30' power cord for Projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-05-2013, 10:56 AM - Thread Starter
tasburath's Avatar
Hey guys,
I am running the cables for my projector. I already have the 30' HDMI cables and tested them.
Originally I was going to have an electrician pull a feed off the ceiling fan for the projector power, but I am now thinking about running a 30' power cable. Something along the lines of this:
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=1736785&SRCCODE=WEBGOOPA&cm_mmc_o=mH4CjC7BBTkwCjCV1-CjCE&gclid=CL_3od_rn7UCFQ2i4AodYR8AcQ
Is there anything I should be concerned with or should I look for a heavier guage power cord for the distance?
tasburath is offline
post #2 of 8 Old 02-05-2013, 11:00 AM
airscapes's Avatar
Quoted: 356 Post(s)
Liked: 289
If it will be run inside a wall cavity, you will need to have it hardwired correctly. If it is in a drop ceiling to an existing outlet, I think a long power cord would be ok. I would get a 16 gauge, 18 is a bit thin.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 8 Old 02-05-2013, 11:01 AM
Sheridan1952's Avatar
Distance (within reason) is not a factor. Certainly, 30' is nothing. What are you going to do, run it along the ceiling?
Sheridan1952 is offline
post #4 of 8 Old 02-05-2013, 11:11 AM - Thread Starter
tasburath's Avatar
I was going to run it above the drywall, coming out of a hooded plate to the projector and another hooded plate on the other end to plug into an outlet.
Obviously, if it is against code I won't go that route.
post #5 of 8 Old 02-05-2013, 11:24 AM
airscapes's Avatar
Quoted: 356 Post(s)
Liked: 289
You need to run a proper line if it is enclosed in the drywall.
Doug
post #6 of 8 Old 02-05-2013, 11:39 AM - Thread Starter
tasburath's Avatar
OK.
I'll have a feed pulled from the ceiling fan circuit.
Thanks for the info.
post #7 of 8 Old 02-05-2013, 01:56 PM
crussader's Avatar
Quoted: 49 Post(s)
Liked: 29
Here is an alternative:
http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10425&cs_id=1042513&p_id=4652&seq=1&format=2
Although, if you can pull from the ceiling fan, that might be the best way to go.
David
crussader is offline
post #8 of 8 Old 02-05-2013, 05:44 PM
Pulling from the ceiling fan involves the possibility that someone can come along and turn OFF the ceiling fan right in the middle of something you're watching. Plus, with some projectors, that's not good to do that.
