AVS Forum | Home Theater Discussions And Reviews
AVS Forum | Home Theater Discussions And Reviews (http://www.avsforum.com/forum/)
-   Digital Projectors - Under $3,000 USD MSRP (http://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/)
-   -   VIEWSONIC PJD7820HD PROJ 3000 LUMENS 1080p 3D using cheap d-link Glasses less than $700 (http://www.avsforum.com/forum/68-digital-projectors-under-3-000-usd-msrp/1459077-viewsonic-pjd7820hd-proj-3000-lumens-1080p-3d-using-cheap-d-link-glasses-less-than-700-a.html)
leckian 02-19-2013 07:03 AM
This could be a good starter projector for someone. Features are great with 1080P and D-Link 3D. I pre-ordered one to play with since my Epson 8500UB is not 3D.
Here are some basic specs.
Brightness 3000 Lumens
Contrast Ratio15,000:1 (w/DynamicEco™)
Aspect Ratio16:9 (native)
Color Wheel6-seg RGBCYW / 7200rpm
Color Depth 30 bits, 1.07B Color (10+10+10)Color
Obviously not a home theater projector but it looks like fun nonetheless.
Lamp Life (normal/eco-mode)4000 / 6000 hours* (Normal / Eco-mode)
Once I get it I will post a review.
narhic_fd 02-20-2013 07:14 PM
would be interested in knowing how this one turns out when you get it. I would especially like to know how much brightness is lost in 3D mode. I have an older viewsonic pjd6211 and at the end of this year i want to make a good jump in getting something better. Could you figure a way of measuring the lumen output in 3D mode?? could you make a video of this projector in use in both normal eco mode and in 3D mode or take some pics with a camera that can accurately show the diff in brightness??
leckian 02-20-2013 08:55 PM
Once I get it I can do some of that and post it. Cost only $699..was surprised to see it has CMS built-in...probably not good for someone sensitive to rainbows though.
narhic_fd 02-21-2013 04:48 PM
Also, please make note how big a projected image you get with it and how far away you have that projector to get that image. It seems to be pretty new cause its hard to find much info on it..of personal use that is
leckian 02-21-2013 09:55 PM
Here is link to owners manual...it has throw distance chart.
http://www.viewsoniceurope.com/uk/assets/149/28077.pdf
leckian 02-21-2013 09:59 PM
This projector lamp life is rated up to 6000 hours. The warranty is 3-year limited warranty on parts and labor, 1-year limited warranty on lamp, 1st year Express Exchange® service.
narhic_fd 02-22-2013 06:27 PM
Yeah, I check out the PFD file on that yesterday but what I've come to find is that they don't always match real world use. Once you have a good image size that is bright enough for you and has plenty of contrast let me know what size image you get and how far away the projector is. Another thing i couldn't find is what type of 3D does this projector use. Does it use Page Flipping, side by side, interlaced or what?? The main thing i want to know though is the brightness in 3D mode compared to normal mode.
leckian 02-22-2013 10:35 PM
The 3D glasses make any projector look significantly dimmer but with a rating of 3000 lumens there is reason to assume that your projected 3D picture, adjusted to compensate for the 3D glasses, will be bright enough.
narhic_fd 02-23-2013 08:10 AM
Yeah, I know that shutter glasses technology blocks out 50% of the light but my concern is how much brightness is lost when the projector is put in 3D mode. As far as I know, when any 3D projector is switched into 3d mode there is always lost of brightness cause its almost dividing the brightness into 2 images. For example, My projector is a viewsonic pj6211 that has 2500 lumens brightness. when I switch my projector into 3D the brightness drop from 2500 to about 1100 lumens. So you take the loss of projector brightness and add that with the loss of brightness from the shutter glasses and it isn't very bright. That's why i want to know how much is loss in lumens when the projector is put in 3D mode.
GEM1 02-26-2013 08:51 AM
newbie question - why do you say 'obviously not a home theater projector". My newbie impression is that 1080p, 3000lum, 150000:1 all speak home theater ... certainly not going to use the projectors tiny speakers, but I doubt many would in any projector even if much better than this. What spec is it missing to be 'home theater" (besides Crestron / ethernet- can just use the rs232 instead)
thanks
leckian 02-26-2013 09:53 AM
thanks
It was designed to be a data projector. A home theater projector should have a faster color wheel. I should get a first look at it tomorrow.
Sisyphus 02-26-2013 03:34 PM
Do you see rainbows, leckian? I'm pretty sensitive myself so I'll be curious to see how you feel about the color wheel speed. Amazing price for a 1080p projector let alone one with hdmi 1.4a 3D. smile.gif
narhic_fd 02-26-2013 06:24 PM
My projector is an older viewsonic pjd6211 with 2000/1 contrast ratio so this things is a major increase. Yes it is a data projector but those specs beat many Home theater projector specs. I'm really interested in seeing how this projector perform in 3D mode.
leckian 02-27-2013 03:45 PM
I have received this projector and viewed it briefly. I don't think you will find a better projector for $699. This projector doesn't pretend to be a home theater projector....when you use the HDMI input the color, tint, and sharpness control are grayed out and unusable. I think this could be a deal breaker for some people. That is a big negative especially if you want quickly want to adjust the colors. There is a CMS system that will allow great control over the picture but that is a time consuming process that I will attempt in the next few days. For people using a a-v receiver that have video color controls that could help to make small adjustments, The projector is brighter than my Epson 8500UB but it feels like the 3000 lumen rating is an overstatement. My only other experience for comparison with cheap 1080P projectors is with the Optoma H33 and the PJD7820HD clearly has superior black level. I consider the black level of the Optoma to be unacceptable while the Viewsonic represents an approximately 20% improvement making it barely adequate. That is not a bad thing considering the price tag. The 3D I will not be able to test until the 3D glasses I ordered arrive. I am not sensitive to rainbows but I imagine those who are would have a problem. I will try to update this by Sunday as long as I receive my glasses by Saturday.
narhic_fd 02-27-2013 05:54 PM
I'm not sure if you have your projector hooked up to a computer or 3D player devise, but can you switch your projector to 3D mode just to see how much the brightness goes down when in 3D mode??
leckian 02-27-2013 07:06 PM
I have no glasses yet or 3D DVD player...both are going to be here soon. I switched to Comcast 3D program...the brightness loss is not huge but the contrast disappears and the image looks washed out. Unfortunately when in 3D mode all color, brightness, and color controls are disabled. The glasses could help with the washed out picture but that remains to be seen. Some external method of controlling the image would probably be needed to get the best picture in 3D mode.
narhic_fd 02-27-2013 07:20 PM
If you had to estimate how much brightness was lost would you say, 60%, 50% or 40%. My blacks get washed out in 3D mode to but i figured out how to maintain some blacks. On my projector there is a setting in the OPTION menu where you can turn Brilliant Color on or Off. Now, you don't want to turn that off when your using the projector in normal mode, that makes it worse, but if you turn that off while in 3D mode it will get rid of some of the gamma and give you some better blacks. The only problem is that when you turn that off it does loose some brightness. But, with a white scrreen or high gain screen it will give some brightness back
leckian 02-27-2013 07:51 PM
I tried turning off brilliant color and switching to 3D mode but the projector automatically goes back to brilliant color on when you switch to 3D. The loss of brightness is not huge...I would say no more than 20%...plus I was using it in the economy lamp mode so I could add a little brightness by switching to normal mode. The loss of contrast/pop in the picture though is dramatic. I want to see how it looks with the 3D glasses...if it is too washed out I will see if the DVD player has some picture controls or look for some other external control.
narhic_fd 02-28-2013 05:39 AM
how big of an image do you have projected On your wall or screen???
narhic_fd 02-28-2013 05:41 AM
Try turning on 3D mode first then turn of Brilliant color.
leckian 02-28-2013 07:39 AM
I have a Vutec Silverstar 88" diagonal
leckian 02-28-2013 07:41 AM
I did try that already...this was disabled in 3D mode.
leckian 02-28-2013 07:42 AM
I believe this product would really help any projector...especially in 3D Mode:
http://darbeevision.com/
Here is avs member review:
http://hstrial-jrodriguez996.homestead.com/Darblet-Darbee-Vision-Review.html?_=1337122950922
leckian 02-28-2013 07:59 AM
I just bought one these Darbee Darblets so hopefully it put the pop back into the 3D picture.
This image gallery shows the effects of the Dablet according to manufacturer:
http://darbeevision.com/gallery
leckian 03-01-2013 10:13 AM
I was able to enter the service menu of this projector and there are tons of settings. There are a few I have tried but the changes do not save and they revert back for factory default. For one there is dynamic black mode that is set to off by factory. When I put it on I can see an improvement in the picture, even with the lights on but it will not save and reverts back to off. Does anyone know have to save the settings in the service menu?
RamblinRoyce 03-01-2013 11:58 AM
If you don't mind me asking, where did you buy the PJD7820HD? I pre-ordered for J&R but uncertain when it will arrive. I'm new to the Projector world and bought a cheapy PJD5133. It looks great for the price but since I want to use my computer with the projector, the 800x600 resolution isn't good enough. Otherwise, I'd be happy enough watching TV and Netflix on it.
I am returning the PJD5133 and have been trying to figure out if the PJD7820HD is released? Or where I can get one? Or how long I can expect to wait for my pre-order? I know you can't help with all of these questions but if you have any info, it would be much appreciated.
swirl54 03-01-2013 12:04 PM
I am also interested in where you got this from and how it compares to the benq w1070 i love the warranty it comes with.
swirl54 03-01-2013 12:07 PM
Also will this display 3d video games from the ps3 with no add ons in other words is it full 3d or just 3d ready?
leckian 03-01-2013 12:30 PM
I bought this directly from Viewsonic on Feb 25, They had 36 units in stock when I ordered
leckian 03-01-2013 12:36 PM
I would say yes, but I have not tested with PS3...it works with a 3D Blu-Ray with the addition of D-Link 3D glasses which cost about $25.00
Powered by vBulletin® Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2017 DragonByte Technologies Ltd.
