First projector questions. - AVS Forum | Home Theater Discussions And Reviews
Old 02-07-2013, 08:47 AM - Thread Starter
bubs126's Avatar
First off I'm on a 500.00 budget. Second its in my basement so it will be dark. Third my basement has a low celling of 6 feet and need to celling or elevated mount it. Forth it must fit on a 6x8 wall (6 feet high 8feet wide).
So with all that I will be using this for movies off Blu-Ray, playing games and streaming off xbox360, as well as cable TV with HD.
Is there a budget projector u can recommend or what resolution of a projector would u recommend. Thank u and look forward towards ur response.
bubs126 is offline
Old 02-07-2013, 12:34 PM
cav500's Avatar
I will suggest the BenQ W710ST. I have this projector and I love it. Blu-Ray movies look great, my pc and PS3 games look incredibly good. 3D is excellent on this projector on the pc. With a budget of only $500.00, I don't think you can beat this one:
http://www.amazon.com/BenQ-W710ST-Short-Theater-Projector/dp/B006ISZM2E
cav500 is offline
Old 02-07-2013, 01:29 PM
s2Bill's Avatar
I really like my LG PA70G. List is higher, but bought on sale at Fry's for less...I'm told they put it on sale often. Only 720, but looks good and 30,000 hr lamp life and contrast numbers make it seem like my CRT's. Of course LED lamp makes it so much better. IMHO
s2Bill is offline
Old 02-07-2013, 02:27 PM
Verge2's Avatar
Quoted: 627 Post(s)
Liked: 151
Slow down tiger.
Verge2 is offline
Old 02-07-2013, 08:03 PM - Thread Starter
bubs126's Avatar
I was looking at the AAPX LED Showtime 3D, AAPX P300 or the Optoma ML500?? Any thoughts?
bubs126 is offline
