SANYO PLV Z5 LCD PANEL CONVERGENCE - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-27-2013, 08:01 AM - Thread Starter
pixelquest's Avatar
Hi,
I just bought a nice second hand Z5.
The picture is good but needs a little shift of the red panel
Did anyone find how to adjust panels to each other vertically,
and also 1 pixel by 1 pixel horizontally ?
I could only make 2 pixels jumps through the service mode.
pixelquest is offline
post #2 of 7 Old 01-27-2013, 08:42 AM
Bohanna's Avatar
Liked: 24
Originally Posted by pixelquest View Post
Hi,
Not sure if the LCD Block has adjustments or if everything is done through the service menu. If there are three sloted screws on top of the LCD panels that are attached to the optical block you can adjust them there. I don't have a service manual for this one but if you can take a picture of the Block and post it here maybe I can help. BTW don't touch or unseat the panels. you can take a cut down business card and slip it on front of the Panels to see what one is out or alighment,
Be careful if or when you open the case. that you don't rip off the connector that goes to the top board. Open it slowly and look underneath.
Bohanna
Bohanna is offline
post #3 of 7 Old 01-31-2013, 08:45 AM - Thread Starter
pixelquest's Avatar
Hi Bohanna,
Thanks for your reply !
The 3 panels and the prism are a complete set, not mechanically adjustable.
I'm looking for a more precise way to adjust them.
Untill now I went through the service mode (menu+input during 5s, then screen button)
group 4,parameters 15 16 17 can shift horizontally the panels by 2 pixels ! (which is not too bad , but not enough)
I could not find a vertical adjustment neither.
Do you have any idea ?
post #4 of 7 Old 01-31-2013, 10:39 AM
Bohanna's Avatar
Liked: 24
nope don't have a clue and I checked several of my other manuals and group 4 had nothing to do with alignment. sorry Where did you get your data numbers from?
Bohanna
Bohanna is offline
post #5 of 7 Old 01-31-2013, 02:28 PM - Thread Starter
pixelquest's Avatar
Hi Bohanna,
I got it from an extract of the service manual
What do you think about it ?
post #6 of 7 Old 02-01-2013, 07:13 AM
Bohanna's Avatar
Liked: 24
Hi Bohanna,
I would buy the manual and toy around with it. MAKE FREAKING SURE YOU WRITE DOWN ANY SETTINGS BEFORE CHANGING THEM. Do not try to keep them in your head. The settings may be relational to each other if the machine has already been worked on so relying on factory /default values will be useless. You may want to print out the two or three service menu pages and jot down all the numbers in each box before you change ANYTHING so you know what to go back to ITSHTF.
Bohanna
Bohanna is offline
post #7 of 7 Old 02-02-2013, 01:22 PM
Bohanna's Avatar
Liked: 24
Don't know if this is helpful but I just ran across it
http://www.servicemanuals.net/ServiceManual/SANYO/PLVZ5_Z5BK/594088/detail.aspx
Bohanna
PS let me know if you buy it .. i could use a screen shot of the data chart
Bohanna is offline
