Help me choose a projector with a $1500 budget - AVS Forum | Home Theater Discussions And Reviews
Old 02-06-2013, 06:06 PM - Thread Starter
viper20's Avatar
Hey guys,
I currently own an Epson home cinema 6100 and i want to upgrade this projector. My budget is about $1500 and i would like to get a significant upgrade from what i currently own. I will be using it for movies as well as gaming. I was looking at the Epson 8350 but it seems like this pj has had some issues and its also pretty old is there anything newer/better that I should be looking at?
viper20 is offline
Old 02-06-2013, 06:11 PM - Thread Starter
viper20's Avatar
I also forgot to mention that this is going in a dedicated theater room if that makes any difference
viper20 is offline
Old 02-06-2013, 07:23 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
Does it have to be LCD?
Throw distance?
Screen size?
Jim McC is offline
Old 02-06-2013, 08:45 PM
nitesoul's Avatar
for 1500$, I'd recommend the Epson 3020, you really can't go wrong for the price
nitesoul is offline
Old 02-07-2013, 07:38 PM
chevyguy2021's Avatar
I love my 8350!
chevyguy2021 is offline
Old 02-07-2013, 08:48 PM
Shift's Avatar
Quoted: 94 Post(s)
Liked: 65
8700ub
Preponderance
1: a superiority in weight, power, importance, or strength
2a : a superiority or excess in number or quantity
2b : majority
Shift is offline
