Viewsonic Pro8200 VS Optoma HD20 Help me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 02-17-2013, 04:05 PM - Thread Starter
CBurns05's Avatar
LOOOOONNG time viewer occasional poster. My wife and I are moving into a new house at the end of next month. She is allowing me to finish the basement and have a projector down there. We are on a lil bit of a budget as we are expecting our first kid/kids in the middle of September. I've been reading and looking up both projectors. I had my heart set on the Pro8200 but the Offset is kinda worrying me. My Finished ceiling Height will be 7'9" I will have the projector mounted around 12'6" away from the screen and hoping for around 110" 16:9 screen. I've got all I need except the projector, screen and speakers (thinking monoprice in wall. The wife will think it looks nicer) We both love having people over for parties and such so the lights will be on when we have guests over more than likely to watch UFC PPV and Nebraksa football games as well as hosting family holidays. ANY and all help will be greatly appreciated.
CBurns05 is offline
post #2 of 5 Old 02-18-2013, 10:12 AM
jnabq's Avatar
Liked: 39
Seems the bottom of the screen will be about 1' 3" off the floor if your limited to a ceiling of around 7' 9" with the Viewsonic, and that size screen. HD20 looks like 2' off the floor. I got the numbers off http://www.eliteprojectorcalculator.com/ if you want to look at 'em. For a comparison my 126" sits at 1' 6" off the floor, which makes it pretty much centered at eye level, when sitting.
jnabq is offline
post #3 of 5 Old 02-18-2013, 05:47 PM
West1134's Avatar
I've got the Viewsonic PRO8200. It is my first projector. I've had it since December 2012. Overall, I'm VERY happy with this PJ!
I've got it setup in a room roughly 12ft deep (screen to PJ hanging from ceiling) and 10ft wide. My ceiling is approx. 8ft tall.
I built my own screen (def recommend you do the same since you said you were on a budget. I followed a DIY BOC (black out cloth) build on here and completed mine for about $70 in materials) that measures 90" of viewable screen with 4" of black border. My screen sits above an entertainment center that is roughly 4 feet tall. Here's a pic:
Technically my screen could go slightly larger, but with the border around the screen, the height at which I have it mounted to clear the entertainment center, and how close the screen frame is to the ceiling, not to mention how close I sit to the screen, my 90" screen is plenty for me.
With the 8200 not having image shift, and using a standard mount, you'll notice that the PJ actually points up towards the ceiling a little (when projecting the bottom of your screen as high off the ground as I am). Because of this, my PJ throws a little light onto the ceiling which then "Halo's" on the surrounding walls. My solution to this is going to be to go buy a spacer to drop the PJ another 1/2" or so which will hopefully fix the Halo effect. Since the PJ sits above a couch, I'm not worried about it hanging too low. Another solution seen on here is building a shroud, but I'd rather try the spacer solution first.
In the end, the Halo effect I'm referring to is really minimal, and not that much of an issue, and with an 8' ceiling it still works quite well.
Hope this helps!
West1134 is offline
post #4 of 5 Old 02-18-2013, 09:45 PM
coderguy's Avatar
Quoted: 303 Post(s)
Liked: 271
I would up the budget slightly and try to go for the Benq w1070, it's the one to get in this price range.
Access HERE from this thread
coderguy is offline
post #5 of 5 Old 03-01-2013, 04:23 PM
ViewSonicCorp's Avatar
Pro8200_User_Guide.pdf 3200k .pdf file
Please refer to attached Pro8200 User Guide and refer to the section on Adjusting Projection Image Size. The graphic chart in this section will help you determine the screen size and projection distance.
ViewSonicCorp is offline
Viewsonic Pro8200 Dlp Projector
