Dark spot on screen - AVS Forum | Home Theater Discussions And Reviews
Old 01-21-2013, 02:49 PM - Thread Starter
bomboy001's Avatar
Does any one know the cause of this dark sport on my projector? How can I take care of it?
bomboy001 is offline
Old 01-21-2013, 03:22 PM
kmannth's Avatar
Is something on your lens?
What kid of projector do you have? How many hours?
kmannth is offline
Old 01-21-2013, 04:06 PM - Thread Starter
bomboy001's Avatar
Volk Cinema LCD projector Model HD-80 about 1000hrs
Old 01-21-2013, 04:22 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
Sorry to here that you got scammed.. Apparently you got a lot of use out of it.. and hopeful only paid $100 for it.
This is a Single panel LCD projector with a fresnel lense in front of the panel and then the focus lens you see outside. This was the technology used in the very first digital projectors back in the late 1990s. Dirt and dust can get into the light path and cause issues like this.
Good luck!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 01-21-2013, 04:46 PM - Thread Starter
bomboy001's Avatar
Which projector would you recommend as a replacement?
Old 01-21-2013, 05:13 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 284
If you are going to replace it, open it up and see if you can fix the issue.. Then start doing some research, this is a good thread to start with. http://www.avsforum.com/t/1339241/coderguys-cheat-sheet-for-choosing-a-projector/0_100
Doug
