VIEWSONIC PJD7820HD PROJ 3000 LUMENS 1080p 3D using cheap d-link Glasses less than $700 - Page 14 - AVS Forum | Home Theater Discussions And Reviews
 3Likes
Old 06-09-2014, 08:17 AM
ptbcomposer's Avatar
Liked: 25
We've already determined there's something weird going on with the ps3 and this projector. Every other video source (pc, cable tv, bluray, xbox 360) is fine, but for some reason the ps3 produces a weird flicker effect. Maybe you could use a hdmi to dvi adapter and then a dvi to vga adapter into the projector. Don't know if this will fix it, but at least it will change the 1080p signal from digital to analog which might help. Analog signals are always on, but digital signals are not. There are either on or off; any variance below a certain threshold will be read as an off, and this projector seems to be sensitive.
ptbcomposer is offline
Old 06-09-2014, 09:59 AM
edgarh's Avatar
Originally Posted by snownskate View Post
Any recommendations on a 35' HDMI cable for this projector? I'm having the same issue with the 35' cable having a hard time locking on to the signal, my old projectors were fine with this setup so it's definitely an issue with this projector.
I'm using a 50' cable without any issue, I had to carry on my blu ray and projector to the shop to get one that works, had similar issues as you had, at the end I got one that works.
edgarh is offline
Old 06-09-2014, 10:02 AM
edgarh's Avatar
Originally Posted by Sherak View Post
Hey! Lucky I found this thread! maybe :)
I bought one of these projectors 2 weeks ago and I cant deny I am very happy with it, for the price its somthing else. Bar one issue! :(
I have it hooked up to both a gaming PC and a PS3, the PS3 is what I would like to use it for 3D films and gaming but im having a mare setting it up.
Firstly when you set up the display on the PS3 using automatic it scans the display and determines it can output in 1080p so chooses this as the default output. Problem is, as I have noticed on here, it doesn't like 1080p from some devices thus it cant lock onto the signal and it flicks between the PS3 output, white noise and the blue screen.
At first I figured the projector was faulty as I tried 2 ps3's and 3 HDMI cables, all of which gave the same result. I took the projector back and they gave me a new one (I forgot to put the 3D glasses in the box, oppps :-) ha ha, so now have two pair! result) Anyho turns out the projector wasnt faulty, it just doesnt like the 1080p signal from the PS3.
Prob is running it in 720p it doesnt detect it as a 3D device so I cant play or watch 3D stuff on it..
Is this somthing anyone else has had a problem with? Any idea on solutions?
Thanks...
Don't know if it works for you, but with my blu-ray I had issues running 3Ds files from USB and I changed the blu ray resolution to 720p as someone suggested on this same forum, and it worked for me, give it a try, don't know if you can change the PS3 from full HD to 720p, but if you can, do it and see if it helps you out.
edgarh is offline
Old 06-09-2014, 03:59 PM
cre8toruk's Avatar
Hi Chaps... I hope someone out there can help me....
I bought the 7820 and I've been desperately trying to get the 3D to work.... Can someone please put together a definitive guide on what I need to do to playback 3D from my PC?
I have the projector set up as an extended screen... and the option to enable stereoscopic 3d settings for all supported displays is ticked... yet no 3D source I play on the projector screen is detected by the glasses or the projector.... I did have some joy disconnecting my PC monitor and setting the stereoscopic player (I just found on the internet) to use AMD HD3D but the glasses just seemed to flash erratically and the image shown didn't really look 3D at all...just a blurred mess....
Complete Noob when it comes to all this so a setup guide would be useful....
fingers crossed...
cre8toruk is offline
Old 06-09-2014, 04:05 PM
Liked: 25
Well, I have used it several times through the PC and there is no specific 3D detection going on inside the projector that I can tell. It's just a switch. You turn 3D mode on the projector on and the screen will look like a weird jumbled mess. The glasses do all the work, which is why they are called active 3D glasses. You don't need any software on the computer. You need a video file that is already in 3D format and the projector just automatically decodes it to work in conjunction with the glasses. Hope this helps.
Old 06-11-2014, 01:12 AM
Sherak's Avatar
Thanks for the help guys,
What happens with the PS3 is it detects if it plugged into a 3D display and if so it will ask you some extra details when you set up your displays, this wasn't happening but as of yesterday it started detecting it as a 3D compatible device and allowed me to input the screen size as a setting.
I thought I had cracked it but when I go into the 3D ready games they do not detect the display as 3D and thus I cannot select the option to start the game in 3D.
I am a touch confused as to how the 3D menu works in the projector thou and the manual doesn't really shed any light.
Sherak is offline
Old 09-03-2014, 06:59 PM
Liked: 0
Hi Everybody!
I just bought a Viewsonic PJD7820HD and I just love it! The picture's clear and razor sharp after a little fiddling with the focus. I've played some games and watched a lot of movies and I really like the fact that this projector has a native resolution of 1080p. However, I read on some other forums that it scales all images. Why would it have to scale an image if the input is at 1080p? Am I watching scaled movies and not real 1080p? Also, when I tried to watch 3D movies with this projector, the max frequency is 24Hz, even though I'm using an HDMI 1.4 cable (which is the latest version of HDMI right?). The projector was listed as having a max frequency of 120Hz so I can't understand why I can't get 60Hz 3D at 1080p.
One thing I noticed while looking online is that the bandwidth of the HDMI cable is too low to support 60Hz at 1080p. Forgive me for being a noob here (this is my first projector) but would I be able to get 3D 1080p at 60Hz if I used a VGA cable?
I'm using my laptop that has Nvidia 3DVision with this projector. When I switch the resolution to 1080p 3D in the Nvidia control panel, the projector does some frame packing and this ends up cropping the picture so I can't view the whole desktop. The start button on the bottom left and the date and time on the right are cut off. Basically, all the extreme edges of the screen are cropped. How can I fix this? This didn't happen on my 3D LED TV (Samsung 55")
Mak.
TheMak is offline
Old 09-03-2014, 10:01 PM
nxsfan's Avatar
Quoted: 24 Post(s)
In my experience, the PJD7820HD overscans 24Hz content. I drive it at 1080p60 to get 1:1 pixel mapping.
Framepacked 3D is limited to 1080p24:
http://www.cnet.com/news/how-3d-cont...-vs-broadcast/
Of course this means the projector overscans when it's receiving framepacked 3D content.
As the above link explains, framepacking is a special way of encoding the left and right eye images into a single frame, you can't recreate that using VGA.
HDMI 1.4a is limited to 1080p60 for 2D video (spec/bandwidth limitations). You can drive at 120Hz at a lower resolution (probably).
You can artificially resize the desktop to an effective lower resolution via Nvidia Control Panel to make the whole display visible, it's not ideal I realize.
There's nothing to stop you from using a different 3D standard like TAB or SBS @ 1080p60, although your worse off due to halving your effective resolution.
nxsfan is offline
Old 09-03-2014, 11:56 PM
Liked: 0
Sorry if this is a dumb question, but what's overscanning? And what would happen if I did use VGA? Would I get no 3D at all? And how do I use SBS? I know that there are some 3D video files that are SBS Full HD like some of the sample 3D files I downloaded off the web. Can this projector do SBS? I've got a GTX 580M in my laptop but it's gonna be upgraded to a GTX 880M very soon, like within the next 5 days. I was thinking it was something to do with the graphics card and my new one could handle it better. Do I have to say goodbye to Full HD 1080p 3D at 60 or 60+ Hz?
Thanks a lot for the answers!
EDIT: [I googled overscan and understood the basic theory, but I'm still unclear as to whether the projector will add more lines to the image or take away from it. Also, how can I access overscan settings in this projector?]
TheMak is offline
Old 09-04-2014, 09:56 AM
nxsfan's Avatar
Quoted: 24 Post(s)
Overscan: The projector is doing what we don't want, it's cropping the outside of the image and then scaling the uncropped image to fill the view. I have no idea why devices overscan in this day and age. I don't think you can do anything to change this behavior.
Yes - you do have to say goodbye to Full HD 1080p 3D at 60 Hz, it's nothing to do with this projector it's just not possible in the HDMI 1.4a spec. By the time they come out with HDMI 2.0 projectors, they will probably be at 4K so you still won't be able to use 3D at 60Hz or higher at the native resolution.
Given the beefy graphics cards I'm guessing you want to game in 3D, hence the 24Hz is too low? IIRC Nvidia 3D vision arbitrarily restricts you to 1080p24 if an HDMI 1.4a device is detected. You'ld be in the same situation (limited to 3D in 1080p24) with virtually any modern consumer 3D projector.
The PJD7820HD is capable of processing SBS and TAB 3D images so like I said before you could game at ~1080p60, except you would be halving the linear resolution along one axis. This is probably better for gaming than true 1080p24. Your problem is finding a way to output in SBS mode. I don't believe you will make any progress with Nvidia 3D Vision or 3D Play, but you might have luck using the Tridef 3D drivers. You will most likely need to manually enable the desired 3D mode in the projector's menu.
TheMak likes this.
nxsfan is offline
Old 09-04-2014, 10:06 AM
kreeturez's Avatar
Quoted: 412 Post(s)
Liked: 324
I've had similar experience with 3D Vision and wrestling with its limited resolution/refresh-rate combination support.
I did find that 720p@60hz worked fine in framepacked mode (and is apparently officially supported by Nvidia); so that may be a better option if available than trying to force SBS. It's also a reasonable compromise because as you say, gaming at 24hz is sluggish.
BenQ W1070 Projector; Kodi (on Ubuntu, OpenELEC & S802) via Sony STR-DH540 AVR with Boston Acoustics SoundWare XS SE 5.1 Audio + Jamo 210 Sub. Emby for Mobile Streaming.
Helpful post? Click the 'Like' button!
kreeturez is offline
Old 09-08-2014, 09:48 PM
Liked: 25
I'm not very familiar with all of the terms people are using, but I can tell you that I use an AMD R6 260x (a fairly high-end AMD gaming card). I use the HDMI port and I set Catalyst to zoom the image a little so that it fills my projector screen. With a little bit of tweaking, I can confirm that I get all the edges of my screen and that nothing is cropped or missing. The projector says 1080p 60Hz. The picture quality is amazing.
I have always used AMD cards because I always use an AMD processor. I am pretty familiar with Catalyst settings and know how to get it to show the image I want on my projector and games.
If you are having problems with Nvidia settings, I would recommend trying an AMD card to do what you want and also save a few bucks.
Also, in 3D mode, I get the same settings. The only thing that changes is the expected double image before activating my glasses.
Old 09-09-2014, 03:07 AM
Liked: 1
I'm looking to jump in and this sounds like the perfect projector.
babyparrot is offline
Old 10-05-2014, 02:41 AM
toobs1234's Avatar
Could someone who has this projector do me a huge favor: measure the minimum focus distance at both zoom extremes?
I am thinking to use this projector for a 3d structured light scanning setup. Viewsonic list minimum focus distance as 30", but that appears to be for the 1.15 throw ratio based upon the listed minimum image size. Other vendors (e.g. Acer) who sell projectors based on the same light engine list the minimum focus distance at 57", which appears to be for the 1.5 throw ratio based upon minimum projected image size specs.
I need a short minimum focal distance and need to use the 1.5 throw ratio. I hope the Viewsonic will fit my needs, but as it's specs seem to be an outlier from the other vendors, I have some concerns about their validity.
thanks in advance to anyone who can help!
John
toobs1234 is offline
Old 03-10-2015, 02:33 AM
jsimeo's Avatar
Exclamation
Hello.
I have this projector for some months, and I have a problem.
Brilliant color is (off) and grayed out. Always off, can't change to "on". I'm talking about 2D viewing, as in 3D anyway you can't change it.
This happened suddenly and without an obvious reason. I had the projector on brilliant color mode on all these months. One day powered it on, and I noticed the lumens were lower than usual, went in menu and saw the grayed out setting.
Just checked but I can't see any FW on viewsonic's site.
Any help?
Thank you.
jsimeo is offline
Old 03-10-2015, 03:11 AM
DtommyD's Avatar
Originally Posted by jsimeo View Post
Hello.
Any help?
Thank you.
I'd say your on the wrong sorce but you've used it in the past. Presumably you know the difference between hdmi ands video.
But, just for fun, make sure your on the correct source and not watching the RCA feed going through a VCR for example. (VC what?)
Next use a different hdmi product like a roku or Apple TV (or whatever). Double check the refresh rates of your box. Try a different cord. Confirm you getting a good signal in the first place on a TV and not your projector or monitor. Restart everything. Everything.
Super obvious stuff of course but you need to cross these off of the list. I'm sure you did a few of these but do it again with fresh eyes. I've had issues with 1080i being automacally selected. It looked bright/overblown and horrible.
It still sounds like your in 3D though.
If your buying a new projector, buy more lumens than you will use. Running it in "Eco Mode" makes your bulb last 20-40% longer and reduces noise and heat.
DtommyD is offline
Old 03-10-2015, 06:57 AM
Liked: 25
You can also try doing a factory reset as a last resort. Search this thread for how to enter the service menu; I forgot what the buttons you have to press on the projector.
Also, I recommend against using Brilliant Color...using that setting burned out my lightpipe after only 2 months during the summer. I started to see weird fragmented shadows on my screen and finally got the courage to open the projector up and saw a bunch of plastic-metal film was flaking off the lightpipe, presumably because it was getting too hot and melting it.
Turning off Brilliant Color permanently and adjusting your gamma/contrast/brightness is the was to go.
jsimeo likes this.
Old 04-27-2015, 11:19 PM
jsimeo's Avatar
I did the factory reset through the service menu and it worked! Thank you! Only with this action I had again the brilliantcolor setting available!
I'm searching for some info but I can't find something on previous pages of the thread:
1. What are the readings you guys have at temperature on service menu's "page" 2; I get at low lamp mode a reading about 290 - 300 after 15 minutes on. A month ago (colder weather then - about 6-7 Celsius lower on room's temp) was 230-240.
2. Is this Celsius, Fahrenheit or what;
jsimeo is offline
Old 04-29-2015, 04:44 AM
jsimeo's Avatar
Question Temperature readings in Service Menu.
Please let me add one more.
3. It is the temperature of what component/point?
The most helpful answer for the moment, would be the readings you have and your room temperature, to ensure that there is nothing to worry about.
(ptbcomposer scared me a little with his burned lightpipe.)
jsimeo is offline
Old 05-14-2015, 11:48 AM
jsimeo's Avatar
17 days after my question... Nobody? No help? What happened guys? Are you alive? Is proj alive?
jsimeo is offline
Old 05-19-2015, 10:04 PM
nxsfan's Avatar
Quoted: 24 Post(s)
Projector is alive and doing well.
Temperature #1 : Anywhere from the high 200s to 300. Not seen it over that.
No idea what the units are, or what part.
nxsfan is offline
Old 05-20-2015, 04:24 AM
jsimeo's Avatar
Your room's temperature?
Thank you for your answer!
jsimeo is offline
Old 05-20-2015, 08:24 AM
nxsfan's Avatar
Quoted: 24 Post(s)
64f / 18c
nxsfan is offline
Old 10-23-2015, 10:23 PM
nxsfan's Avatar
Quoted: 24 Post(s)
I bought the PJD7820HD August 2013. Since then I must have watched 100s of movies and I have certainly spent hours calibrating the picture, I have tried all published calibration settings with and without BrilliantColor and tried calibrating myself with the Disney WOW disk and other online content.
While the detail of the PJD7820HD is great and in many ways it has really beautiful and vivid pop, I have never been 100% happy with the picture. I felt that colors on my older and supposedly inferior Acer H5360 (which I have in the bedroom) looked better, but I wasn't sure if this was a result of my projecting onto a tinted wall (versus a dedicated screen in the living room).
Long story short, I made the insane and painful decision to buy the BenQ W1070 that everyone raves about. After 10 minutes putting in some settings I found online, the BenQ looks significantly better than ViewSonic ever did. Although it's very painful buying a projector that on paper is so similar to the PJD7820HD (RGBRGB wheel aside), the BenQ is far and away a better projector - and quieter too. If you are in the same position as me and use the PJD7820HD in dedicated/dim environment, I sadly but enthusiastically recommend biting the bullet and moving to the BenQ W1070.
nxsfan is offline
Viewsonic Pjd7820hd Full Hd 1080p Projector
taboola here
