question about lamp module care - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-24-2013, 10:49 AM - Thread Starter
unikr0n's Avatar
getting ready to replace my old lamp in my dlp optoma projector this weekend. my question is i have the new lamp still in the box and haven't opened it yet (got it this week). it seems like i've read that its best to not expose it to light until i'm ready to install it.
this there any truth to this? the lamp is #lmg5162 for an optoma hd20 if that info helps any. thanks!
unikr0n is offline
post #2 of 6 Old 01-24-2013, 12:35 PM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Not expose a Lamp that makes light as bright as day and produces heat as hot as the sun, to light?.. no, I don't think there is any truth to that statement and actually the first time I have every heard such a suggestion.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 6 Old 01-24-2013, 12:55 PM
kmannth's Avatar
I think you don't want to touch it or contaminate it in any way. Sunlight won't hurt it.
kmannth is offline
post #4 of 6 Old 01-24-2013, 02:00 PM - Thread Starter
unikr0n's Avatar
fantastic. thanks, guys!
unikr0n is offline
post #5 of 6 Old 01-24-2013, 03:03 PM
Bohanna's Avatar
Liked: 24
The issue is getting your body oils or other contaminates on the actual Lamp element. The reason they suggest vinyl gloves is there is mecury in the lamps. As long as you don't touch the actual inside lamp stem or the arc chamber you should be fine.
Bohanna
Bohanna is offline
post #6 of 6 Old 01-24-2013, 03:09 PM
DaGamePimp's Avatar
Quoted: 443 Post(s)
Liked: 494
"Step Brothers" reference...
DON'T TOUCH IT !!!
Jason
Media Room = Samsung 65KS8000 / Denon x3300 / Klipsch speakers / Velodyne subs / Samsung K8500 / PS4 Pro + PSVR / WiiU / PS3 / 360 / Wii / 1080 TI - i7 game PC / Multi-Arcade / My HT SLIDESHOW
DaGamePimp is online now
