Infocus SP7210 Receiver Compatibility Please - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 02-03-2013, 12:42 PM - Thread Starter
Big Lar's Avatar
Hello folks, have a dilema here. I need some ideas as to what new receiver to purchase that is compatible with the Infocus MP1 I think its called. I remember when I purchased my Onkyo TX-SR705 that a few receivers only were compatible with the hdmi to dvi type setup. The Onkyo decided to Not send out a signal of hdmi at all which is why of course I am looking for a new receiver.
I am looking in the price range of about $600.00 max and quite frankly am a bit lost. I would have posted in the receiver section but figured the question is really more about the sp 7210.
I Highly appreciate all input as to the matter at hand. Thank you.
Larry
Big Lar is offline
post #2 of 6 Old 02-04-2013, 09:04 PM
ondaedg's Avatar
strange, my onkyo tx sr605 would send a signal to my 7210 with no issue. Can you point me to a link showing that the 7210 doesn't play nice with some receivers?
ondaedg is offline
post #3 of 6 Old 02-04-2013, 10:49 PM - Thread Starter
Big Lar's Avatar
I believe it was in the official sp7210 thread, my Onkyo had no problems sending the signal to my 7210 Until the hdmi output gave up the ghost, which is why I am looking for a new compatible receiver.
Larry
Big Lar is offline
post #4 of 6 Old 02-10-2013, 01:04 PM
davidd13's Avatar
My InFocus SP7210 works perfectly with my new Sony STRDN1030. No problems whatsoever.
davidd13 is offline
post #5 of 6 Old 02-14-2013, 02:42 AM - Thread Starter
Big Lar's Avatar
Thank You! Exactly what I am looking for as to info.
Larry
Big Lar is offline
post #6 of 6 Old 02-16-2013, 06:12 PM
tradewinds's Avatar
Quoted: 16 Post(s)
I just bought a Yamaha RX-V673. Should be delivered on Monday. Need to check my digital out of the SP7210 to see if by some miracle I can get it working again.
My Riser | My LED Star Ceiling | My HTPC Build
tradewinds is offline
