use).
I would like to point the following:
We must be very carefull with the film-wires of the motherboards, they 're fragiles.
I carefully filled the joints and the gears of the auto-iris and the gears of the motor of the cinema filter with Lithium grease.
VERY IMPORTAND: The cinema filter must be initially alligned in front of the "fly -eyes" lens, with carefully touch to the midle microswitch of the bar-base.
I opend the cover of the optics (in front of the optical master lens).
First, I use air can to remove the dust and I use a photo lens cleaning gel and microfiber cloth for cleaning the lenses and the pollaroid filters.
The sounds of gears are smooth and nice.
I enjoyed the "Escape of NY" with my brand new projector!
Be well , strong and healthy.
Thank you again
greetings from from Greece
Chris
ChGeorgopoulos is offline
post #10 of 20 Old 05-13-2015, 03:22 PM
chrison600's Avatar
Quoted: 12 Post(s)
Disregard this response. I got it. Two small screws at top of rear panel.
Chris
Well - I feel like an idiot because I'm going to try to perform this repair/lubrication of the iris and optical filter and I can't even get the case open.
Epson ProCinema 9350. Got the side panels off and 7 screws out of the underside that seem to release the upper portion of the case. The front edge will lift free no problem, but there's something still holding the rear together. Help?
Chris
chrison600 is offline
post #11 of 20 Old 05-13-2015, 05:47 PM
chrison600's Avatar
Quoted: 12 Post(s)
I have completed this repair and it looks like I screwed up one of my LCD's. Appears that red is gone.
Does anyone know how to put the projector into test mode to see if the red LCD has indeed failed?
Follow on question: Are the LCD cables replaceable? Should I look for a replacement cable/LCD or have I basically forced myself into another projector?
Chris
post #12 of 20 Old 05-13-2015, 07:05 PM
chrison600's Avatar
Quoted: 12 Post(s)
After a little more research, it appears this might be due to a misaligned cinema filter panel. Does anyone know if that misalignment might cause what appears to be a lost LCD color?
Chris
post #13 of 20 Old 08-23-2015, 04:51 PM
matt25rs's Avatar
This fixed my 8350! Thank you very much for the help.
EDIT: Unfortunately this only worked for a short while then the gears on the motor broke. I applied this fix and have been working since.
matt25rs is offline
post #14 of 20 Old 09-04-2015, 06:16 AM
matt25rs's Avatar
Couldn't post the link due to number of posts.......
matt25rs is offline
post #15 of 20 Old 09-04-2015, 06:17 AM
matt25rs's Avatar
matt25rs is offline
post #16 of 20 Old 10-20-2015, 06:56 AM
Liked: 0
I know this is kind of an old thread but wanted to say thanks. This saved me too.
I had the exact same symptoms as the author. I have an old Home Cinema 1080 - purchased the 1st year of the model (2007) so it's 8 years old. Similar to others on this thread, I know I need to replace this unit with a better, more up to date model but I just don't want to deal with it nor do I have the funds right now.
So I took the unit apart to see if I could figure out what was up (nothing to lose). After messing around with it I found this thread. Took the filter mechanism apart and blew it out and manually moved it back and forth a few times. Tested with it half pulled apart and viola! It worked. Tested it about 4 more times during each stage of re-assembling it. Popped it back on the ceiling mount and I'm good to go. I figure if it happens again I'l repeat the process....maybe look for a part on line if I'm still not ready to buy a new unit.
So once again, just wanted to say thanks! and reiterate to anyone looking at this thread that it works and it's not that difficult.
Mark Downey is offline
post #17 of 20 Old 11-03-2015, 05:34 PM
Liked: 0
Another 1080UB owner chiming in here. I originally purchased mine back in 2008 and the noisy motor / flashing red with turbo fan started about 2 months ago.
First, I'm writing to say thanks for the original poster. Excellent description and pictures.
Second, I'm writing to share my slightly different experience in case someone else finds it useful.
I tried the open/jiggle/close attempt, but that didn't work for me. In the end I had the "stripped gear" issue that is referenced. I had to pull a bunch of the components out to access the small geared motor housing that drives the optical filter carriage.
Here is a test to see if your problem might be similar. If you can slide the optical filter back and forth manually, then your gears are (at least partially) stripped. They may have enough friction in the short term, but you'll likely see slow degradation until it just whirrs and then errors out with the flashing red light again.
When I had the geared motor section detached, there is a brass shaft with two larger exposed white gears attached that drives the optical filter carriage. The brass shaft enters the small black gear box through a brass bushing and gets turned internally by the small motor. The brass rod is splined and friction-fits into a tiny gear in the gear box. This connection was what was slipping for me.
I fixed it by taking the brass shaft out and carefully used a thin wire to place a small amount of CA glue (super glue) into the gear box on the inside of the small gear. Don't get any glue on the bushing. Then, re-insert the brass rod until it fits snugly and screw in those tiny screws.
At this point I hooked the motor up to a 5V power supply and confirmed that all the gears turned as they should. It was also at this point that I discovered that, with the motor stopped, I was unable to turn those larger white gears manually. If they can be turned manually, then some gear connection somewhere is slipping!
I re-assembled everything and all my tests so far show a fully functioning projector. I'll try to remember to post again here to confirm the fix is working longer term.
I love the dive-in-and-fix-it attitude in this forum. It hurts me to think how many of these projectors got tossed because of a tiny slipping brass to plastic connection. Good luck!
Dylan Parker is offline
post #18 of 20 Old 09-18-2016, 01:21 PM
Spelvin's Avatar
Howdy! OP, thank you for the write up on this. I had a lamp destroy itself in my projector and after the replacement was in I kept getting the flashing red light issue. Taking top off and the mother board out I found I could manually move the color filter without. I then tore down the entire projector and hopefully fixed the gear. I found that by removing the gear from the metal shaft and then putting it back on inverted allowed it to no longer slip on the shaft.
Unfortunately I now have a new issue. while trying to get to the gear box I tore down items that probably did not need to be messed with and as such my blue no longer works as it should. I have re-seated the ribbon cable and made sure it looked good, but this appears to be more of an optical issue.
Can anyone make any suggestions as to which piece I may have move improperly that would cause the attached odd cut off? I have messed with the Lens shift, set it to ceiling mount, rechecked the optical path and they all seem fine or do not change the issue. Red and Green look perfect.
I noticed that each of the optical paths have what look like filters on the ends before they get to the LCD panels for each color. Those filters appear to have adjustments, but they are set and then appear to have glue or some epoxy on them. I have not tried to adjust those, and was hoping to get an option on them before I did.
Thank you!
Spelvin is offline
post #19 of 20 Old 04-09-2017, 07:21 PM
Quoted: 14 Post(s)
Liked: 1
Hi,
ive had my Epson 5030ub for about 3 years. was running fine until last week.
I purchased this projector new as part of my home theater build. As of today it had about 4200 hours on it (original bulb). I had just bought a new bulb as i knew it was going to be requiring a replacement soon. It's been working perfectly for the time ive owned it, until a week ago where it simply died. This is what happened:
The error occurred like this:
1. I pushed the standby button twice as normal on the remote to turnoff the projector after watching for about 2 hours.
2. Suddenly i heard something inside the projector rumble really loudly, a sound i had never heard before. It was not the sound of the auto iris adjusting as ive heard that many times. it was a different noise. Then the temp light started flashing bright red and status light blue and simultaneously the fan went to overdrive and started blowing air like crazy. (im not sure if i heard a little pop sound in the moment but maybe there was maybe there wasn't).
3. The projector then turned itself off after about 20 seconds etc.
4. I switched it off from the power assuming it would be okay the next morning and probably that it just needed a replacement bulb which i knew was needing to be changed. So i went to sleep.
5. next morning i found one my fuse in my house was tripped however the surge protector i had the projector plugged into was fine. i turned on the fuse and I then went to turn the projector on from the remote and then this --->
"power light" remains off, all i was getting was a flashing orange "lamp light" and a flashing blue "status light" which according to the manual indicates an internal error / malfunction with the projector (contact epson for help). The unit is powered but nothing at all happens. The projector will not turn on.
6. i tried the new bulb just to see if that was the issue but no help there. so its definitely not a bulb issue.
i rang EPSON who forwarded me onto one of their repairers who is telling me that the entire optical engine and mainboard needs to be replaced and that i am looking in the "thousands" to get it fixed. He says there isnt any issue with the power supply etc.
I am out of warranty but this is a catastrophic major failure, what are my chances regarding getting any help from EPSON? I mean i dont want to pay thousands to get this fixed and neither do i want to take out thousands of more dollars to buy an entirely new projector.
has any owners of the Epson 5010, 5020, 5025, 5030 or even 5040 owners know anything about this? Please help
saintblues is online now
post #20 of 20 Old Today, 07:02 PM
Quoted: 14 Post(s)
Liked: 1
Hey everyone, got the replacement PSU, ripped the entire projector into bits. literally gave everything a clean and put it all back in with the new power supply unit and what do you know. back working beautifully!!!!!
cant believe epsons repairer said it was unfixable.. some of these guys literally work for money. fixed it myself, will be righting up a detailed post hopefully when i get some time!
thanks for everyones help!
most of epsons projectors all use the same PSU so this could be relevant to many epson projector models as well as the newer 5040ub thats just been released.
Epson Powerlite Home Cinema 1080 Home Theater Projector
