OPTOMA HD25 HD25LV new budget 2D 3D DLP FULL projector - Page 22 - AVS Forum | Home Theater Discussions And Reviews
 4Likes
post #631 of 668 Old 01-10-2015, 01:04 PM
falafala's Avatar
Quoted: 23 Post(s)
Originally Posted by terry2 View Post
I have the HD-25e but I'll give you my experience. I've had it about 16 months. I've always focused it using the grid pattern but never thought it had a really sharp image. It looks good with great color, just not as sharp as I thought it would be. A couple of months ago I connected a laptop. Brought up a screen full of text and found the whole image out of focus. I re-focused the projector to the text. All images from all sources now look sharp across the entire screen except the grid pattern is now off. It appears, at least on mine, if I focus the unit to the the grid pattern it won't be right.
This is excellent suggestion. will try this tonight.
falafala is offline
post #632 of 668 Old 01-11-2015, 06:46 AM
kenhdtv's Avatar
Quoted: 16 Post(s)
Agent8,I use mine on ECO mode and the fan is barely noticeable. It seemed to loud in normal mode but the brightness is still great on ECO so I left it in ECO and have been happy with it for the past year.
kenhdtv is offline
post #633 of 668 Old 01-14-2015, 12:00 PM
Liked: 0
Hey Ken, I lurked this thread for a bit and used your May 2014 settings on my HD-25LV. I casted a color grid from my galaxy note 4 (basic/reference mode display settings) and compared to what the projector displayed. Unfortunately your settings seem to offer a very pale/purple blue and various other colors seem wrong in comparison to what the phone displays. I realize the note likely has a much better display, but even using reference mode on the projector seems to give much more accurate results. Any tips?
peab0dy is offline
post #634 of 668 Old 01-14-2015, 12:14 PM
Liked: 0
Pictures (taken with note 4, not ideal i know) for an idea of what I'm seeing
ID:	478330   Click image for larger version
ID:	478338   Click image for larger version
peab0dy is offline
post #635 of 668 Old 01-14-2015, 12:18 PM
Liked: 0
Not sure how to edit posts but I would edit this to say more accurate not "much more"
peab0dy is offline
post #636 of 668 Old 01-15-2015, 09:50 PM
kenhdtv's Avatar
Quoted: 16 Post(s)
Peabody, I can't really see a difference in your screenshots but something may be lost in the process. I'm not familiar with the Note 4 so I'm assuming you are wirelessly broadcasting the image to a receiver stick plugged into the projector's HDMI port. If that's the case, you may be losing some image color quality in that wireless process.
Have you tried hooking up a blu-ray player or cable box or gaming system to the projector to see how everyday videos/movies look? If they look much better then you'll know you're losing something with the Note 4 video feed.
If your projector is brand new, the color may shift a little as the bulb ages. My calibration settings were with a 1000-hr bulb.
One long shot to try would be experimenting with the color space setting under the IMAGE / ADVANCED menu section. It's probably defaulted to AUTO but you could try one of the other options to see if it improves the pic. I doubt it will help but it was a thought.
And be aware that the USER settings get overwritten if you're in a different MODE -AND- you tweak a setting like brightness, contrast, etc. As soon as you make a tweak in one of the standard modes, those mode settings and your tweak now become the new USER settings.
kenhdtv is offline
post #637 of 668 Old 01-26-2015, 04:04 AM
Liked: 0
Hi Ken,
Thanks for your settings for the HD-25LV. I notice that you don't have settings for Color and Tint. Are you able to share that information as well?
Cheers,
Woel.
WoelNosaj is offline
post #638 of 668 Old 01-26-2015, 11:56 PM
kenhdtv's Avatar
Quoted: 16 Post(s)
Woel, I believe Color & Tint are disabled when you're using a HDMI video source which is the only source I use.
kenhdtv is offline
post #639 of 668 Old 01-28-2015, 01:51 AM
Liked: 0
Hi Ken,
That's strange as I'm connected using HDMI as well as my video source. Is there something that i may have set on the projector itself?
post #640 of 668 Old 01-28-2015, 06:45 AM
tucsondave's Avatar
Originally Posted by WoelNosaj View Post
Hi Ken,
Color and tint are disabled when feeding an RGB signal instead of YUV.
td
tucsondave is offline
post #641 of 668 Old 01-28-2015, 05:15 PM
kenhdtv's Avatar
Quoted: 16 Post(s)
The users manual says (on p36) that the color and tint are only supported for composite or component inputs (Video and VGA inputs next to the HDMI inputs, page 10).
http://www.optomausa.com/uploads/man...LV-M-en-US.pdf
kenhdtv is offline
post #642 of 668 Old 01-29-2015, 04:03 AM
Liked: 0
so is there something wrong with my projector as it is displaying those options?
post #643 of 668 Old 01-29-2015, 03:17 PM
bighernan's Avatar
Quoted: 20 Post(s)
Liked: 35
Just wanted to chime in that i dont think there is anything wrong with your projector. I get the same color and tint options as well. I connect my directv receiver to my Yamaha rxa-2030 and output to the projector from there. I also have my htpc connected to my receiver.
A quick note that when i edit my htpc, xbmc (openelec 5.0 to be exact), to output rgb colorspace i dont get the color and tint options on my projector. If i change the colorspace to what I prefer, YCbCr444, I get those options again.
I believe it all depends on what your projector is receiving as a signal.
bighernan is offline
post #644 of 668 Old 01-29-2015, 07:43 PM
Liked: 0
Thanks for your reply bighernan. Could it be a setting on my Receiver? I have a Marantz SR6008. I connect my foxtel box and PS3 into the receiver. Sorry for all the dumb questions as this is my first projector setup.
post #645 of 668 Old 02-19-2015, 01:25 PM
Patzig's Avatar
Quoted: 136 Post(s)
Liked: 275
Pretty interesting, I'll have to try this. Thanks for posting.
Patzig is offline
post #646 of 668 Old 03-01-2015, 11:25 AM
rural scribe's Avatar
Quoted: 54 Post(s)
Liked: 31
my experience with the HD25e
Just wanted to share my experience with the HD25e. I bought this to replace my ceiling-mounted IN76 in my home theater. Because of constraints in the room, I can't mount the projector more than 10 feet from the screen (Da-lite 77324 Video Spectra 1.5 high-gain 60 x 80" pull-down).
I was able to move it back a few inches because it is substantially smaller than the old projector. At maximum zoom, it just fills the screen, which my old projector couldn't quite manage, so the throw distance appears identical to the IN76. I'm very happy with the image and with the 3D effect. It is much brighter. I wish it had an s-video input, but other than that, it has everything I need.
I recently purchased a replacement lamp on Ebay which was supposed to be an original bulb in a generic housing. The housing didn't fit the projector, almost, but not quite. I had a similar problem once with a replacement bulb housing for the IN76, so I tried what worked before, swapping bulbs and putting the new bulb in the original housing.
This didn't work. I could get the bulb out of the replacement lamp housing O.K., but I could not get the original bulb out of the original housing. I couldn't loosen some of the screws that were securing the bulb. I tried all kinds of things to make the replacement housing fit into the projector, but ran out of options, so I sent it back, a little worse for wear, and got a full refund.
So I ended up spending double the money for a replacement lamp direct from Optoma. I just didn't want to take a chance on another generic housing.
Another thing I found out in my first experience with 3D was how touchy it is, at least with my Sony BDP-S5100. I found out that if the cable was connected to my Monoprice 2x2 HDMI switch that was also connected to my non-3D Vizio HD TV, it wouldn't play 3D content, or even show 3D options in the menu of dual 2D-3D disks.
I had to run a separate HDMI cable direct from the player to the projector for 3D. I also had to bypass the HDMI inputs and outputs on my Sony STRDH510 surround amp for the same reason. It can't handle 3D signals either. So I put in a ViewHD HDMI bi-directional A-B switch to shunt the 3D HDMI signal straight from the player to the projector and used a coaxial cable to handle the sound.
Most of the time, I have the A-B switch set to run the HDMI signal through the surround amp. I only need to switch it for 3D. I also use a Philips DVP5990/F7 player because I still have tons of DVDs and a few DIVX disks as well. I like to split the load between these two players. A DVR is also connected to the same system.
One of these days, I'll probably buy a new surround amp that is HDMI 3D compatible, but for now, the system works. All I need to do now is to get the projector calibrated and get rid of the dust glob that got in there when I was trying to get that replacement lamp to fit.
rural scribe is offline
post #647 of 668 Old 03-30-2015, 05:11 AM
Acute's Avatar
I have the HD25 for 10 months now and have just started to watch movies in 3D using the ZF2300 glasses.
I have been very happy with the picture quality in 2D. I set the black level accurately using Spears & Munsil Pluge 0% pattern. The resulting image has a very 3D look and good details.
But in actual 3D, the image brightness dropped tremendously. I wonder whether fellow members here can share what they did to get a bright enough picture when watching in 3D.
As for me, to get the best contrast, I use either of two sets of settings when watching movies in 2D: (a) Brightness -4, Contrast between -18 to -16 or (b) Brightness -5 Contrast -9. This suits me well in no ambient light on a 97" white-painted wall screen.
But to get a minimal bright enough picture in 3D, I have to raise contrast to -2 with brightness at -4, or contrast to -1 with brightness at -5. The problem in doing so is that the brightest two or three bars in Green and Blue are clipped, i.e. they become of same brightness. If I were to raise contrast further, then the highest three to four bars will be clipped.
I wonder what other solutions are available. Or should I just raise contrast to get the brightness needed for 3D and not care about the colors clipping? I prefer not to switch the lamp to bright mode as I find the noise very distracting.
Thanks for any advice.
Acute is offline
post #648 of 668 Old 05-14-2015, 10:46 AM
SillieBazzillie's Avatar
Quoted: 31 Post(s)
Liked: 25
Has anybody swapped in a new lamp yet? Mine is nearing 2,000 hours (I know it's rated for more) and the projector is definitely losing some brightness. Curious as to the impact going to a new bulb.
I do love this projector from a price/performance perspective.
SillieBazzillie is offline
post #649 of 668 Old 05-14-2015, 11:32 AM
ebrackin's Avatar
Great question. Mine is also around that amount of hours and I have noticed the change in brightness to the point where I went off calibration just to bright mode... Looked it up and its quite hard to find real replacement bulbs. Looks to be pretty expensive. I think the change out is easy though. remove the top cover and the whole unit slides out.
Optoma HD25
Pioneer Elite VSX 03THX
Monitor Audio RX6
Monitor Audio RXC
Monitor Audio R180HD
PS4
Xbox One
ebrackin is offline
post #650 of 668 Old 05-14-2015, 11:43 AM
Quoted: 31 Post(s)
Liked: 25
I grabbed one from Amazon, not the real deal but hopefully it improves the brightness. I should be replacing this evening and I'll post my thoughts.
post #651 of 668 Old 06-11-2015, 12:09 PM
Quoted: 31 Post(s)
Liked: 25
A little tardy in updating this. The first lamp I grabbed from Amazon didn't fit at all. This one, while tight, slid right in:
http://www.amazon.com/gp/product/B00...ilpage_o02_s00
The difference in brightness is immediately noticeable. A good overall upgrade.
post #652 of 668 Old 06-21-2015, 05:34 PM
sgibson's Avatar
Quoted: 89 Post(s)
Liked: 51
Hi kenhdtv,
Got the upgrade to 3D fever. Now i'm looking to replace my 6 yr old Optoma HD20. It has served me well. I see Optoma is currently releasing a new HD37 model. I can use my existing ceiling mount and just order and swap out the mounting plate. HD37 average price currently $1k+. Haven't seen any test reviews or users results on the HD37 yet.
OTOH, I came across the Optoma HD25-LV for about $850. Found a nice review at: http://www.projectorreviews.com/opto...magequality-4/
Then I found my way here and I'm curious about actual user reviews of the Optoma HD25-LV.
I found kenhdtv's info/settings page as a great source of info he and info others have provided here.
Some of the 25-LV features appear in the new HD37 model.
It doesn't matter that the HD25-LV was released in 2013, I'm interested more in it's image, black level and reliability. Ceiling mount is 11 ft. from 92" diag. 16:9 SilverTicket Gray screen with 1.0 gain. BTW, short throws are out for me.
Look forward to your feedback and thoughts.
Thanks and regards,
sgibson
sgibson is offline
post #653 of 668 Old 06-25-2015, 05:56 PM
sgibson's Avatar
Quoted: 89 Post(s)
Liked: 51
Guess this is a dead issue, seeing as no one responded.
That's ok, changed my mind on the HD25-LV anyhow.
sgibson
sgibson is offline
post #654 of 668 Old 06-25-2015, 10:03 PM
silvereyes's Avatar
sgibson
Sgibson, where is the kenhdtv info/setting page? I'm curious about that info as well.
silvereyes is offline
post #655 of 668 Old 06-26-2015, 07:46 PM
lizrussspike's Avatar
Quoted: 670 Post(s)
Liked: 809
sgibson
I own the HD-25LV for about 18 months now and love it. I use KenHDTVs settings and love this projector. I use it indoors and outdoors. I paid over $1K for mine so getting it less than that is good. I have had no issues and love it. Family comes over to watch movies and sports, and my son play COD games. Would highly recommend this projector. just recently bought the Sainsonic 3D glasses as I got them off of Amazon-4 of them for about $60. Just turn them on and watch them work. My 3 girls love watching 3D movies now.
lizrussspike is offline
post #656 of 668 Old 06-29-2015, 11:58 AM
silvereyes's Avatar
I found kenhdtv settings, they are great indeed. Does anyone have 3D settings using the Optoma ZF2100 glasses?
Also, what is the tint and color setting for kenhdtv 2D calibration? If its not posted I assume they are both at zero.
post #657 of 668 Old 07-10-2015, 07:51 PM
silvereyes's Avatar
While kenhdtv settings are good, I've discovered yet better settings, at least to my taste and my setup (133" screen and hd25e). These settings were done by Steve Withers so the credit goes to him. I found kenhdtv colors to be a bit too saturated.
Here is the link to them
https://www.avforums.com/threads/opt...tings.1761515/
post #658 of 668 Old 07-31-2015, 10:40 PM
Liked: 0
No air filter on my HD25-LV and no mention in the manual either. Mine does have an overtemp indicator LED next to the power LED - the manual mentions to make sure the vent areas are not blocked/restricted and to make sure the room isn't too warm if this light comes on. Is your overtemp light on or blinking?
Hi Ken,
I am a noob on this forum so please forgive me if I went about this the wrong way.....
I also have an Optoma HD25-LV. I recently changed the blower fan as it was making a loud humming sound. I then also updated the firmware to version C04. My color indexes now seem to have reset to default values. I didn't write down my original CW index number so I was wondering if you could provide me with your CW numbers from the service menu. I would really appreciate this as I've spend hours trying to correct the colors.
BTW. to get into the service menu on the HD25-LV doe the following; (with the projector on) - on the remote control press the OFF button once - now press the UP arrow then RIGHT arrow then UP arrow then LEFT arrow and lastly the MENU button.
The service menu will now appear and you will see 2 CW index numbers (one for the 2X and one for the 3X).
Thanks for your time and I look forward to hearing from you.
dlj123 is offline
post #659 of 668 Old 07-31-2015, 10:44 PM
Liked: 0
Smile HD25- LV CW Index
Hi All,
I have an Optoma HD25-LV. I recently changed the blower fan as it was making a loud humming sound. I then also updated the firmware to version C04. My color indexes now seem to have reset to default values. I didn't write down my original CW index number so I was wondering if anyone could provide me with their CW numbers from the service menu. I would really appreciate this as I've spend hours trying to correct the colors.
dlj123 is offline
post #660 of 668 Old 08-01-2015, 04:28 PM
kenhdtv's Avatar
Quoted: 16 Post(s)
dlj, my 2 CW index numbers are both 535. I never had to go into the service menu to adjust my colors - just used the normal user menu and the following settings:
http://www.avsforum.com/photopost/da...4401df_s1.jpeg
Hope you get your picture looking good again.
kenhdtv is offline
Optoma Hd25 Lv 3d Home Theater Projector
