WIll HDMI Wall plates cause issues? - AVS Forum | Home Theater Discussions And Reviews
Old 01-25-2013, 09:23 AM - Thread Starter
tasburath's Avatar
Hey guys,
I am going to run HHDMI from my projector to my receiver. It will be a 20' run.
I want to use something like this in the ceiling & wall:
http://www.amazon.com/Monoprice-Two-Piece-Built--Flexible-Ethernet/dp/B003R73MPI/ref=sr_1_6?ie=UTF8&qid=1359130753&sr=8-6&keywords=hdmi+wall+plate
Will having 2 HDMI wall plates between the projector and receiver cause any significant signal loss or create input lag?
tasburath is offline
Old 01-25-2013, 11:51 AM
garciab's Avatar
Quoted: 144 Post(s)
Liked: 55
I can only say that they didn't cause any problems for me/my 720p projector.
bg
garciab is online now
Old 01-25-2013, 12:14 PM
old corps's Avatar
Quoted: 157 Post(s)
Liked: 87
Didn't cause any problems for me either. I used the single Monoprice wall plates. Sending 1080p to projectors (Epson 3010 & Viewsonic Pro8100). You'll be fine.smile.gif
Ed
old corps is offline
Old 01-25-2013, 03:22 PM
BobL's Avatar
Liked: 56
They may or may not. With HDMI the safest bet is to run the a straight cable and use pass through wall plates. All added connections like wall plates, port savers ,etc. change capacitance and alter the signals waveform. If it alters it enough it will be a problem. Working in this business I avoid those extra connections like the plague but YMMV.
BobL is offline
Old 01-25-2013, 08:20 PM
rovingtravler's Avatar
I am using pass through plates just so I do not have to wonder.
David
"You buy a Ferrari when you want to be somebody. You buy a Lamborghini when you are somebody." - Frank Sinatra
rovingtravler is offline
Old 01-27-2013, 10:59 AM - Thread Starter
tasburath's Avatar
Can you guys link the pass-thru plates that you use?
Old 01-27-2013, 11:21 AM
BobL's Avatar
Liked: 56
BobL is offline
Old 01-28-2013, 08:09 PM
I have the one with power for the projector side and one from ebay with a 7.2 speaker set up and HDMI in a 3 gang wide setup.
David
Old 11-18-2014, 01:43 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
I was going to do it this way also, for simplicity - you need only one cable end to end, instead of 3. But the problem is that it would leave a hole for cold air to creep into the room. That was a deal breaker. Wall plate it is.
Soulburner is offline
Old 11-18-2014, 02:02 AM
dreamer's Avatar
Quoted: 910 Post(s)
Liked: 242
You could just use duct tape sealing the wires to the back of the plate on the inside before you stuff them back into the wall and screw it in place. I'll do that just to keep pests from crawling out of the wall and into the room but it will seal against cold air too..
Kirk Ellis
BenQ W1070 VuTec 122" Screen
Harmon Kardon AVR 247 Parasound L&R Amp
Psycoustic Mark III L&R Towers, Boston Center
Energy Take 5 Surrounds, HSU Research Sub
dreamer is offline
Old 11-18-2014, 08:10 AM
techtre2003's Avatar
Quoted: 159 Post(s)
Liked: 90
I would echo what BobL said. If you decide to do the wall plates I'd definitely get them in and test everything out to make sure they work ok before you cut any holes in your wall/ceiling.
techtre2003 is offline
Old 11-18-2014, 12:51 PM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Good thinking. Will be trying this by the end of the week. If the plates don't work, they are going back. However, they have good reviews so I don't expect any problems (fingers crossed). They are the CE Tech recessed plates from Home Depot.
Old 12-06-2014, 11:30 AM
Soulburner's Avatar
Quoted: 194 Post(s)
Liked: 379
Back to report that the CE Tech wall plates work perfectly. I recommend them over the others because they are a bit recessed and look pretty decent, lending to the WAF.
