Mits HC4000 or step up to Panny AE8000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-29-2013, 12:50 AM - Thread Starter
OilfieldTrash78's Avatar
This is going to be my first PJ, and I am not 100% sure which one to get. I am hearing pretty good things about the Mitsubishi HC4000, and good things about the Panasonic AE8000. I have read the owner's forums on them both, but wanted some input on the 2. Is it worth the step up in price to go with the Panasonic? Or for a beginner would it be best to start with the Mitsubishi?
The room it will be going in will be a dedicated HT, with one window that has blinds, and blackout curtains. The ceiling and all walls are painted dark.
Thanks for the info.
OilfieldTrash78 is offline
post #2 of 5 Old 01-29-2013, 08:14 AM
domingos38's Avatar
Quoted: 27 Post(s)
Liked: 42
I would go with the 8000,because u have a dedicated HT room.its more money but you will appreciate the better blacks
domingos38 is offline
post #3 of 5 Old 01-29-2013, 04:32 PM
dbturbo2's Avatar
Quoted: 28 Post(s)
I have not seen the Panny but have spent time with the HC4000. Out of the numerous projectors I experienced in my room over the past year the HC4000 was one of my favorites regardless of cost. The DC3 gives it good black levels, and you have the clarity and pop of the DLP picture. As long as you can live with the limited placment options and without 3D, I don't know how you could go wrong at this price. Benq 1070 seems a good choice at this price also.
dbturbo2 is offline
post #4 of 5 Old 01-29-2013, 06:18 PM
CoryW's Avatar
Quoted: 148 Post(s)
Liked: 111
I own the Mits HC3800 and I still absolutely love it. I know the HC4000 is even better. And I'm sure the Panny is outstanding as well. I will say I'd recommend doing research on some of the differences between DLP and LCD. I've always been an LCD guy (3 previous LCD projectors before Mits) but when I switched to DLP I now prefer the pop that comes from the ANSI contrast that DLP does so well.
Cory
Audio: Ascend Acoutics, Sennheiser HD 598, Denon AVR-S710W
Video: JVC DLA-RS400, LG OLED B6, 92" Dark Energy Abyss screen, HTPC/MadVR/Darblet, Panasonic DMP-UB900 UHD Player
CoryW is offline
post #5 of 5 Old 01-29-2013, 07:22 PM
coderguy's Avatar
Quoted: 503 Post(s)
Liked: 345
I would look at the Benq w1070 as well, better 3D than the Panny, sharper, but worse blacks. You'll save a ton of money though and get a better pixel fill with the DLP as well.
For a first projector. the Benq is a better deal, if you want a more expensive PJ later, look at a JVC or Sony.
Access HERE from this thread
coderguy is offline
