Will any 3D DLP work on a CIH setup using the zoom method? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-31-2013, 10:51 AM - Thread Starter
Tom Monahan's Avatar
Location: Butte, Montana Hometown of the late Evel Knievel
Quoted: 60 Post(s)
Liked: 43
I have a 40x96 scope screen. For scope films, I need to zoom out to fill the screen. Are there any 3D DLP projectors that work when using this zoom method? I want a DLP for 3D only. The room is only 12'11" deep so I don't have a long throw. Also, it needs to be placed within the screen area vertically, around 1/3 above bottom of screen. My JVC 2D is ceiling mounted so a DLP would need to be shelf mounted below it.
Tom
My equipment: JVC RS55 for 2D, BenQ W7000 for 3D, Carada 40x117 2.925:1 AR BW Criterion screen, Navatar .8 HD conversion lens, Darbee Darblet, region free Oppo BP93, Toshiba HD-A35 HD-DVD, JVC HD-DH5U D-Theater, Mitsubishi HS-HD 20000 DVHS, Pioneer CLD-97 LD player/AC-3 mod, B&K AC3 Demodulator
Tom Monahan is offline
post #2 of 6 Old 01-31-2013, 10:55 AM
JoeBoy73's Avatar
Quoted: 12 Post(s)
Liked: 26
I know the mits7800 (probably most of their other PJs also) will do it for sure...I've seen the 7800 in action. Not sure if there are any others...
JoeBoy73 is offline
post #3 of 6 Old 02-01-2013, 05:43 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
I called Mike at AVScience and he told me the Mits wouldn't work. He didn't know of any 3D DLP's that would.frown.gif
When it comes to lens shift, DLP's are a JOKE compared to other projector types.
Tom
post #4 of 6 Old 02-01-2013, 05:51 PM
kmannth's Avatar
The w7000 won't work? It has almost as much zoom and a 3 LCD or JVC.
kmannth is offline
post #5 of 6 Old 02-01-2013, 08:20 PM
dougri's Avatar
Quoted: 45 Post(s)
Liked: 52
Originally Posted by Tom Monahan View Post
I have a 40x96 scope screen. For scope films, I need to zoom out to fill the screen. Are there any 3D DLP projectors that work when using this zoom method? I want a DLP for 3D only. The room is only 13' deep so I don't have a long throw. Also, it needs to be placed within the screen area vertically, around 1/3 above bottom of screen. My JVC 2D is ceiling mounted so a DLP would need to be shelf mounted below it.
Tom
The Sharp xv-z30000 fits the bill, but at a price (~$3k now). Throw ratio 1.4-2.8, lens shift btwn top & bottom of screen, motorized zoom & focus with lens memory. A bit spendy for a 2nd, 3d only pj though.
dougri is offline
post #6 of 6 Old 02-01-2013, 11:57 PM - Thread Starter
Quoted: 60 Post(s)
Liked: 43
The minimum zoom is 1.6. My room is only 12'11" deep so I wouldn't quite have enough thow to fill the screen. I wonder if the actual projector might deviate slightly from that 1.6 figure.confused.gif I wonder if manufacturers might underestimate minimum zoom a little just to be safe.confused.gif
If anyone who owns a 7000 would test their unit to see, I would be most grateful.smile.gif
Tom
