Panny PT-AR100U or BenQ W1070 for 165" screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-28-2013, 03:07 PM - Thread Starter
babka's Avatar
Has anyone tried them side side by side? Any input is appreciated.
babka is offline
post #2 of 7 Old 02-28-2013, 04:19 PM
Jim McC's Avatar
Quoted: 115 Post(s)
Liked: 58
First off, I would plug in your screen size and throw distance in the Calculator Pro at Projector Central, and see how may foot lamberts each gives you.
Jim McC is offline
post #3 of 7 Old 02-28-2013, 05:00 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
Those numbers are not that much help, for they are always incorrect with the projectors that I have owned. But what can do you have for your screen? I have the W1070, I can be a little help
blee0120 is online now
post #4 of 7 Old 02-28-2013, 09:42 PM - Thread Starter
babka's Avatar
I have a 1.0 gain DaLite white screen currently. Projector central shows a throw distance for the BenQ of 15' to achieve a 144" wide image whilst with the Panny, 21' away from the screen is needed.
babka is offline
post #5 of 7 Old 03-01-2013, 08:13 AM
Mr.G's Avatar
Quoted: 603 Post(s)
Liked: 308
As one poster said although the different projection calculators may not be super accurate they at least give you some idea when doing a comparison.
Your go-to calculator should be the Elite developed by Coderguy. For any projector you are going to get a throw range - closest, farthest and the default mid range.
http://www.eliteprojectorcalculator.com/
For the two projectors you're comparing neither is ideal for a 165" diagonal screen without increasing the gain to around 1.3. In 'Best Mode - Low Lamp' you want to achieve 12-16 fL in a dark home theater environment. The Elite calculator shows the BenQ is the brightest of the two. Keeping your present 1.0 gain screen and mounting the projector at its closest distance (13 feet 10 inches) you can achieve 12.6 fL...but it drops off to 9 fL at 500 hours of use.
So if brightness is your sole criteria then the BenQ wins. What projector were you using previously to light this screen? Was it a conference/classroom ultra-bright projector?
All I Really Need to Know I Learned in Kindergarten Movies
Mr.G is offline
post #6 of 7 Old 03-01-2013, 10:41 AM - Thread Starter
babka's Avatar
Thanks. I haven't used a projector in about 10 years due to room constraints. But I do remember lighting it up with an old Panny and it looked decent. But I would think 10 years later, there would be more light canons out for larger screens, and in a decent price range. What other machines would you recommend?
babka is offline
post #7 of 7 Old 03-01-2013, 12:52 PM
blee0120's Avatar
Quoted: 430 Post(s)
Liked: 230
If you have a dark theater and light control, the Benq will work. In high lamp you will get 16-20ftL. In smart eco model, you will get 13ftL. The ideal is 12-16ftL. Its very doable. I once used a Marantz VP8600 that was giving me 10ftL on a 135in 1.0 gain screen. I prefer 12-15ftL myself
Panasonic Pt Ar100u Lcd Projector , Benq W1070 1080p 3d Projector
