Brand new projector; spots on the screen - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 01-24-2013, 07:32 AM - Thread Starter
Iceking007's Avatar
Hello I just bought a benq W710ST and I've noticed it's putting these two fist sized circles near the top two corners almost like a lense flair or water spot. These are not on the out side of the lense as I have cleaned it with no results, if i turn the focus ring the spots will mostly hold their position but change size. I think it's some internal smudge on the lense or something should I be worried about this, should I send it back on warrantee, have you ever experienced this before?
Iceking007 is offline
post #2 of 3 Old 01-24-2013, 03:08 PM
DaGamePimp's Avatar
Quoted: 360 Post(s)
Liked: 381
Sounds like dust blobs. Exchange it.
Jason
Media Room = Vizio 4K 70" lcd/Denon x4100/Audiosource Amp 100/Klipsch speakers/Velodyne subs/Sony BDP s780/PS4 Pro/X1S/WiiU/PS3/360/Wii/Game PC/Multi-Arcade / #standwithscotty / My HT SLIDESHOW
DaGamePimp is offline
post #3 of 3 Old 01-24-2013, 03:42 PM
Bohanna's Avatar
Liked: 24
I'm guessing that moisture somehow made it to the backside of the lens. Since its new I would exchange it
Bohanna
Bohanna is offline
